  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • Vincent LgrdV
    Vincent LgrdV
    Vincent Lgrd
    I'm a beginner in home automation and I'm trying MySensor for the first time. My acctual configaration is a Domoticz on a Raspberry Pi 2B and a RFLink GW with a NRF24L01 module to try to measure with a MySensor probe.
    I've building a temperature sensor with a DS18B20 sensor on a Official Arduino nano board and I can not run the sensor correctly.
    The arduino serial monitor show these:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    12 TSM:FPAR
    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2022 !TSM:FPAR:NO REPLY
    2024 TSM:FPAR
    2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4034 !TSM:FPAR:NO REPLY
    4036 TSM:FPAR
    4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6046 !TSM:FPAR:NO REPLY
    6048 TSM:FPAR
    6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8058 !TSM:FPAR:FAIL
    8059 TSM:FAIL:CNT=1
    8061 TSM:FAIL:PDT
    Someone could help me?
      Did you set node ID?
      • Vincent LgrdV
        Vincent LgrdV
        Vincent Lgrd
        Where should I put it? In arduino sensor code?
          Yes, it's like #define MY_NODE_ID 2 and put it at beginning of the code
          • Vincent LgrdV
            Vincent LgrdV
            Vincent Lgrd
            Ok , with Node ID, I have this:
            3 MCO:BGN:BFR
            63 TSM:INIT
            64 TSF:WUR:MS=0
            71 TSM:INIT:TSP OK
            73 TSM:INIT:STATID=2
            75 TSF:SID:OK,ID=2
            76 TSM:FPAR
            113 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2120 !TSM:FPAR:NO REPLY
            2122 TSM:FPAR
            2158 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4166 !TSM:FPAR:NO REPLY
            4168 TSM:FPAR
            4204 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6212 !TSM:FPAR:NO REPLY
            6214 TSM:FPAR
            6250 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8258 !TSM:FPAR:FAIL
            8259 TSM:FAIL:CNT=1
              ok, but we are going off topic since now your problem seems to be the radios can't talk to each other, so if you take a look in troubleshooting section you will see others having this error that usually if bad wiring, missing capacitor on vcc of the nrf24, range/interference problem. How far are the 2 radio modules? Try putting them 2-3 meters apart.
              • Vincent LgrdV
                Vincent LgrdV
                Vincent Lgrd
                Thanks, my radio modules are very close, they are on the same table for test. On of them may be damaged, I must receive others. I'm going in the troubleshooting section to avoid polluting this article.
                Thanks for your help
                  Put them at least 2 meters apart, just to play safe.
                  • Vincent LgrdV
                    Vincent LgrdV
                    Vincent Lgrd
                    It's the same, I've even reversed the radio modules
                    • D
                      dantefff
                      @gohan , I'm in the same situation as @Vincent-Lgrd. I'm powering my arduino UNO from usb (to test). Is that a possible problem?
                        I use USB pretty much all the time and never had any issue. I had many problems in the beginning with radio modules that had the black blob instead of the ic and once I got the new ones everything started to work. I'm still working on increasing the range, probably because they are clones and not good quality.
                        D 1 Reply Last reply
                          dantefff
                          @gohan I changed my getaway to an old good rpi model b, and the temperature node started to work, so I think that the problem was on de getaway wiring or in the getaway code itsef. Thanks
                          • G
                            G
                            gewoonandre
                            Is it also possible to upload the example code to a Arduino Nano, and connect it via USB to a Windows PC with Domoticz?
                            Or will it only work with the radio modules (and extra gateway?)
                              I think you can use the serial gateway sketch and the sensor code in setup and loop
                              • C
                                C
                                CurtisMack
                                Thank you for posting this project!
                                Could like to suggest a small change to the sketch. There are several posts out there about this not running with the latest DallasTemperature library. The call to sensors.millisToWaitForConversion won't compile because the method is not public. From another post I learned that this method is very simple and could be included in the sketch. I would suggest changing the line
                                to read
                                int16_t conversionTime = millisToWaitForConversion(sensors.getResolution());
                                and add this function to the sketch:
                                int16_t millisToWaitForConversion(uint8_t bitResolution)
                                switch (bitResolution)
                                case 9:
                                return 94;
                                case 10:
                                return 188;
                                case 11:
                                return 375;
                                default:
                                return 750;
                                In any case, this might help the next person using this project.
                                • WoekaW
                                  WoekaW
                                  Woeka
                                  I had some problems with Domoticz triggering an event based on a certain temperature. When using multiple DS18B20 it is a good idea to use the ID of the sensors to always get the same order of sensors. If one is not read, for example B of A, B, C then C becomes B. See: https://forum.mysensors.org/topic/4143/about-ds18b20-onewire for more info. You maybe need to adjust the sketch a bit for your number of sensors.
                                  • R
                                    R
                                    Rene046
                                    @CurtisMack
                                    could you explain how to solve this ?
                                    I'm no pro, and wanted to use 1 single DS1820 in a sketch and also got same message about :
                                    Mysensors is hard hard nut to learn, specially because of a lot of changes in the newer version 2.1.0 ...(and im still learning to work with arduino software , i keep running often against old sketches i like to try as sample to use them in other sketches , (my way of learning) but than they dont work with latest version. because something changed.
                                    but i love the mysensors functions.
                                    p.s sorry for my bad english....
                                    K 1 Reply Last reply
                                    • R Rene046
                                      @CurtisMack
                                      K
                                      K
                                      kontrollable
                                      @Rene046 The solution is here:https://forum.mysensors.org/topic/4828/temperature-sensor/46
                                      • R
                                        R
                                        Rene046
                                        I sofar got the sketch running and giving good data on serial and into domoticz
                                        i only could use some help with how to sent my Temperature in Celsius to domoticz to
                                        i tried to use:
                                        send(msgTemp.set(insideThermometer ,2));
                                        and
                                        send(msgTemp.set(tempC,2));
                                        both without luck, the first did transmit some data but wrong numbers
                                        second did nothing think because with this i done i does not know what address the DS1820 is on.
                                        Im learning every day something new....
                                        Maybe someone could help,
                                        G 1 Reply Last reply
                                        • R
                                          R
                                          Rene046
                                          forgot the sketch
                                          #include <BH1750.h>
                                          #include <OneWire.h>
                                          // Data wire is plugged into port 3 on the Arduino
                                          #define ONE_WIRE_BUS 3
                                          // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
                                          // Pass our oneWire reference to Dallas Temperature.
                                          // arrays to hold device address
                                          DeviceAddress insideThermometer;
                                          unsigned long SLEEP_TIME = 180000; // Sleep time between reads (in milliseconds)
                                          int SOLAR_SENSE_PIN = A1;  // select the input pin for the solar sense point
                                          #define CHILD_ID_BATTERY 4
                                          #define CHILD_ID_SOLAR 6
                                          #define CHILD_ID_LIGHT 1
                                          #define CHILD_ID_TEMP1 2
                                          BH1750 lightSensor;
                                          int oldBatteryPcnt = 0;
                                          MyMessage msgTemp(CHILD_ID_TEMP1,V_TEMP);
                                          MyMessage msgbatt(CHILD_ID_BATTERY, V_VOLTAGE);
                                          MyMessage msgsolar(CHILD_ID_SOLAR, V_VOLTAGE);
                                          uint16_t lastlux;  //lux
                                          void setup(void)
                                            analogReference(INTERNAL1V1);
                                            analogReference(INTERNAL);
                                            sendSketchInfo("Battery Meter", "2.0");
                                            //Serial.begin(9600); // start serial port
                                            Serial.print("Locating devices..."); // locate devices on the bus
                                            sensors.begin(); // start reading sensor
                                            Serial.print("Found ");
                                            Serial.print(sensors.getDeviceCount(), DEC);
                                            Serial.println(" devices.");
                                            Serial.print("Parasite power is: "); // report parasite power requirements
                                            if (sensors.isParasitePowerMode()) Serial.println("ON");
                                            else Serial.println("OFF");
                                          // assign address manually.  the addresses below will beed to be changed
                                            // to valid device addresses on your bus.  device address can be retrieved
                                            // by using either oneWire.search(deviceAddress) or individually via
                                            // sensors.getAddress(deviceAddress, index)
                                            //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
                                            // Method 1:
                                            // search for devices on the bus and assign based on an index.  ideally,
                                            // you would do this to initially discover addresses on the bus and then
                                            // use those addresses and manually assign them (see above) once you know
                                            // the devices on your bus (and assuming they don't change).
                                            if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
                                            // method 2: search()
                                            // search() looks for the next device. Returns 1 if a new address has been
                                            // returned. A zero might mean that the bus is shorted, there are no devices,
                                            // or you have already retrieved all of them.  It might be a good idea to
                                            // check the CRC to make sure you didn't get garbage.  The order is
                                            // deterministic. You will always get the same devices in the same order
                                            // Must be called before search()
                                            //oneWire.reset_search();
                                            // assigns the first address found to insideThermometer
                                            //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
                                            // show the addresses we found on the bus
                                            Serial.print("Device 0 Address: ");
                                            printAddress(insideThermometer);
                                            Serial.println();
                                            // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
                                            sensors.setResolution(insideThermometer, 9);
                                            Serial.print("Device 0 Resolution: ");
                                            Serial.print(sensors.getResolution(insideThermometer), DEC);
                                            Serial.println();
                                          // function to print the temperature for a device
                                          void printTemperature(DeviceAddress deviceAddress)
                                            // method 1 - slower
                                            //Serial.print("Temp C: ");
                                            //Serial.print(sensors.getTempC(deviceAddress));
                                            //Serial.print(" Temp F: ");
                                            //Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
                                            // method 2 - faster
                                            float tempC = sensors.getTempC(deviceAddress);
                                            Serial.print(tempC);
                                            Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
                                          void loop(void)
                                            // call sensors.requestTemperatures() to issue a global temperature
                                            // request to all devices on the bus
                                            Serial.print("Requesting temperatures...");
                                            sensors.requestTemperatures(); // Send the command to get temperatures
                                            Serial.println("DONE");
                                            // It responds almost immediately. Let's print out the data
                                            printTemperature(insideThermometer); // Use a simple function to print out the data
                                           // get the battery Voltage
                                            int sensorValue2 = analogRead(BATTERY_SENSE_PIN);
                                            delay(1000);
                                            int sensorValue1 = analogRead(BATTERY_SENSE_PIN);
                                            delay(100);
                                            delay(1000);
                                            int sensorValueS = analogRead(SOLAR_SENSE_PIN);
                                            delay(1000);
                                          #ifdef MY_DEBUG
                                            Serial.print("Battery Voltage2: ");
                                            Serial.println(sensorValue2);
                                            Serial.print("Battery Voltage1: ");
                                            Serial.println(sensorValue1);
                                            Serial.println(sensorValue);
                                            Serial.print("Solar Voltage: ");
                                            Serial.println(sensorValueS);
                                            const float vRef = 4.200/ 1.05/ 1023 ;
                                            float batteryV  = sensorValue * 0.0042598 ; // 0.0038952294568380753114792412093 max 4,2 volt
                                            float batteryS  = sensorValueS * 0.0102459 ; // 0.0038952294568380753114792412093 max 10 volt
                                          #ifdef MY_DEBUG
                                            Serial.print(batteryV);
                                            Serial.println(" V");
                                          send(msgbatt.set(batteryV ,2));
                                            Serial.print(batteryS);
                                          send(msgsolar.set(batteryS ,2));
                                            Serial.print(batteryPcnt);
                                            Serial.println(" %");
                                              // Power up radio after sleep
                                              oldBatteryPcnt = batteryPcnt;
                                            Serial.println(lux);
                                            if (lux != lastlux) {
                                                send(msg.set(lux));
                                                lastlux = lux;
                                            sleep(SLEEP_TIME);
                                          // function to print a device address
                                          void printAddress(DeviceAddress deviceAddress)
                                            for (uint8_t i = 0; i < 8; i++)
                                              if (deviceAddress[i] < 16) Serial.print("0");
                                              Serial.print(deviceAddress[i], HEX);
                                          C 1 Reply Last reply
