  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 675.9k Views 99 Watching
  • andreacioniA andreacioni
    Hi @AndrewZ , yes this is a known issue (I just openend an issue here) with the binding. Just out of curiosity, have you changed something in things file?
    AndrewZA
    AndrewZA
    AndrewZ
    @andreacioni thank you
    Yes, it was a change in the .things file, but it was related to another binding.
    andreacioniA 1 Reply Last reply
    • AndrewZA AndrewZ
      andreacioniA
      andreacioniA
      andreacioni
      @AndrewZ things file update trigger a reload of all binding declared inside it, nothing strange. ;) Follow the above link to keep track of the status of this issue.
      • L
        L
        LastSamurai
        I just tried to get the openhab 2 binding up and running. I have a serial gateway and domoticz + openhab running on a pi. I stopped the domoticz service and installed the serial and mysensors addons for openhab like mentioned in the github readme (bundle:list showed them both). I also added the openhab user to the dialout group.
        I then created a demo.things file in config/things with
        Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSB0", sendDelay=200 ] {
        The log of openhab shows these errors though:
        2017-03-19 00:03:59.855 [ERROR] [col.serial.MySensorsSerialConnection] - Can't connect to serial port. Wrong port?
        2017-03-19 00:03:59.897 [ERROR] [col.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:46)
        Any idea why? This works just fine:
        cat /dev/ttyUSB0
        AndrewZA 1 Reply Last reply
        • L LastSamurai
          cat /dev/ttyUSB0
          AndrewZA
          AndrewZA
          AndrewZ
          wrote on last edited by AndrewZ
          #408
          @LastSamurai please check the group ownership
          $ ls -l /dev/ttyUSB0
          Make sure the port you're using is included in EXTRA_JAVA_OPTS as described here
          • L
            L
            LastSamurai
            Thank you, that helped! Should anyone ever face the same problem: after changing the EXTRA_JAVA_OPTS I also needed to restart openhab (more likely the java vm).
            • L
              L
              LastSamurai
              So openhab is running now and discovers my sensors when I restart them while scanning. My RGBW controller nodes pop up as RGBW sensors though. The on/off switch works, but what do I have to do to actually control the colors?
              I tried editing the 4 variables but that doesn't seem to change the lights.
              0_1490048386134_upload-9bf82cdd-ddd8-4249-973e-65bd30a3a959
              • T
                TimO
                wrote on last edited by TimO
                #411
                @LastSamurai : What does your sketch expect? One ASCII formated RGB code like described here: https://www.mysensors.org/download/serial_api_20 or a value between 0 and 100% per color (r,g,b,w)? I see different implementations (in openhab and in mysensors) and maybe we have to adjust the binding.
                • L
                  L
                  LastSamurai
                  @TimO Right, I guess thats the problem. I have written my sketch against domoticz, so it expects either a 6 bit hex string (rgb = e.g. ff00ff) or a 9 bit (idk why) rgbw hex string (e.g. #ff00ff00).
                  According to the mysensors docu "ff00ff00" would be right, I guess.
                  T RVMRVMR 2 Replies Last reply
                  • AndrewZA
                    AndrewZA
                    AndrewZ
                    Just noticed in the log:
                    [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                    Is that normal or any additional configuration is needed?
                    • AndrewZA AndrewZ
                      TimO
                      @AndrewZ hmmmm, a child that represents itself with an id of 255 shouldn't exist. 255 is used for battery status for example. What's the message that comes in before that?
                      • L LastSamurai
                        TimO
                        @LastSamurai I'm working on a solution! RGB seems easy, but I haven't looked at RGBW. The Colopicker in OpenHAB only sends RGB.
                        L 1 Reply Last reply
                        • T TimO
                          AndrewZA
                          AndrewZA
                          AndrewZ
                          @TimO here is the output:
                          2017-03-23 20:51:32.531 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                          2017-03-23 20:51:33.754 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
                          2017-03-23 20:51:33.772 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
                          • AndrewZA AndrewZ
                            TimO
                            @AndrewZ the message occurs right after startup and before the bridge gets connected?! Just ignore the message if everything else is working fine. :D
                            I'll release the refactored version soon. It's already available via the new IoT marketplace.
                            • T TimO
                              AndrewZA
                              AndrewZA
                              AndrewZ
                              @TimO yes, message occurs on startup and I'm already using version from marketplace, I see it as market:binding-3328323 - 1.0
                              • AndrewZA AndrewZ
                                TimO
                                @AndrewZ oh okay! I will look at it!
                                • T TimO
                                  L
                                  L
                                  LastSamurai
                                  @TimO Cool, I'll test it once you are done. Domoticz only allows to either use the white channel or a RGB value (without the white) at the moment. Perhaps it can be done similarly in openhab.
                                  • L LastSamurai
                                    TimO
                                    @LastSamurai Could you please take a look at this: https://github.com/tobof/openhab2-addons/issues/76 ?
                                    I've added the RGB & RGBW channels and because I'm not that confident about the RGBW implementation I'm kindly asking you to test the implementation and give me some feedback. :-)
                                    The conversion from HSB, which is used by OpenHAB2 internally, to RGBW left me pretty confused. ;-)
                                    • L
                                      L
                                      LastSamurai
                                      I'll test it. Might take some days to get to it though ;)
                                      • B balder88
                                        Hey guys, first message on this forum. Been reading alot before. But now I have a problem I just can't solve.
                                        It's about smartsleep with openhab 2.
                                        Im using wifi gw rfm 69.
                                        Regular messages works as it should both ways.
                                        But it almost seems like the smartsleep isn't enabled in the binding.
                                        Here are my configs and logs.
                                        Things file:
                                        Bridge mysensors:bridge-eth:gw69 [ ipAddress="192.168.1.235", tcpPort=5003, sendDelay=100, enableNetworkSanCheck=true ] {
                                        //  Anarduino
                                            humidity        AnHum   [ nodeId="66", childId="0" ]
                                            temperature     AnTemp  [ nodeId="66", childId="1" ]
                                            light           light02 [ nodeId="66", childId="3", smartSleep=true ]
                                        Items file:
                                        Switch  TestLight   "Test lampa" (Test) { channel="mysensors:light:gw69:light02:status" }
                                        Sketch: (Cleaned up the parts that dont matter, RTC and so on.)
                                        #define MY_RADIO_RFM69
                                        #define MY_IS_RFM69HW
                                        #define MY_NODE_ID 66
                                        #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000
                                        #include <TimeLib.h>
                                        #include <MCP7940RTC.h>
                                        #define MCP7940_CTRL_ID 0x6F
                                        #define CSMEM_PIN 5
                                        #define LEDPIN 9
                                        long sleepIntervalSec=5;
                                        long loopCnt=0;
                                        uint8_t d[8];
                                        uint8_t dAlarm[8];
                                        int d1[8];
                                        #define DHT_DATA_PIN 6
                                        #define SENSOR_TEMP_OFFSET 0
                                        static const uint64_t UPDATE_INTERVAL = 5000;
                                        #define CHILD_ID_HUM 0
                                        #define CHILD_ID_TEMP 1
                                        #define CHILD_ID_MULTIMETER 2
                                        float lastTemp;
                                        float lastHum;
                                        uint8_t nNoUpdatesTemp;
                                        uint8_t nNoUpdatesHum;
                                        bool metric = true;
                                        MyMessage msgVolt(CHILD_ID_MULTIMETER, V_VOLTAGE);
                                        DHT dht;
                                        int oldBatteryPcnt = 0;
                                        int batteryBasement = 812;
                                        int batteryFull = 922;
                                        float batteryConstant = 100.0 / (batteryFull - batteryBasement);
                                        float lastbatteryV = 0;
                                        const int buzzer = 7; //buzzer to arduino pin 7
                                        #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                        void before()
                                          for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                                            pinMode(pin, OUTPUT);
                                           analogReference(INTERNAL);
                                          pinMode(LEDPIN, OUTPUT);
                                          digitalWrite(LEDPIN, LOW);
                                          Wire.begin();
                                          pinMode(CSMEM_PIN, OUTPUT);
                                          digitalWrite(CSMEM_PIN, HIGH);
                                          sleepIntervalSec = dht.getMinimumSamplingPeriod();
                                          clearAlarm();
                                          delay(20);
                                          setNewAlarm();
                                          analogRead(BATTERY_SENSE_PIN);
                                           sendSketchInfo("Humidity sensor", "1.0");
                                           present(CHILD_ID_MULTIMETER, S_MULTIMETER, "VOLT", true);
                                           present(CHILD_ID_HUM, S_HUM, "HUMIDITY", true);
                                           present(CHILD_ID_TEMP, S_TEMP, "TEMP", true);
                                            present(sensor, S_BINARY);
                                          wait(100);
                                           #ifdef MY_DEBUG
                                           Serial.println(sensorValue);
                                           float batteryV  = sensorValue * 0.004551646;
                                           if(sensorValue < batteryBasement) {
                                            sensorValue = batteryBasement;
                                            batteryV = 0;
                                           else if (sensorValue > batteryFull) {
                                            sensorValue = batteryFull;
                                           int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                                               if ((abs(oldBatteryPcnt - batteryPcnt) > 1)) {
                                              oldBatteryPcnt = batteryPcnt;
                                           if(batteryV != lastbatteryV) {
                                           send(msgVolt.set(batteryV, 2));
                                           lastbatteryV = batteryV;
                                           #ifdef MY_DEBUG
                                           Serial.print(batteryV);
                                           Serial.println(" V");
                                           Serial.print(batteryPcnt);
                                           Serial.println(" %");
                                          dht.readSensor(true);
                                          if (isnan(temperature)) {
                                            lastTemp = temperature;
                                            if (!metric) {
                                            // Reset no updates counter
                                            nNoUpdatesTemp = 0;
                                            #ifdef MY_DEBUG
                                            Serial.print("T: ");
                                            nNoUpdatesTemp++;
                                          if (isnan(humidity)) {
                                            lastHum = humidity;
                                            nNoUpdatesHum = 0;
                                            #ifdef MY_DEBUG
                                            Serial.print("H: ");
                                            Serial.println(humidity);
                                            nNoUpdatesHum++;
                                        long sleepTime = UPDATE_INTERVAL;
                                        if (batteryPcnt < 50) {
                                          sleepTime = (sleepTime * 2);
                                          sleepIntervalSec = sleepTime / 1000;
                                          Serial.println();
                                          Serial.print("Setting new sleep time: ");
                                          Serial.print(sleepIntervalSec);
                                          Serial.println(" seconds.");
                                          clearAlarm();
                                          delay(20);
                                          setNewAlarm();
                                          smartSleep(sleepTime);
                                          if (message.type==V_STATUS) {
                                            // Change relay state
                                            // Store state in eeprom
                                        Sensor startup:
                                        3 MCO:BGN:BFR
                                        4 TSM:INIT
                                        5 TSF:WUR:MS=0
                                        8 TSM:INIT:TSP OK
                                        9 TSM:INIT:STATID=66
                                        11 TSF:SID:OK,ID=66
                                        13 TSM:FPAR
                                        143 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        524 TSF:MSG:READ,0-0-66,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        529 TSF:MSG:FPAR OK,ID=0,D=1
                                        2150 TSM:FPAR:OK
                                        2151 TSM:ID
                                        2152 TSM:ID:OK
                                        2154 TSM:UPL
                                        2161 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                        2181 TSF:MSG:READ,0-0-66,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                        2186 TSF:MSG:PONG RECV,HP=1
                                        2189 TSM:UPL:OK
                                        2190 TSM:READY:ID=66,PAR=0,DIS=1
                                        2199 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                        2253 TSF:MSG:READ,0-0-66,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        2310 TSF:MSG:SEND,66-66-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                        2366 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                        2403 TSF:MSG:READ,0-0-66,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        2461 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Humidity sensor
                                        2562 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                        2618 TSF:MSG:SEND,66-66-0-0,s=2,c=0,t=30,pt=0,l=4,sg=0,ft=0,st=OK:VOLT
                                        2757 !TSF:MSG:SEND,66-66-0-0,s=0,c=0,t=7,pt=0,l=8,sg=0,ft=0,st=NACK:HUMIDITY
                                        2777 TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=6,pt=0,l=4,sg=0,ft=1,st=OK:TEMP
                                        2912 !TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
                                        2918 MCO:REG:REQ
                                        2974 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                                        2991 TSF:MSG:READ,0-0-66,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        2996 MCO:PIM:NODE REG=1
                                        2999 MCO:BGN:STP
                                        3154 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                        3160 MCO:SLP:TPD
                                        3161 MCO:SLP:WUP=-1
                                        3163 MCO:BGN:INIT OK,TSP=1
                                        Log Sensor: (This is when I press the button when the sensor is awake)
                                        It's sends away it's heartbeat correctly.
                                        125578 TSF:MSG:READ,0-0-66,s=3,c=1,t=2,pt=0,l=1,sg=0:0
                                        Setting new sleep time: 5 seconds.
                                        137926 MCO:SLP:MS=5000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                        137939 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:134932
                                        Log Openhab: And the gateway receives heartbeat.
                                        18:21:37.174 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                                        18:21:37.178 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                                        18:21:37.181 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                                        18:22:15.416 [DEBUG] [rs.internal.protocol.MySensorsReader] - 66;255;3;0;22;134932
                                        18:22:16.372 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                                        18:22:16.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.1
                                        Log Openhab: When the node sleeps..
                                        18:26:52.396 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                                        18:26:52.397 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                                        18:26:52.399 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                                        As you can see there is no mention in the openhab log file about buffering or smart sleep. Or a received heartbeat. Which it gets.
                                        What am I doing wrong?
                                        B
                                        B
                                        balder88
                                        I found the solution myself. About a week ago i upgraded the binding. And it worked.
                                        Everything seems to work as it should. Except I can't recieve var1 (custom) for neither the hum or temp child.
                                        smartSleep is nice. I use it once an hour (regular sleep every minute) to get configurations from openhab about sleep time and other small things in the code.
                                        @balder88 said in openHAB 2.0 binding:
                                        Things file:
                                        //  Anarduino
                                        Items file:
                                        #define CSMEM_PIN 5
                                        #define LEDPIN 9
                                        long loopCnt=0;
                                        uint8_t d[8];
                                        uint8_t dAlarm[8];
                                        int d1[8];
                                        float lastTemp;
                                        float lastHum;
                                        bool metric = true;
                                        DHT dht;
                                        void before()
                                          Wire.begin();
                                          clearAlarm();
                                          delay(20);
                                          setNewAlarm();
                                          wait(100);
                                           #ifdef MY_DEBUG
                                            batteryV = 0;
                                           #ifdef MY_DEBUG
                                            if (!metric) {
                                            nNoUpdatesTemp = 0;
                                            #ifdef MY_DEBUG
                                            nNoUpdatesTemp++;
                                            lastHum = humidity;
                                            nNoUpdatesHum = 0;
                                            #ifdef MY_DEBUG
                                            nNoUpdatesHum++;
                                          Serial.println();
                                          clearAlarm();
                                          delay(20);
                                          setNewAlarm();
                                        Sensor startup:
                                        3 MCO:BGN:BFR
                                        4 TSM:INIT
                                        5 TSF:WUR:MS=0
                                        8 TSM:INIT:TSP OK
                                        11 TSF:SID:OK,ID=66
                                        13 TSM:FPAR
                                        2150 TSM:FPAR:OK
                                        2151 TSM:ID
                                        2152 TSM:ID:OK
                                        2154 TSM:UPL
                                        2189 TSM:UPL:OK
                                        2918 MCO:REG:REQ
                                        2999 MCO:BGN:STP
                                        3160 MCO:SLP:TPD
                                        3161 MCO:SLP:WUP=-1
                                        • A
                                          antonholmstedt
                                          First I want to thank you for this binding, got it working with my esp8266 gateway without any problems at all. However, I want to ask how the reconnection problem is developing, any plans to solve it or is it not possible? I've tried to scan the thread but didn't find any information regarding it.
