  3. An Esp8266 Nextion Scene controller??
38 Posts 12 Posters 25.7k Views 18 Watching
  • DidiD Offline
    DidiD Offline
    Didi
    It´s from his blog and i think the pcb is updated
    • David VitrantD David Vitrant
      Hmm hey sorry for dumb question especially since it's a super old post but I don't seem to find a link to the eagle/cad documents or a way to buy this shield. I have Nextion 2.4, 3.2" and some enhanced version too.
      Let me know if I missed the buy button or a way to get the fritzing/eaglecad I can change myself and maybe adapt to my sousvide and thermostat project :).
      Help Please,
      DV
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      #25
      @fets @David-Vitrant as @Didi pointed out this is Peter Scargill's board. I suggest you read this link if you want to set it up - http://tech.scargill.net/home-control-2016/ It does require MQTT and Node-red knowledge though
      I uploaded the latest version on oshpark
      F 1 Reply Last reply
      • alexsh1A Offline
        alexsh1A Offline
        alexsh1
        https://www.youtube.com/watch?v=aljm6vH3a5I - this is a video explaining functionality (this is the older version of the board)
        • alexsh1A alexsh1
          F Offline
          F Offline
          fets
          I'm a fan of scargill work. I saw this article a while ago but I didn't use ESP8266 at the time, so I didn't pay attention.
          Now after several tests with ESP, I'm more interested in this PCB, but I can't find a link to oshpark in the article.
          Can you provide a link please.:clap:
          • alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @fets Sure -> https://oshpark.com/shared_projects/UDRPebht
            • David VitrantD Offline
              David Vitrant
              @alexsh1 Ha thanks for the osh link :). Saved me the trouble. I find myself building many similar projets and exploring similar avenues as Scargill.
              Have to use my SMD workstation and go blind for this. But will try anyway.
              • alexsh1A alexsh1
                F Offline
                F Offline
                fets
                @alexsh1 :+1:
                • ? Offline
                  ? Offline
                  A Former User
                  @scalz : What software did you used to create these 3d pics of your board?
                  • S Offline
                    @ben5en
                    solidworks, sketchup
                    • A Offline
                      A Offline
                      artipi
                      Hi @alexsh1 ,
                      did you finished your Enhanced Version? As i understood correctly the ESP8266 Board is used to send messages/touch commands over wifi - mqtt to a controller right? How it is programmed to send over mqtt?
                      So if i have this ESP - Board i do not need a arduino right?
                      Another question: Is it possible to run this board with a arduino pro mini or uno and nrf radio to send messages to my controller?
                      alexsh1A 1 Reply Last reply
                      • A Offline
                        A Offline
                        artipi
                        As i see, i can also take some of this ESP-Boards right?
                        https://www.aliexpress.com/item/1pcs-lot-NodeMcu-Lua-WIFI-Internet-of-Things-development-board-based-ESP8266-esp-12e-for-arduino/32775934156.html?spm=2114.01010208.8.10.eix0zH
                        • A artipi
                          Hi @alexsh1 ,
                          alexsh1A Offline
                          alexsh1A Offline
                          alexsh1
                          @artipi what is it you are trying to do?
                          You have to read more on the esp8266 forum.
                          There is a tool to upload binaries (it works on Windows 10) to esp8266. You have to compile binaries.
                          No, the board has not been designed to be run in the arduino environment. This is only esp8266.
                          @artipi said in An Esp8266 Nextion Scene controller??:
                          Hi @alexsh1 ,
                          • A artipi
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @artipi no, for this board you only need esp-12
                            • A Offline
                              A Offline
                              artipi
                              i try to make a small Wall scene controller that sends the commands to Domoticz over mqtt.
                              I ordered now the Nextion Display an thinking now to buy a WeMos D1 Mini Pro. Is that the right way?
                              • L Offline
                                L Offline
                                luma
                                I stumbled across this thread while searching for something related and thought I'd resurrect it to mention my HASwitchPlate project, which utilizes an ESP8266 as a MQTT-to-Nextion gateway to act as a wall-mounted scene controller. The project includes code for the ESP8266, Nextion, and home automation platforms including Home Assistant and OpenHAB. A PCB has been developed to allow running from AC power, and 3D-printable models are provided to mount the project into a single-gang work box common in North America.
                                The end result is a scene controller you can build yourself with all the necessary components (software, electronics, and physical enclosure) ready to download.
