  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • wendanW
    wendanW
    wendan
    I get the feeling it is possible to use more then one sensor parallel on port 3. I wonder if each sensor is being monitored? Am I right and do I need to alter or change something?
    • wendanW
      wendanW
      wendan
      my feeling was right.... i just connected 5 temp censors it is working great
      • J
        J
        Joseph Absher
        wrote on last edited by Joseph Absher
        #29
        I am getting the error:
        DallasTemperatureSensor.ino: In function 'void loop()':
        DallasTemperatureSensor:93: error: 'getConfig' was not declared in this scope
             float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        Does anyone have any suggestions?
        • J Joseph Absher
          @Joseph-Absher https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed
          • J
            J
            Joseph Absher
            @mfalkvidd That worked. Thanks.
            • Vincent LgrdV
              Vincent LgrdV
              Vincent Lgrd
              I'm a beginner in home automation and I'm trying MySensor for the first time. My acctual configaration is a Domoticz on a Raspberry Pi 2B and a RFLink GW with a NRF24L01 module to try to measure with a MySensor probe.
              I've building a temperature sensor with a DS18B20 sensor on a Official Arduino nano board and I can not run the sensor correctly.
              The arduino serial monitor show these:
              3 TSM:INIT
              4 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              12 TSM:FPAR
              15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              2022 !TSM:FPAR:NO REPLY
              2024 TSM:FPAR
              2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              4034 !TSM:FPAR:NO REPLY
              4036 TSM:FPAR
              4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              6046 !TSM:FPAR:NO REPLY
              6048 TSM:FPAR
              6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              8058 !TSM:FPAR:FAIL
              8059 TSM:FAIL:CNT=1
              8061 TSM:FAIL:PDT
              Someone could help me?
                Did you set node ID?
                • Vincent LgrdV
                  Vincent LgrdV
                  Vincent Lgrd
                  Where should I put it? In arduino sensor code?
                    Yes, it's like #define MY_NODE_ID 2 and put it at beginning of the code
                    • Vincent LgrdV
                      Vincent LgrdV
                      Vincent Lgrd
                      Ok , with Node ID, I have this:
                      3 MCO:BGN:BFR
                      63 TSM:INIT
                      64 TSF:WUR:MS=0
                      71 TSM:INIT:TSP OK
                      73 TSM:INIT:STATID=2
                      75 TSF:SID:OK,ID=2
                      76 TSM:FPAR
                      113 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2120 !TSM:FPAR:NO REPLY
                      2122 TSM:FPAR
                      2158 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      4166 !TSM:FPAR:NO REPLY
                      4168 TSM:FPAR
                      4204 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      6212 !TSM:FPAR:NO REPLY
                      6214 TSM:FPAR
                      6250 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      8258 !TSM:FPAR:FAIL
                      8259 TSM:FAIL:CNT=1
                        ok, but we are going off topic since now your problem seems to be the radios can't talk to each other, so if you take a look in troubleshooting section you will see others having this error that usually if bad wiring, missing capacitor on vcc of the nrf24, range/interference problem. How far are the 2 radio modules? Try putting them 2-3 meters apart.
                        • Vincent LgrdV
                          Vincent LgrdV
                          Vincent Lgrd
                          Thanks, my radio modules are very close, they are on the same table for test. On of them may be damaged, I must receive others. I'm going in the troubleshooting section to avoid polluting this article.
                          Thanks for your help
                            Put them at least 2 meters apart, just to play safe.
                            • Vincent LgrdV
                              Vincent LgrdV
                              Vincent Lgrd
                              It's the same, I've even reversed the radio modules
                              • D
                                dantefff
                                @gohan , I'm in the same situation as @Vincent-Lgrd. I'm powering my arduino UNO from usb (to test). Is that a possible problem?
                                  I use USB pretty much all the time and never had any issue. I had many problems in the beginning with radio modules that had the black blob instead of the ic and once I got the new ones everything started to work. I'm still working on increasing the range, probably because they are clones and not good quality.
                                  D 1 Reply Last reply
                                    dantefff
                                    @gohan I changed my getaway to an old good rpi model b, and the temperature node started to work, so I think that the problem was on de getaway wiring or in the getaway code itsef. Thanks
                                    • G
                                      G
                                      gewoonandre
                                      Is it also possible to upload the example code to a Arduino Nano, and connect it via USB to a Windows PC with Domoticz?
                                      Or will it only work with the radio modules (and extra gateway?)
                                        I think you can use the serial gateway sketch and the sensor code in setup and loop
                                        • C
                                          C
                                          CurtisMack
                                          Thank you for posting this project!
                                          Could like to suggest a small change to the sketch. There are several posts out there about this not running with the latest DallasTemperature library. The call to sensors.millisToWaitForConversion won't compile because the method is not public. From another post I learned that this method is very simple and could be included in the sketch. I would suggest changing the line
                                          to read
                                          int16_t conversionTime = millisToWaitForConversion(sensors.getResolution());
                                          and add this function to the sketch:
                                          int16_t millisToWaitForConversion(uint8_t bitResolution)
                                          switch (bitResolution)
                                          case 9:
                                          return 94;
                                          case 10:
                                          return 188;
                                          case 11:
                                          return 375;
                                          default:
                                          return 750;
                                          In any case, this might help the next person using this project.
