  2. Bug Reports
  3. [Solved] Strange behavior of RFM69 OTA burning firmware after some research
19 Posts 5 Posters 7.2k Views 3 Watching
  • Y
    Y
    yury
    I will reproduce tonight. with MYSController log.
    tekkaT 1 Reply Last reply
    • Y yury
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @yury Please try with this, I've quickly added a check:
      ~~https://github.com/tekka007/MySensors/tree/OTAUpdate~~
      ~~PR: https://github.com/mysensors/MySensors/pull/718~~
      Edit: PR merged, try with the latest development: https://github.com/mysensors/MySensors/tree/development
      Y 1 Reply Last reply
      • tekkaT tekka
        Y
        Y
        yury
        @tekka
        with your new PR updated all works good now. I could not replicate @ 40 ms in retryWaitTime the mentioned above. so I put 10 ms like a stress test. It has survived! with lots of WRONG FWB but with CRC OK!
        the logs
        serial
        https://drive.google.com/open?id=0B11zpaGZaUo5c3NMT1VuSGoxU3c
        last OTA is correspoding to serial log
        https://drive.google.com/open?id=0B11zpaGZaUo5MVh2cUg2cWMxWER0aHEwWHhoY1VidEpuOURn
        • KoreshK
          KoreshK
          Koresh
          Just 2 cents... We couldn't replicate 40 ms in retryWaitTime the mentioned above in another location. And tonight Yury couldnt replicate this case at home too. But yesterday it was typical situation. So I can assume it was caused by high environment radio noise (city center with many potential RF sources). I think it is an ideal situation to test boards and improve library stability :wink:
          • KoreshK Koresh
            tekkaT
            tekkaT
            tekka
            @yury @Koresh Thanks for your feedback and thorough analysis, that helped to identify the issue.
            • N
              N
              napo7
              I might be a bit dumb , but I can't find RFM69 OTA bootloader ?
              Has anyone done it ?
                @napo7
                this is sensebender micro bootloader, same as dualoptiboot from lowpowerlab
                https://www.mysensors.org/about/ota
                • N
                  N
                  napo7
                  Ah ah ! I was sure that I was dumb !!
                  I'll have to give a try to port MYSBootLoader to rfm69 so ....
                  • N napo7
                    tekkaT
                    tekkaT
                    tekka
                    @napo7 There is something cooking in the lab...will post more in a bit :)
                    • N
                      N
                      napo7
                      Well, I'll wait a bit, so !
                      BTW :how much is a bit for you ? :laughing:
                      • N napo7
                        tekkaT
                        tekkaT
                        tekka
                        @napo7 Hmm...1/8th of a byte ;) I cannot give you an ETA right now, but feel free to write your own bootloader implementation of the RFM69 driver.
                        • N
                          N
                          napo7
                          Well done ! I must admit I wasn't ready to read such a word play ;)
                          Hum... In fact, I did a small try, cloned the RF24 bootloader, tried to search which pieces of the code I have to modify, but didn't go further....
                          If you was about to release it in the future days (I'm willing to help/debug/test), I'd have waited, but my projects are going to be on a rush....
                          I'll try to go a bit further in making my own version :)
                          • N napo7
                            tekkaT
                            tekkaT
                            tekka
                            @napo7 perfect!
                            • Y
                              Y
                              yury
                              The bootloader and OTA update script + RFM69 work super nice with MYScontroller. I use it few times a week. Big Big Big ups to Tekka. Especially I like the sensebender micro bootloader boots instantly ))). Enjoy everybody!
                              • N
                                N
                                napo7
                                Hi @tekka,
                                Any news about RFM69 for MYSBootloader ?
                                I've had another look in the code, too much complicated for my skills !
                                • N napo7
                                  Hi @tekka,
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @napo7 No, nothing that is close to a release - I've done some PoC with rfm69 bootloading but this needs more time.
                                  • N
                                    N
                                    napo7
                                    Hi @tekka
                                    Would you share your poc so I could try to enhance it ?
                                    Regards
