max6675 + Thermo
sorry my english is not good.
link text
My Hardware
Ardunion nano + max6675 + ThermoelementBlease Help
lg
Wolfgang#include <max6675.h> #include <MyConfig.h> #include <MySensors.h> #include <SPI.h> uint8_t CS0 = 9; // CS pin on MAX6675 uint8_t SO = 8; // SO pin of MAX6675 uint8_t SCLK = 10; // SCK pin of MAX6675 uint8_t units = 1; // Units to readout temp (0 = ˚F, 1 = ˚C) float temperature = 0.0; // Temperature output variable float lastTemperature; unsigned long SLEEP_TIME = 30000; boolean metric = true; MySensor gw; MyMessage msg(0,V_TEMP); // Initialize the MAX6675 Library for our chip MAX6675 temp0(CS0,SO,SCLK,units); void setup() { // Startup and initialize MySensors library. Set callback for incoming messages. gw.begin(); // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Max6675 Temperature Sensor", "1.0"); // Present all sensors to controller gw.present(0, S_TEMP); Serial.begin(115200); } void loop() { // Process incoming messages (like config from server) gw.process(); temperature = temp0.read_temp(); // Read the temp if(temperature == -1) { // If there is an error with the TC, temperature will be -1 Serial.println("Thermocouple Error!!"); // Temperature is -1 and there is a thermocouple error } else { Serial.print("Current Temperature: "); Serial.println( temperature ); // Print the temperature to Serial if (temperature!=lastTemperature) gw.send(msg.setSensor(0).set(temperature,1)); lastTemperature=temperature; } gw.sleep(SLEEP_TIME); }``` upload error MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.MySensors.h
/* * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. */ /** * @file MySensors.h * * MySensors main interface (includes all necessary code for the library) */ #ifndef MySensors_h #define MySensors_h #include "core/MySensorsCore.h" // Detect node type /** * @def MY_GATEWAY_FEATURE * @brief Is set for gateway sketches. */ /** * @def MY_IS_GATEWAY * @brief Is true when @ref MY_GATEWAY_FEATURE is set. */ /** * @def MY_NODE_TYPE * @brief Contain a string describing the class of sketch/node (gateway/repeater/sensor). */ #if defined(MY_GATEWAY_SERIAL) || defined(MY_GATEWAY_W5100) || defined(MY_GATEWAY_ENC28J60) || defined(MY_GATEWAY_ESP8266) || defined(MY_GATEWAY_LINUX) || defined(MY_GATEWAY_MQTT_CLIENT) #define MY_GATEWAY_FEATURE #define MY_IS_GATEWAY (true) #define MY_NODE_TYPE "GW" #elif defined(MY_REPEATER_FEATURE) #define MY_IS_GATEWAY (false) #define MY_NODE_TYPE "REPEATER" #else #define MY_IS_GATEWAY (false) #define MY_NODE_TYPE "NODE" #endif // Enable radio "feature" if one of the radio types was enabled #if defined(MY_RADIO_NRF24) || defined(MY_RADIO_RFM69) || defined(MY_RADIO_RFM95) || defined(MY_RS485) #define MY_SENSOR_NETWORK #endif // HARDWARE #if defined(ARDUINO_ARCH_ESP8266) #include "core/MyHwESP8266.cpp" #elif defined(ARDUINO_ARCH_AVR) #include "drivers/AVR/DigitalWriteFast/digitalWriteFast.h" #include "core/MyHwAVR.cpp" #elif defined(ARDUINO_ARCH_SAMD) #include "core/MyHwSAMD.cpp" #elif defined(__linux__) #include "core/MyHwLinuxGeneric.cpp" #endif // LEDS #if !defined(MY_DEFAULT_ERR_LED_PIN) && defined(MY_HW_ERR_LED_PIN) #define MY_DEFAULT_ERR_LED_PIN MY_HW_ERR_LED_PIN #endif #if !defined(MY_DEFAULT_TX_LED_PIN) && defined(MY_HW_TX_LED_PIN) #define MY_DEFAULT_TX_LED_PIN MY_HW_TX_LED_PIN #endif #if !defined(MY_DEFAULT_RX_LED_PIN) && defined(MY_HW_TX_LED_PIN) #define MY_DEFAULT_RX_LED_PIN MY_HW_TX_LED_PIN #endif #if defined(MY_LEDS_BLINKING_FEATURE) #error MY_LEDS_BLINKING_FEATURE is now removed from MySensors core,\ define MY_DEFAULT_ERR_LED_PIN, MY_DEFAULT_TX_LED_PIN or\ MY_DEFAULT_RX_LED_PIN in your sketch instead to enable LEDs #endif /** * @def MY_DEFAULT_LED_BLINK_PERIOD * @brief Default LEDs blinking period in milliseconds. */ #ifndef MY_DEFAULT_LED_BLINK_PERIOD #define MY_DEFAULT_LED_BLINK_PERIOD 300 #endif #if defined(MY_DEFAULT_RX_LED_PIN) || defined(MY_DEFAULT_TX_LED_PIN) || defined(MY_DEFAULT_ERR_LED_PIN) #include "core/MyLeds.cpp" #else #include "core/MyLeds.h" #endif #include "core/MyIndication.cpp" // INCLUSION MODE #if defined(MY_INCLUSION_MODE_FEATURE) #include "core/MyInclusionMode.cpp" #endif // SIGNING #if defined(MY_SIGNING_ATSHA204) || defined(MY_SIGNING_SOFT) #define MY_SIGNING_FEATURE #endif #include "core/MySigning.cpp" #include "drivers/ATSHA204/sha256.cpp" #if defined(MY_SIGNING_FEATURE) // SIGNING COMMON FUNCTIONS #if defined(MY_SIGNING_ATSHA204) && defined(MY_SIGNING_SOFT) #error Only one signing engine can be activated #endif #if defined(MY_SIGNING_ATSHA204) && defined(__linux__) #error No support for ATSHA204 on this platform #endif #if defined(MY_SIGNING_ATSHA204) #include "core/MySigningAtsha204.cpp" #include "drivers/ATSHA204/ATSHA204.cpp" #elif defined(MY_SIGNING_SOFT) #include "core/MySigningAtsha204Soft.cpp" #endif #endif // FLASH #if defined(MY_OTA_FIRMWARE_FEATURE) #include "drivers/SPIFlash/SPIFlash.cpp" #include "core/MyOTAFirmwareUpdate.cpp" #endif // GATEWAY - TRANSPORT #if defined(MY_CONTROLLER_IP_ADDRESS) || defined(MY_CONTROLLER_URL_ADDRESS) #define MY_GATEWAY_CLIENT_MODE #endif #if defined(MY_USE_UDP) && !defined(MY_GATEWAY_CLIENT_MODE) #error You must specify MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS for UDP #endif #if defined(MY_GATEWAY_MQTT_CLIENT) #if defined(MY_SENSOR_NETWORK) // We assume that a gateway having a radio also should act as repeater #define MY_REPEATER_FEATURE #endif // GATEWAY - COMMON FUNCTIONS // We support MQTT Client using W5100, ESP8266 and Linux #if !defined(MY_GATEWAY_CLIENT_MODE) #error You must specify MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS #endif #if !defined(MY_MQTT_PUBLISH_TOPIC_PREFIX) #error You must specify a topic publish prefix MY_MQTT_PUBLISH_TOPIC_PREFIX for this MQTT client #endif #if !defined(MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) #error You must specify a topic subscribe prefix MY_MQTT_SUBSCRIBE_TOPIC_PREFIX for this MQTT client #endif #if !defined(MY_MQTT_CLIENT_ID) #error You must define a unique MY_MQTT_CLIENT_ID for this MQTT client #endif #include "core/MyGatewayTransport.cpp" #include "core/MyProtocolMySensors.cpp" #if defined(MY_GATEWAY_LINUX) #include "drivers/Linux/EthernetClient.h" #include "drivers/Linux/EthernetServer.h" #include "drivers/Linux/IPAddress.h" #endif #include "drivers/PubSubClient/PubSubClient.cpp" #include "core/MyGatewayTransportMQTTClient.cpp" #elif defined(MY_GATEWAY_FEATURE) // GATEWAY - COMMON FUNCTIONS #include "core/MyGatewayTransport.cpp" #include "core/MyProtocolMySensors.cpp" // GATEWAY - CONFIGURATION #if defined(MY_SENSOR_NETWORK) // We assume that a gateway having a radio also should act as repeater #define MY_REPEATER_FEATURE #endif #if !defined(MY_PORT) #error You must define MY_PORT (controller or gatway port to open) #endif #if defined(MY_GATEWAY_ESP8266) // GATEWAY - ESP8266 #include "core/MyGatewayTransportEthernet.cpp" #elif defined(MY_GATEWAY_LINUX) // GATEWAY - Generic Linux #include "drivers/Linux/EthernetClient.h" #include "drivers/Linux/EthernetServer.h" #include "drivers/Linux/IPAddress.h" #include "core/MyGatewayTransportEthernet.cpp" #elif defined(MY_GATEWAY_W5100) // GATEWAY - W5100 #include "core/MyGatewayTransportEthernet.cpp" #elif defined(MY_GATEWAY_ENC28J60) // GATEWAY - ENC28J60 #if defined(MY_USE_UDP) #error UDP mode is not available for ENC28J60 #endif #include "core/MyGatewayTransportEthernet.cpp" #elif defined(MY_GATEWAY_SERIAL) // GATEWAY - SERIAL #include "core/MyGatewayTransportSerial.cpp" #endif #endif // RAM ROUTING TABLE #if defined(MY_RAM_ROUTING_TABLE_FEATURE) && defined(MY_REPEATER_FEATURE) // activate feature based on architecture #if defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_SAMD) || defined(LINUX_ARCH_RASPBERRYPI) #define MY_RAM_ROUTING_TABLE_ENABLED #elif defined(ARDUINO_ARCH_AVR) // memory limited, enable with care // #define MY_RAM_ROUTING_TABLE_ENABLED #endif #endif #if defined(MY_REPEATER_FEATURE) #define MY_TRANSPORT_SANITY_CHECK #endif #if defined(MY_TRANSPORT_DONT_CARE_MODE) #error This directive is deprecated, set MY_TRANSPORT_WAIT_READY_MS instead! #endif // RADIO #if defined(MY_RADIO_NRF24) || defined(MY_RADIO_RFM69) || defined(MY_RADIO_RFM95) ||defined(MY_RS485) // SOFTSPI #ifdef MY_SOFTSPI #if defined(ARDUINO_ARCH_ESP8266) #error Soft SPI is not available on ESP8266 #endif #include "drivers/AVR/DigitalIO/DigitalIO.h" #endif #if defined(MY_RADIO_NRF24) && defined(__linux__) && !(defined(LINUX_SPI_BCM) || defined(LINUX_SPI_SPIDEV)) #error No support for nRF24 radio on this platform #endif #include "core/MyTransport.cpp" // count enabled transports #if defined(MY_RADIO_NRF24) #define __RF24CNT 1 #else #define __RF24CNT 0 #endif #if defined(MY_RADIO_RFM69) #define __RFM69CNT 1 #else #define __RFM69CNT 0 #endif #if defined(MY_RADIO_RFM95) #define __RFM95CNT 1 #else #define __RFM95CNT 0 #endif #if defined(MY_RS485) #define __RS485CNT 1 #else #define __RS485CNT 0 #endif #if (__RF24CNT + __RFM69CNT + __RFM95CNT + __RS485CNT > 1) #error Only one forward link driver can be activated #endif #if defined(MY_RADIO_NRF24) #if defined(MY_RF24_ENABLE_ENCRYPTION) #include "drivers/AES/AES.cpp" #endif #include "drivers/RF24/RF24.cpp" #include "core/MyTransportNRF24.cpp" #elif defined(MY_RS485) #if !defined(MY_RS485_HWSERIAL) #if defined(__linux__) #error You must specify MY_RS485_HWSERIAL for RS485 transport #endif #include "drivers/AltSoftSerial/AltSoftSerial.cpp" #endif #include "core/MyTransportRS485.cpp" #elif defined(MY_RADIO_RFM69) #include "drivers/RFM69/RFM69.cpp" #include "core/MyTransportRFM69.cpp" #elif defined(MY_RADIO_RFM95) #include "drivers/RFM95/RFM95.cpp" #include "core/MyTransportRFM95.cpp" #endif #endif #if defined(MY_PARENT_NODE_IS_STATIC) && (MY_PARENT_NODE_ID == AUTO) #error Parent is static but no parent ID defined. #endif // Make sure to disable child features when parent feature is disabled #if !defined(MY_SENSOR_NETWORK) #undef MY_OTA_FIRMWARE_FEATURE #undef MY_REPEATER_FEATURE #undef MY_SIGNING_NODE_WHITELISTING #undef MY_SIGNING_FEATURE #endif #if !defined(MY_GATEWAY_FEATURE) #undef MY_INCLUSION_MODE_FEATURE #undef MY_INCLUSION_BUTTON_FEATURE #endif #if !defined(MY_CORE_ONLY) #if !defined(MY_GATEWAY_FEATURE) && !defined(MY_SENSOR_NETWORK) #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless. #endif #endif #include "core/MyCapabilities.h" #include "core/MyMessage.cpp" #include "core/MySensorsCore.cpp" #include <Arduino.h> #if !defined(MY_CORE_ONLY) #if defined(ARDUINO_ARCH_ESP8266) #include "core/MyMainESP8266.cpp" #elif defined(__linux__) #include "core/MyMainLinux.cpp" #else #include "core/MyMainDefault.cpp" #endif #endif #endif // Doxygen specific constructs, not included when built normally // This is used to enable disabled macros/definitions to be included in the documentation as well. #if DOXYGEN #define MY_GATEWAY_FEATURE #define MY_LEDS_BLINKING_FEATURE //!< \deprecated use MY_DEFAULT_RX_LED_PIN, MY_DEFAULT_TX_LED_PIN and/or MY_DEFAULT_ERR_LED_PIN instead **** DEPRECATED, DO NOT USE **** #endif``` -
