ESP8266 and RFM69 send issue
Thanks, I'll give it a try with a simpler sketch and report back. Good point, I've always thought the NACK was coming from the local radio unable to send, not from the remote one, very good to know!
Ok the problem is definitely related to the ESP8266 gateway. I re-wired the same radio to a serial gateway and everything is working fine. Back to the ESP8266, same problem as before. On the serial I'm using:
#define MY_RADIO_RFM69 #define MY_RFM69_FREQUENCY RF69_868MHZ #define MY_IS_RFM69HWOn the esp8266:
#define MY_RADIO_RFM69 #define MY_RFM69_FREQUENCY RF69_868MHZ #define MY_IS_RFM69HW #define MY_RF69_IRQ_NUM D1 #define MY_RF69_SPI_CS D2Everything wired as the instructions from https://www.mysensors.org/build/connect_radio, I've double checked a few times already.
I have now a workaround so I should be fine but I'd be really curious to understand what was wrong in the esp8266 setup causing that issue...Thanks
@user2684 this seems to be missing:
#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PINI am not sure if it is needed, but it might be worth adding and see if it helps.
@mfalkvidd thanks for looking into it, but it should be already there, I've just consolidated the
#define MY_RF69_IRQ_PIN D1 #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PINinto a single line:
#define MY_RF69_IRQ_NUM D1 -
Quick update on this. I've also tried as the last chance to connect the radio to an external power but the result is always the same (send failure).
Apart from that, these RFM69 are amazing (this is the first time I'm using this radio), I've tested one with the working serial gateway; first I went downstairs and it was working (where the NRF24 got lost), then I moved outside and was working, then I walked and walked probably around 70-80 meters/yards (plus a few walls), in the dark for a while and was still working (sometimes the gateway was resetting I guess because the tx power required was too high). Pretty impressive.
You are the man @mfalkvidd! I've been very superficial to face this issue for saving a single line of code ;-) I didn't notice that define is actually used in MyTransportRFM69.cpp.
After adding it back I had to reset it a good number of times, sometimes I had a soft WTD reset just before the send, other times I had !TSF:MSG:SEND once again and then started working, looks like consistently now. I cannot explain why hasn't worked straight away after the change, it could even be some bad wiring I fixed without noticing it. Thanks for the help!
I had the same problem when I was troubleshooting RFM69 on my Wemos GW shield.
It seems to me that
#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PINIs supposed to be automatically set when
#define ARDUINO_ARCH_ESP8266is defined.
You would assume that when you define
#define MY_GATEWAY_ESP8266It would automatically add
#define ARDUINO_ARCH_ESP8266For example here in MySensors.h but it is not, meaning that
#define MY_RF69_IRQ_NUM MY_RF69_IRQ_PINis never declared.
So you can simply use
#define ARDUINO_ARCH_ESP8266 #define MY_RF69_IRQ_PIN D1or
#define MY_RF69_IRQ_PIN D1 #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PINin your sketch.
I personally think it should be automatically done in MySensors.h (and would be happy to submit a ticket on github if needed) but maybe it was done on purpose.
How did you get it to work finally?
I keep getting these "Soft WDT reset" crashes:
0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGE--,VER=2.1.1
0;255;3;0;9;TSF:LRT:OK
0;255;3;0;9;TSM:INIT
0;255;3;0;9;TSF:WUR:MS=0
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
0;255;3;0;9;!TSM:INIT:TSP FAILconnected with Airport, channel 6
dhcp client start...
0;255;3;0;9;TSM:FAIL:CNT=1
0;255;3;0;9;TSM:FAIL:PDT
ip:192.168.0.149,mask:255.255.255.0,gw:192.168.0.1
pm open,type:2 0
0;255;3;0;9;TSM:FAIL:RE-INIT
0;255;3;0;9;TSM:INITSoft WDT reset
ctx: cont
sp: 3ffef260 end: 3ffef550 offset: 01b0stack>>>
3ffef410: 00000004 3ffef940 3ffef5ec 402030bd
3ffef420: 00000027 3ffef940 3ffef5ec 40203071
3ffef430: 3ffef604 00000001 3ffef5ec 402031b5
3ffef440: 00000000 00000016 3ffef5ec 402033f0
3ffef450: 0000002f 3ffef940 3ffef5ec 000000ff
3ffef460: 00000000 00000016 3ffef5ec 402044bd
3ffef470: 00020401 40040203 33060305 40086c07
3ffef480: 42190009 07264025 dc291028 2d2f882e
3ffef490: 90376330 8f3c4238 306f123d 000000ff
3ffef4a0: 00000063 00000000 3ffefa30 40203834
3ffef4b0: 3ffef758 00000000 00000000 0000466d
3ffef4c0: 3ffef758 00000000 00000000 40204574
3ffef4d0: 3ffef758 0000466d 40204290 40204599
3ffef4e0: 00000000 00000000 00000000 40202e15
3ffef4f0: 000007ce 00000000 00000000 40204ca9
3ffef500: 3fffdad0 3ffef5a7 00000000 402050e7
3ffef510: 600002ff 00020000 3ffef758 3ffee528
3ffef520: 3fffdad0 3ffef5a7 3ffefa10 40205355
3ffef530: feefeffe 00000000 3ffee520 402053c0
3ffef540: feefeffe feefeffe 3ffee530 40100114
<<<stack<<< -
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
pm open,type:2 0
ctx: cont
<<<stack<<<
