  2. Announcements
  • OliverDogO OliverDog
    @marceloaqno WOWWW
    now I understood... but I think this is not clear on the build steps...
    I choose a Serial Gateway, but on that lines, they say:
    "If for some reason you can't use the GPIO pins of the Raspberry Pi, you could connect the radio to a arduino with the GatewaySerial sketch and feed the pi through a serial port:"
    So I assumed the serial gateway is the same I already use...
    So, where do I get directions to config a serial gateway with the radio attached to the GPIO?
    marceloaqno
    Code Contributor
    @OliverDog Which controller are you using(or are planning to use)?
    OliverDogO 1 Reply Last reply
    • Erik TammingaE Erik Tamminga
      Can I use pin 18 (GPIO 24) on my RPi3 for IRQ usage? Should I?
      If I compile with --my-rf24-irq-pin=18, no date is received when the gateway starts.
      I Cannot use pin 15 because that pin is covered by my Z-wave.me board.
      Regards,
      Erik
      marceloaqno
      Code Contributor
      @Erik-Tamminga Some pins may have some restrictions, I couldn't find any good info about that. Try using another pin (GPIO 25).
      • M marceloaqno
        OliverDogO
        OliverDogO
        OliverDog
        @marceloaqno I already use Home Assistant with a Serial Gateway connected on pi USB.
          marceloaqno
          Code Contributor
          @OliverDog Home Assistant supports ethernet gateways, I recommend you go with that.
          ./configure --my-gateway=ethernet --my-transport=nrf24
          (The default settings is to use ethernet and nrf24, so you could omit them)
          and add to it any of your custom options.
          • MadhiasM
            MadhiasM
            Madhias
            wrote on last edited by Madhias
            #347
            I have a question regarding the --my-serial-groupname option: since I start the gateway under an user account with sudo, the gateway device ([EDIT] symlink) will be created with ownership root:root. Shouldn't it be created with root:dialout (as I chose dialout as group in my case)?
            [DELETED]
            • MadhiasM Madhias
              [DELETED]
              marceloaqno
              Code Contributor
              @Madhias /dev/pts/2 it's the one who holds the specified group ownership
              MadhiasM 1 Reply Last reply
              • M marceloaqno
                MadhiasM
                MadhiasM
                Madhias
                @marceloaqno OK, many thanks for that hint!
                I was wrong from the beginning on, since I thought my configuration for the gateway was correct because of --my-serial-groupname=dialout - but that was not compiled. I edited now the mysgw.cpp manually (there was tty instead of dialout; and of course there was all the time the warning when compiling...). Now it works! Without chmod, or chowning anything later!
                  macvictor
                  @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
                  Gateway:
                  2. make
                  3. sudo make install
                  10. sudo mysgw --gen-aes-key
                  Node:
                  #define USE_SOFT_SIGNING
                  #define STORE_SOFT_KEY
                  #define USER_SOFT_KEY
                  #define STORE_SOFT_SERIAL
                  #define STORE_AES_KEY
                  #define USER_AES_KEY
                  EEPROM configuration:
                  // Enable NRF24L01 radio type
                  // Select soft signing
                  #define MY_SIGNING_SOFT
                  // Enable node whitelisting
                  #define MY_REPEATER_FEATURE
                  #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
                  #define CHILD_ID 1      // Id of the sensor child
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  Bounce debouncer = Bounce();
                  int oldValue = 0;
                  bool state;
                    // Setup the button
                    pinMode(BUTTON_PIN, INPUT);
                    // Activate internal pull-up
                    debouncer.attach(BUTTON_PIN);
                    debouncer.interval(5);
                    pinMode(RELAY_PIN, OUTPUT);
                    state = loadState(CHILD_ID);
                    digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
                  void presentation()  {
                    debouncer.update();
                    // Get the update value
                    int value = debouncer.read();
                  //  oldValue = value;
                    delay(5000);
                    if (message.isAck()) {
                      // Change relay state
                      state = message.getBool();
                      // Store state in eeprom
                  4 TSM:INIT
                  5 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  13 TSF:SID:OK,ID=105
                  15 TSM:FPAR
                  2065 !TSM:FPAR:NO REPLY
                  2067 TSM:FPAR
                  4117 !TSM:FPAR:NO REPLY
                  4119 TSM:FPAR
                  6169 !TSM:FPAR:NO REPLY
                  6171 TSM:FPAR
                  8221 !TSM:FPAR:FAIL
                  8222 TSM:FAIL:CNT=1
                  8224 TSM:FAIL:PDT
                  and in gateway i see:
                  sudo mysgw -d
                  mysgw: Starting gateway...
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: TSM:INIT:TSP OK
                  mysgw: TSM:INIT:GW MODE
                  mysgw: MCO:REG:NOT NEEDED
                  mysgw: MCO:BGN:STP
                  mysgw: MCO:BGN:INIT OK,TSP=1
                  mysgw: connected to 127.0.0.1
                  mysgw: MQTT connected
                  mysgw: !TSF:MSG:PVER,3=2
                  mysgw: !TSF:MSG:PVER,1=2
                  mysgw: TSF:MSG:REL MSG
                  mysgw: !TSF:RTE:240 UNKNOWN
                  mysgw: !TSF:MSG:PVER,0=2
                  mysgw: !TSF:RTE:233 UNKNOWN
                  mysgw: !TSF:RTE:51 UNKNOWN
                  Where is problem?
                  M pepsonP rajeev2301R 5 Replies Last reply
                  • M macvictor
                    Gateway:
                    2. make
                    Node:
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValue = 0;
                    bool state;
                      // Setup the button
                      debouncer.update();
                      delay(5000);
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    11 TSM:INIT:TSP OK
                    15 TSM:FPAR
                    2067 TSM:FPAR
                    4119 TSM:FPAR
                    6171 TSM:FPAR
                    8221 !TSM:FPAR:FAIL
                    8222 TSM:FAIL:CNT=1
                    8224 TSM:FAIL:PDT
                    sudo mysgw -d
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    Where is problem?
                    marceloaqno
                    Code Contributor
                    @macvictor Did you also enable encryption on your node? (#define MY_RF24_ENABLE_ENCRYPTION)
                      macvictor
                      @marceloaqno Thanks for help :+1: This was my problem 😀
                        how do I set user and password to access the mqtt broker? I tried do add --my-mqtt-password=PASS --my-mqtt-user=USER other parameters but they get ignored
                          macvictor
                          @gohan edit configure file and add this code:
                          --my-mqtt-user=*)
                              CPPFLAGS="-DMY_MQTT_USER=\\\"${optarg}\\\" $CPPFLAGS"
                          --my-mqtt-password=*)
                              CPPFLAGS="-DMY_MQTT_PASSWORD=\\\"${optarg}\\\" $CPPFLAGS"
                          after this code:
                          --my-signing-request-gw-signatures-from-all*)
                                  signing_request_signatures=true
                                  CPPFLAGS="-DMY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL $CPPFLAGS"
                          this is about 408 number line and use flag --my-mqtt-password and --my-mqtt-client-id when you run configure, thats all. =)
                          blaceyB gohanG 2 Replies Last reply
                          • M macvictor
                            --my-mqtt-user=*)
                            after this code:
                            blaceyB
                            blaceyB
                            blacey
                            wrote on last edited by blacey
                            #355
                            @macvictor It would be great if you would submit this as a GitHub Pull Request. If you aren't comfortable with that, then I would encourage you to at least open a MySensors issue to add these RPI configuration options.
                            • TeknorT
                              TeknorT
                              Teknor
                              wrote on last edited by Teknor
                              #356
                              When using RPI as a GW for MySensors, the CPU load increases from 18% to around 80 %. I am using a RPI II model B. I'd love the have the GW running on the Raspberry, and avoid a USB connected Arduino.
                              Does somebody else experience the same?
                              M carlylerC 2 Replies Last reply
                              • TeknorT Teknor
                                macvictor
                                @Teknor I use RPI III as GW and all node connect with gw used nRF24L01. My CPU now usage 5-10%, but I installed "Home Assistance" + homebridge + some plugins.
                                TeknorT 1 Reply Last reply
                                • M macvictor
                                  TeknorT
                                  TeknorT
                                  Teknor
                                  #358
                                  @macvictor Thanks. My RPI 2 is running Domoticz, RFXcom GW and 2x 3MP cameras with motion detection using Motioneye. Might be something wrong with my MySensors GW setup...
                                  • TeknorT Teknor
                                    carlylerC
                                    carlylerC
                                    carlyler
                                    @Teknor I tend to agree something is wrong, but I think it really on depends how many nodes and how often you're sending data.
                                    rpi3 + GPIO nrf24l01 + openhab2 + 8 nodes + packet received, on average 1 / 5s :
                                    top - 06:29:37 up 2 days, 22:33,  2 users,  load average: 0.26, 0.24, 0.19
                                    KiB Mem:    947732 total,   903420 used,    44312 free,   175364 buffers
                                    KiB Swap:   102396 total,     4496 used,    97900 free.   391360 cached Mem
                                      681 root      20   0  208840  56532  23684 S   8.9  6.0 214:23.60 Xorg
                                      527 root      20   0   39448  21532  11264 S   4.3  2.3  69:34.28 vncserver-x11-c
                                     1154 pi        20   0   50548  17628  12196 S   3.0  1.9  64:05.96 lxterminal
                                    30426 openhab   20   0  441764 197592  14960 S   1.6 20.8 284:18.70 java
                                     2467 root      20   0   20024   2456   2300 S   1.3  0.3  62:55.17 mysgw
                                    25634 root      20   0       0      0      0 S   1.0  0.0   0:00.21 kworker/u8:0
                                      688 root      20   0   13720   9432   8828 S   0.7  1.0   2:04.96 vncagent
                                    25855 pi        20   0    5232   2584   2140 R   0.7  0.3   0:00.49 top
                                        7 root      20   0       0      0      0 S   0.3  0.0   9:15.35 rcu_sched
                                       78 root     -51   0       0      0      0 S   0.3  0.0   5:16.50 irq/92-mmc1
                                      967 pi        20   0   95656  17716  12028 S   0.3  1.9   6:41.87 lxpanel
                                        1 root      20   0   24620   4688   2716 S   0.0  0.5   0:13.08 systemd
                                        2 root      20   0       0      0      0 S   0.0  0.0   0:00.27 kthreadd
                                    • M macvictor
                                      --my-mqtt-user=*)
                                      after this code:
                                      @macvictor
                                      That worked, thanks. But to configure channel, power, AES key, and so on, do you think it is better to use command line like you posted above or customize myconfig.h?
                                        @macvictor
                                        marceloaqno
                                        Code Contributor
                                        @gohan You can also set mqtt username and password in examples_linux/mysgw.cpp
                                        gohanG 1 Reply Last reply
                                        • M marceloaqno
                                          @marceloaqno
                                          I'm trying to understand where is the best place to avoid file gets overwritten in case of upgrades
