  3. 💬 RFM69 Livolo 2 channels 1 way EU switch(VL-C700X-1 Ver: B8)
mysensorslivolo
100 Posts 14 Posters 49.8k Views 17 Watching
  • jirmJ jirm
    @alexus
    Few weeks ago I uploaded and shared to Oshpark pcb web service this @mtiutiu pcb design (but take care !!! I think this is not last one version @mtiutiu design), so anyone can easily find it there and order build some pcb if like.
    You can check it at https://oshpark.com/shared_projects , and easyly find it with only enter "livolo" word in the search case.
    Sadly I don't have enough time yet to involve more in this project, but in near future I'm going to that and test that awesome design that this project have.
    Regards
    alexus
    @jirm Thanks!
      shabba
      Crap! I have version C2. I have already ordered all the BOM components! Doh.
      Can the old PCB be hacked into working with this? What is the actual difference?
      mtiutiuM 1 Reply Last reply
      • S shabba
        mtiutiuM
        mtiutiuM
        mtiutiu
        #58
        @shabba
        Can you post some pictures of the new board? I'm curious how it looks on both sides. I'm referring to the power/relays board underneath. I may need to recreate this project board after the new one because my friend for whom I made this project initially bought the new version of the Livolo switches. So in the end I think I'll work on the new version but only after he receives the switches as I need to compare and see the differences from both a mechanical and electrical point of view.
        Don't worry about the BOM as that part stays the same. What could change is only the PCB layout and its size and/or outline.
          shabba
          wrote on last edited by shabba
          #59
          If you want better close ups etc let me know.
          link text
            shabba
            Hmm.. I added some links in last post but they don't seem to show..
            • S shabba
              mtiutiuM
              mtiutiuM
              mtiutiu
              @shabba
              There's a button called upload image with an arrow inside it and a cloud symbol underneath.
                shabba
                Shared album here: https://goo.gl/photos/H5w7u9cNbiS6SGRD9
                • S shabba
                  mtiutiuM
                  mtiutiuM
                  mtiutiu
                  #63
                  @shabba
                  Can you focus a little bit better on the power/relays board? Those pics are a little bit blurry. Thanks. Oh..and I almost forgot - thank you for your gratitude.
                  The main change is that they added a 2x7 connector now instead of the old one which was 2x6. But that's not a big problem at all as I can recreate the PCB to accommodate the new one. Still I have to wait for the Livolo switches to come in my hand so that I can identify the changes regarding the new connector(where the relays are connected and the 12-14V line if any). Other than that I don't see any big changes only the rounded corners are not so round now and they have a cut. The MOSFET is placed now at a 45 degree angle and the relays driving IC is a TSSOP one if I see well in the pictures. The 3.3V or 3V regulator is placed somewhere else now but that doesn't matter as I don't need it.
                  So in short: I need to recreate the PCB to accommodate the new 2x7 connector and to add cuts in the corners. BOM will not change.
                    shabba
                    Added a couple more pics.
                    • mtiutiuM mtiutiu
                      @shabba
                      tonnerre33T
                      tonnerre33T
                      tonnerre33
                      @mtiutiu It's the PCB that i made here : https://github.com/tonnerre33/Linovo_EU_2Gang_1way/tree/develop/
                      You can take many informations that you want ;)
                      I'm curious to see how you'll do the pcb for compare with mine and learn ;)
                      A mtiutiuM 2 Replies Last reply
                      • tonnerre33T tonnerre33
                        alexus
                        @tonnerre33 Great work. Can design with esp8266, it would be fine
                          mtiutiuM
                          mtiutiuM
                          mtiutiu
                          #67
                          @tonnerre33
                          Nice work. I will steal maybe the outline of the board(board frame) :simple_smile: . Did you tested it from a mechanical point of view? I mean will the board fit in the enclosure? And I see that you use the existent voltage regulator from the Livolo power/relays board...I didn't wanted to use that because the voltage drop over it is pretty big(12-14V - 3V =~ 9-11V) and with that in mind considering the TX current of the RFM69 which is around 50mA gives a max power dissipation of: 11V x 50mA = 550mW - pretty high(I didn't added here the MCU, LEDS and other stuff). Now this only happens on TX time which should be pretty short in theory so it should handle that(but better check the voltage regulator datasheet though). Rest of the time it will be around 16mA(RX current of the RFM69W) + a few milliamps for the MCU and other components - around 20mA let's say and this translates to: 11V x 20mA = 220mW(half power dissipation compared to TX mode).
                          Now depending on how much time you're in TX mode compared to RX mode this will be around 300mW maybe if we take the average(but this is just a rough estimation). The onboard regulator that they use is a Holtek 7130-1 device which can whitstand a 24V input voltage BUT only 30mA output current max and it can dissipate using the SOT89 package around 500mW maximum so it may heat.
                          I don't know if on the current board they changed it or not but still imho it's not a good idea on the long term to overload it. Indeed if the average power dissipation doesn't reach that value(500mW) it's ok and you should stay below that: usually it's a good idea to dissipate half of the max allowed power only.
                          And I saw that the 3V voltage regulator powers other stuff on the relays board not only the front plate so we should take that into consideration too.
                          Given all of the above and thinking on the long term that's the main reason I used a DC-DC step down converter powered from the 12-14V line which is also the voltage used to power the onboard 3V regulator that Livolo uses.
                          Most of the problems(if not all) come from a bad designed power supply. It seems that most people underestimate this part but what they don't realize is that the power supply is the most important part of every circuit and that it plays a very important role regarding the final performances and stability of the whole circuit that it powers.
                          • tonnerre33T
                            tonnerre33T
                            tonnerre33
                            #68
                            Thx mtiutiu.
                            I followed your advises and i converted the project to kicad ;)
                            For the board frame, i have tested it with paper but it's difficult to check it because paper is flexible..
                            Same for the position of the 2x7 pins connectors, i think it's ok but i'm not sure until i have tested it with a real pcb.
                            You are right for the power !! I haven't check the current consumption of the RFM !! OMG 45mA in tranmit mode when NRF24L01 is 11.3mA (but with 0dBm output power for NRF).
                            For RFM it's 20mA with 0dBm. Can't we set RFM to 0dBm ? I don't know the consequences for the range if we change this parameter...
                            The installed regulator is 7130-1 = 30mA for Vin=5V. Maybe it's more current for 3V ? I didn't see the information in the doc :(
                              Thx mtiutiu.
                              mtiutiuM
                              mtiutiuM
                              mtiutiu
                              #69
                              @tonnerre33
                              If you keep the average power dissipation under 250mW(half of the max rated value from the datasheet) it should be ok. Reducing the Tx power helps but will decrease coverage - but that's not a problem if you set your nodes as repeaters too as this will increase coverage(not the battery powered ones of course). So yes there are solutions don't worry.
                              Oh and I used paper too when I replicated the original board outline, touchpads and main connector placement. Then I scanned it, imported it into Inkscape, a little bit of QCAD...and in the end got the final results. There may be an easier way of doing it but I didn't had any better idea(s) at that time.
                              • MiKaM
                                MiKaM
                                MiKa
                                wrote on last edited by MiKa
                                #70
                                What about change 7130-1 to for example: MCP1703T-3302E/MB ?
                                MIKa
                                • MiKaM MiKa
                                  MIKa
                                  mtiutiuM
                                  mtiutiuM
                                  mtiutiu
                                  #71
                                  @MiKa
                                  That device is rated at 16V max input voltage...I won't use that because the input varies from 12 to 14V approx. So it's like living on the edge. Why are people afraid of including a DC-DC converter into their design when high voltage drops are involved and a little bit more output current is required - actually we can speak in terms of power here as it's more appropriate. So we all know that when it comes to more power a DC-DC converter is more efficient than a classic LDO. Is it because of noise? That can be filtered not a problem and reduced to an acceptable level. In terms of volume - indeed there are more components involved and a little bit more care is needed when designing the PCB but hey we need to make some compromise in the end...and I for example like to stay on the safe side on the long term.
                                  A 1 Reply Last reply
                                  • mtiutiuM mtiutiu
                                    @MiKa
                                    alexus
                                    wrote on last edited by alexus
                                    #72
                                    Is there a connection example with ESP?
                                    • A alexus
                                      mtiutiuM
                                      mtiutiuM
                                      mtiutiu
                                      @alexus
                                      Hi, I don't know of any. There was @DJONvl who claims that he did it on this thread: https://forum.mysensors.org/topic/2775/livolo-glass-panel-touch-light-wall-switch-arduino-433mhz/75. But it didn't got my attention as ESP or any WiFi module is too power hungry for this project where simple sensors/actuators are involved and very light in terms of power usage(including radio transport). But as I said this is only my personal preference.
                                        Thx mtiutiu.
                                        mtiutiuM
                                        mtiutiuM
                                        mtiutiu
                                        #74
                                        @tonnerre33
                                        Nice work regarding Kicad. You'll see that on the long term it's a real benefit to switch to Kicad and I strongly adhere to it even though some people would say the contrary. It is indeed a little bit hard maybe to start with it and the learning curve is not the easiest one but after you master it then it will be a joy to work with. And more features/bug fixes are made as we speak because it's a very active developed project now. And on top of that that it's FREE - no limitations or whatsoever.
                                          shabba
                                          I got my PCBs today in the post. Is there a way to hack them to work with new circuit or should I just bin them?
