  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 665.0k Views 99 Watching
  • AndrewZA
    AndrewZA
    AndrewZ
    @TimO , I just noticed a weird behavior - I've changed configuration for another binding and restarted it from the console but that killed mysensors binding:
    2017-03-04 13:07:19.110 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.things'
    2017-03-04 13:07:19.123 [ERROR] [col.serial.MySensorsSerialConnection] - Interrupted reset time wait
    2017-03-04 13:07:19.124 [WARN ] [col.serial.MySensorsSerialConnection] - Skipping I_VERSION connection test, not recommended...
    2017-03-04 13:07:19.125 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
    2017-03-04 13:07:19.125 [WARN ] [col.serial.MySensorsSerialConnection] - Network Sanity Checker thread disabled from bridge configuration
    2017-03-04 13:07:21.141 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
    2017-03-04 13:07:21.149 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    2017-03-04 13:07:33.161 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
    2017-03-04 13:07:33.163 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:1)
    Complete stop/start of OH is the only solution so far.
    andreacioniA 1 Reply Last reply
    • AndrewZA AndrewZ
      andreacioniA
      andreacioniA
      andreacioni
      Hi @AndrewZ , yes this is a known issue (I just openend an issue here) with the binding. Just out of curiosity, have you changed something in things file?
      AndrewZA 1 Reply Last reply
      • andreacioniA andreacioni
        AndrewZA
        AndrewZA
        AndrewZ
        @andreacioni thank you
        Yes, it was a change in the .things file, but it was related to another binding.
        • AndrewZA AndrewZ
          andreacioniA
          andreacioniA
          andreacioni
          @AndrewZ things file update trigger a reload of all binding declared inside it, nothing strange. ;) Follow the above link to keep track of the status of this issue.
          • L
            L
            LastSamurai
            I just tried to get the openhab 2 binding up and running. I have a serial gateway and domoticz + openhab running on a pi. I stopped the domoticz service and installed the serial and mysensors addons for openhab like mentioned in the github readme (bundle:list showed them both). I also added the openhab user to the dialout group.
            I then created a demo.things file in config/things with
            Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSB0", sendDelay=200 ] {
            The log of openhab shows these errors though:
            2017-03-19 00:03:59.855 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
            2017-03-19 00:03:59.897 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:46)
            Any idea why? This works just fine:
            cat /dev/ttyUSB0
            • L LastSamurai
              cat /dev/ttyUSB0
              AndrewZA
              AndrewZA
              AndrewZ
              wrote on last edited by AndrewZ
              #408
              @LastSamurai please check the group ownership
              $ ls -l /dev/ttyUSB0
              Make sure the port you're using is included in EXTRA_JAVA_OPTS as described here
              • L
                L
                LastSamurai
                Thank you, that helped! Should anyone ever face the same problem: after changing the EXTRA_JAVA_OPTS I also needed to restart openhab (more likely the java vm).
                • L
                  L
                  LastSamurai
                  So openhab is running now and discovers my sensors when I restart them while scanning. My RGBW controller nodes pop up as RGBW sensors though. The on/off switch works, but what do I have to do to actually control the colors?
                  I tried editing the 4 variables but that doesn't seem to change the lights.
                  0_1490048386134_upload-9bf82cdd-ddd8-4249-973e-65bd30a3a959
                  • T
                    TimO
                    wrote on last edited by TimO
                    #411
                    @LastSamurai : What does your sketch expect? One ASCII formated RGB code like described here: https://www.mysensors.org/download/serial_api_20 or a value between 0 and 100% per color (r,g,b,w)? I see different implementations (in openhab and in mysensors) and maybe we have to adjust the binding.
                    • L
                      L
                      LastSamurai
                      @TimO Right, I guess thats the problem. I have written my sketch against domoticz, so it expects either a 6 bit hex string (rgb = e.g. ff00ff) or a 9 bit (idk why) rgbw hex string (e.g. #ff00ff00).
                      According to the mysensors docu "ff00ff00" would be right, I guess.
                      T RVMRVMR 2 Replies Last reply
                      • AndrewZA
                        AndrewZA
                        AndrewZ
                        Just noticed in the log:
                        [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                        Is that normal or any additional configuration is needed?
                        • AndrewZA AndrewZ
                          TimO
                          @AndrewZ hmmmm, a child that represents itself with an id of 255 shouldn't exist. 255 is used for battery status for example. What's the message that comes in before that?
                          • L LastSamurai
                            TimO
                            @LastSamurai I'm working on a solution! RGB seems easy, but I haven't looked at RGBW. The Colopicker in OpenHAB only sends RGB.
                            L 1 Reply Last reply
                            • T TimO
                              AndrewZA
                              AndrewZA
                              AndrewZ
                              @TimO here is the output:
                              2017-03-23 20:51:32.531 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                              2017-03-23 20:51:33.754 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                              2017-03-23 20:51:33.772 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                              • AndrewZA AndrewZ
                                TimO
                                @AndrewZ the message occurs right after startup and before the bridge gets connected?! Just ignore the message if everything else is working fine. :D
                                I'll release the refactored version soon. It's already available via the new IoT marketplace.
                                • T TimO
                                  AndrewZA
                                  AndrewZA
                                  AndrewZ
                                  @TimO yes, message occurs on startup and I'm already using version from marketplace, I see it as market:binding-3328323 - 1.0
                                  • AndrewZA AndrewZ
                                    TimO
                                    @AndrewZ oh okay! I will look at it!
                                    • T TimO
                                      L
                                      L
                                      LastSamurai
                                      @TimO Cool, I'll test it once you are done. Domoticz only allows to either use the white channel or a RGB value (without the white) at the moment. Perhaps it can be done similarly in openhab.
                                      • L LastSamurai
                                        TimO
                                        @LastSamurai Could you please take a look at this: https://github.com/tobof/openhab2-addons/issues/76 ?
                                        I've added the RGB & RGBW channels and because I'm not that confident about the RGBW implementation I'm kindly asking you to test the implementation and give me some feedback. :-)
                                        The conversion from HSB, which is used by OpenHAB2 internally, to RGBW left me pretty confused. ;-)
                                        • L
                                          L
                                          LastSamurai
                                          I'll test it. Might take some days to get to it though ;)
