  3. OpenHAB
  4. openHAB 2.0 binding
openHAB 2.0 binding
534 Posts 88 Posters 676.6k Views 99 Watching
  • T
    TimO
    wrote on last edited by TimO
    #411
    @LastSamurai : What does your sketch expect? One ASCII formated RGB code like described here: https://www.mysensors.org/download/serial_api_20 or a value between 0 and 100% per color (r,g,b,w)? I see different implementations (in openhab and in mysensors) and maybe we have to adjust the binding.
    • L
      L
      LastSamurai
      @TimO Right, I guess thats the problem. I have written my sketch against domoticz, so it expects either a 6 bit hex string (rgb = e.g. ff00ff) or a 9 bit (idk why) rgbw hex string (e.g. #ff00ff00).
      According to the mysensors docu "ff00ff00" would be right, I guess.
      T RVMRVMR 2 Replies Last reply
      • AndrewZA
        AndrewZA
        AndrewZ
        Just noticed in the log:
        [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
        Is that normal or any additional configuration is needed?
        • AndrewZA AndrewZ
          TimO
          @AndrewZ hmmmm, a child that represents itself with an id of 255 shouldn't exist. 255 is used for battery status for example. What's the message that comes in before that?
          AndrewZA 1 Reply Last reply
          • L LastSamurai
            TimO
            @LastSamurai I'm working on a solution! RGB seems easy, but I haven't looked at RGBW. The Colopicker in OpenHAB only sends RGB.
            L 1 Reply Last reply
            • T TimO
              AndrewZA
              AndrewZA
              AndrewZ
              @TimO here is the output:
              2017-03-23 20:51:32.531 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
              2017-03-23 20:51:33.754 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
              2017-03-23 20:51:33.772 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
              • AndrewZA AndrewZ
                TimO
                @AndrewZ the message occurs right after startup and before the bridge gets connected?! Just ignore the message if everything else is working fine. :D
                I'll release the refactored version soon. It's already available via the new IoT marketplace.
                • T TimO
                  AndrewZA
                  AndrewZA
                  AndrewZ
                  @TimO yes, message occurs on startup and I'm already using version from marketplace, I see it as market:binding-3328323 - 1.0
                  • AndrewZA AndrewZ
                    TimO
                    @AndrewZ oh okay! I will look at it!
                    • T TimO
                      L
                      L
                      LastSamurai
                      @TimO Cool, I'll test it once you are done. Domoticz only allows to either use the white channel or a RGB value (without the white) at the moment. Perhaps it can be done similarly in openhab.
                      • L LastSamurai
                        TimO
                        @LastSamurai Could you please take a look at this: https://github.com/tobof/openhab2-addons/issues/76 ?
                        I've added the RGB & RGBW channels and because I'm not that confident about the RGBW implementation I'm kindly asking you to test the implementation and give me some feedback. :-)
                        The conversion from HSB, which is used by OpenHAB2 internally, to RGBW left me pretty confused. ;-)
                        • L
                          L
                          LastSamurai
                          I'll test it. Might take some days to get to it though ;)
                          • B balder88
                            Hey guys, first message on this forum. Been reading alot before. But now I have a problem I just can't solve.
                            It's about smartsleep with openhab 2.
                            Im using wifi gw rfm 69.
                            Regular messages works as it should both ways.
                            But it almost seems like the smartsleep isn't enabled in the binding.
                            Here are my configs and logs.
                            Things file:
                            Bridge mysensors:bridge-eth:gw69 [ ipAddress="192.168.1.235", tcpPort=5003, sendDelay=100, enableNetworkSanCheck=true ] {
                            //  Anarduino
                                humidity        AnHum   [ nodeId="66", childId="0" ]
                                temperature     AnTemp  [ nodeId="66", childId="1" ]
                                light           light02 [ nodeId="66", childId="3", smartSleep=true ]
                            Items file:
                            Switch  TestLight   "Test lampa" (Test) { channel="mysensors:light:gw69:light02:status" }
                            Sketch: (Cleaned up the parts that dont matter, RTC and so on.)
                            #define MY_RADIO_RFM69
                            #define MY_IS_RFM69HW
                            #define MY_NODE_ID 66
                            #define MY_SMART_SLEEP_WAIT_DURATION_MS 1000
                            #include <TimeLib.h>
                            #include <MCP7940RTC.h>
                            #define MCP7940_CTRL_ID 0x6F
                            #define CSMEM_PIN 5
                            #define LEDPIN 9
                            long sleepIntervalSec=5;
                            long loopCnt=0;
                            uint8_t d[8];
                            uint8_t dAlarm[8];
                            int d1[8];
                            #define DHT_DATA_PIN 6
                            #define SENSOR_TEMP_OFFSET 0
                            static const uint64_t UPDATE_INTERVAL = 5000;
                            #define CHILD_ID_HUM 0
                            #define CHILD_ID_TEMP 1
                            #define CHILD_ID_MULTIMETER 2
                            float lastTemp;
                            float lastHum;
                            uint8_t nNoUpdatesTemp;
                            uint8_t nNoUpdatesHum;
                            bool metric = true;
                            MyMessage msgVolt(CHILD_ID_MULTIMETER, V_VOLTAGE);
                            DHT dht;
                            int oldBatteryPcnt = 0;
                            int batteryBasement = 812;
                            int batteryFull = 922;
                            float batteryConstant = 100.0 / (batteryFull - batteryBasement);
                            float lastbatteryV = 0;
                            const int buzzer = 7; //buzzer to arduino pin 7
                            #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                            void before()
                              for (int sensor=3, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                                pinMode(pin, OUTPUT);
                               analogReference(INTERNAL);
                              pinMode(LEDPIN, OUTPUT);
                              digitalWrite(LEDPIN, LOW);
                              Wire.begin();
                              pinMode(CSMEM_PIN, OUTPUT);
                              digitalWrite(CSMEM_PIN, HIGH);
                              sleepIntervalSec = dht.getMinimumSamplingPeriod();
                              clearAlarm();
                              delay(20);
                              setNewAlarm();
                              analogRead(BATTERY_SENSE_PIN);
                               sendSketchInfo("Humidity sensor", "1.0");
                               present(CHILD_ID_MULTIMETER, S_MULTIMETER, "VOLT", true);
                               present(CHILD_ID_HUM, S_HUM, "HUMIDITY", true);
                               present(CHILD_ID_TEMP, S_TEMP, "TEMP", true);
                                present(sensor, S_BINARY);
                              wait(100);
                               #ifdef MY_DEBUG
                               Serial.println(sensorValue);
                               float batteryV  = sensorValue * 0.004551646;
                               if(sensorValue < batteryBasement) {
                                sensorValue = batteryBasement;
                                batteryV = 0;
                               else if (sensorValue > batteryFull) {
                                sensorValue = batteryFull;
                               int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
                                   if ((abs(oldBatteryPcnt - batteryPcnt) > 1)) {
                                  oldBatteryPcnt = batteryPcnt;
                               if(batteryV != lastbatteryV) {
                               send(msgVolt.set(batteryV, 2));
                               lastbatteryV = batteryV;
                               #ifdef MY_DEBUG
                               Serial.print(batteryV);
                               Serial.println(" V");
                               Serial.print(batteryPcnt);
                               Serial.println(" %");
                              dht.readSensor(true);
                              if (isnan(temperature)) {
                                lastTemp = temperature;
                                if (!metric) {
                                // Reset no updates counter
                                nNoUpdatesTemp = 0;
                                #ifdef MY_DEBUG
                                Serial.print("T: ");
                                nNoUpdatesTemp++;
                              if (isnan(humidity)) {
                                lastHum = humidity;
                                nNoUpdatesHum = 0;
                                #ifdef MY_DEBUG
                                Serial.print("H: ");
                                Serial.println(humidity);
                                nNoUpdatesHum++;
                            long sleepTime = UPDATE_INTERVAL;
                            if (batteryPcnt < 50) {
                              sleepTime = (sleepTime * 2);
                              sleepIntervalSec = sleepTime / 1000;
                              Serial.println();
                              Serial.print("Setting new sleep time: ");
                              Serial.print(sleepIntervalSec);
                              Serial.println(" seconds.");
                              clearAlarm();
                              delay(20);
                              setNewAlarm();
                              smartSleep(sleepTime);
                              if (message.type==V_STATUS) {
                                // Change relay state
                                // Store state in eeprom
                            Sensor startup:
                            3 MCO:BGN:BFR
                            4 TSM:INIT
                            5 TSF:WUR:MS=0
                            8 TSM:INIT:TSP OK
                            9 TSM:INIT:STATID=66
                            11 TSF:SID:OK,ID=66
                            13 TSM:FPAR
                            143 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            524 TSF:MSG:READ,0-0-66,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            529 TSF:MSG:FPAR OK,ID=0,D=1
                            2150 TSM:FPAR:OK
                            2151 TSM:ID
                            2152 TSM:ID:OK
                            2154 TSM:UPL
                            2161 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                            2181 TSF:MSG:READ,0-0-66,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            2186 TSF:MSG:PONG RECV,HP=1
                            2189 TSM:UPL:OK
                            2190 TSM:READY:ID=66,PAR=0,DIS=1
                            2199 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            2253 TSF:MSG:READ,0-0-66,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            2310 TSF:MSG:SEND,66-66-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                            2366 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                            2403 TSF:MSG:READ,0-0-66,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            2461 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=OK:Humidity sensor
                            2562 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                            2618 TSF:MSG:SEND,66-66-0-0,s=2,c=0,t=30,pt=0,l=4,sg=0,ft=0,st=OK:VOLT
                            2757 !TSF:MSG:SEND,66-66-0-0,s=0,c=0,t=7,pt=0,l=8,sg=0,ft=0,st=NACK:HUMIDITY
                            2777 TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=6,pt=0,l=4,sg=0,ft=1,st=OK:TEMP
                            2912 !TSF:MSG:SEND,66-66-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
                            2918 MCO:REG:REQ
                            2974 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                            2991 TSF:MSG:READ,0-0-66,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                            2996 MCO:PIM:NODE REG=1
                            2999 MCO:BGN:STP
                            3154 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            3160 MCO:SLP:TPD
                            3161 MCO:SLP:WUP=-1
                            3163 MCO:BGN:INIT OK,TSP=1
                            Log Sensor: (This is when I press the button when the sensor is awake)
                            It's sends away it's heartbeat correctly.
                            125578 TSF:MSG:READ,0-0-66,s=3,c=1,t=2,pt=0,l=1,sg=0:0
                            Setting new sleep time: 5 seconds.
                            137926 MCO:SLP:MS=5000,SMS=1,I1=255,M1=255,I2=255,M2=255
                            137939 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:134932
                            Log Openhab: And the gateway receives heartbeat.
                            18:21:37.174 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                            18:21:37.178 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                            18:21:37.181 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                            18:22:15.416 [DEBUG] [rs.internal.protocol.MySensorsReader] - 66;255;3;0;22;134932
                            18:22:16.372 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                            18:22:16.408 [DEBUG] [rs.internal.protocol.MySensorsReader] - 0;255;3;0;2;2.1.1
                            Log Openhab: When the node sleeps..
                            18:26:52.396 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 66;3;1;0;2;0
                            18:26:52.397 [INFO ] [smarthome.event.ItemCommandEvent    ] - Item 'TestLight' received command OFF
                            18:26:52.399 [INFO ] [marthome.event.ItemStateChangedEvent] - TestLight changed from ON to OFF
                            As you can see there is no mention in the openhab log file about buffering or smart sleep. Or a received heartbeat. Which it gets.
                            What am I doing wrong?
                            B
                            B
                            balder88
                            I found the solution myself. About a week ago i upgraded the binding. And it worked.
                            Everything seems to work as it should. Except I can't recieve var1 (custom) for neither the hum or temp child.
                            smartSleep is nice. I use it once an hour (regular sleep every minute) to get configurations from openhab about sleep time and other small things in the code.
                            @balder88 said in openHAB 2.0 binding:
                            Things file:
                            //  Anarduino
                            Items file:
                            #define CSMEM_PIN 5
                            #define LEDPIN 9
                            long loopCnt=0;
                            uint8_t d[8];
                            uint8_t dAlarm[8];
                            int d1[8];
                            float lastTemp;
                            float lastHum;
                            bool metric = true;
                            DHT dht;
                            void before()
                              Wire.begin();
                              clearAlarm();
                              delay(20);
                              setNewAlarm();
                              wait(100);
                               #ifdef MY_DEBUG
                                batteryV = 0;
                               #ifdef MY_DEBUG
                                if (!metric) {
                                nNoUpdatesTemp = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesTemp++;
                                lastHum = humidity;
                                nNoUpdatesHum = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesHum++;
                              Serial.println();
                              clearAlarm();
                              delay(20);
                              setNewAlarm();
                            Sensor startup:
                            3 MCO:BGN:BFR
                            4 TSM:INIT
                            5 TSF:WUR:MS=0
                            8 TSM:INIT:TSP OK
                            11 TSF:SID:OK,ID=66
                            13 TSM:FPAR
                            2150 TSM:FPAR:OK
                            2151 TSM:ID
                            2152 TSM:ID:OK
                            2154 TSM:UPL
                            2189 TSM:UPL:OK
                            2918 MCO:REG:REQ
                            2999 MCO:BGN:STP
                            3160 MCO:SLP:TPD
                            3161 MCO:SLP:WUP=-1
                            • A
                              antonholmstedt
                              First I want to thank you for this binding, got it working with my esp8266 gateway without any problems at all. However, I want to ask how the reconnection problem is developing, any plans to solve it or is it not possible? I've tried to scan the thread but didn't find any information regarding it.
                              • A
                                Alpoy
                                wrote on last edited by Alpoy
                                #425
                                Thanks for making this binding! :)
                                One question, is there a specific reason motion (tripped) sensors have to be Contact items?
                                In OH2 all the Z-wave motion sensors are Switches (AFAIK) so it would be nice if the mysensor PIR's could also be Switches so I can just add these to my existing motion sensor groups and rules.
                                (I tried setting a triggered channel as Switch but it didn't work)
                                andreacioniA 1 Reply Last reply
                                • A Alpoy
                                  andreacioniA
                                  andreacioniA
                                  andreacioni
                                  @Alpoy check this discussion on GitHub. The question is still open.
                                  @antonholmstedt reconnection is currently implemented in binding (look here). Feel free to open an issue if you experience reconnection fails in your environment :smiley:
                                  • andreacioniA andreacioni
                                    antonholmstedt
                                    Yes I have reconnection problems right now, so will open an issue :)
                                    • N
                                      N
                                      Nicklas Starkel
                                      I was checking back on this bindning and it really has matured!
                                      On GitHub I see that there are some updates referring to MqTT protocol.
                                      Are they available in the JAR that is posted here?
                                      http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                                      Kudos on the great work!
                                      • N Nicklas Starkel
                                        TimO
                                        @Nicklas-Starkel Well no, MQTT Gateway is not yet supported. :-(
                                        I got distracted by my current hardware project and need to catch up on the binding. First tests of the MQTT addition to the binding look very promising and I'll include it soon.
                                        The current release is this one: http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.1.0-SNAPSHOT.jar
                                        While preparing the code to be included in OpenHAB2 I'm currently changing some things that will break the current configuration / things files. But I will give some information about that with the release of the next version.
                                        • G
                                          G
                                          gonzalonal
                                          Hi @TimO, @andreacioni.
                                          I am doing some "expert mode" rules where I need to get the NodeId of a specific sensors, or at least, to get all the configured Nodes Ids. Is that possible?
                                          I would like to cron a rule where every X minutes, heartbeat request message is sent to all configured nodes, so as to see wether they are alive or not.
                                          Thanks, regards.
