  3. Is it possible to add a Sensor to a Gateway directly?
5 Posts 2 Posters 2.3k Views 2 Watching
  • F Offline
    F Offline
    free118
    Hello all,
    just a question.
    Is it possible to add a Sensor (Analog In) directly to a Gateway (arduino) and comunicate this value over USB?
    What I want to do is the following:
    I've one Sensor which communicate over the Gateway to my Pimatic (over serial USB)
    Now I want to add a second Sensor, which is physicaly very close to the Gateway.
    So i want to add it there, and it should communicate to Pimatic as well.
    Kind of an internal "Sensor" device.
    So is this possible? If yes how?
    Free
    • F free118
      Hello all,
      just a question.
      Free
      @free118 Welcome to the MySensors community!
      Yes it is possible. Just add it to the gateway sketch, just as if you were adding it to a normal sensor node sketch.
      • F Offline
        F Offline
        free118
        wrote on last edited by free118
        Ok great,
        that's what I've done.
        But which Node and Child ID is needed for this. So that the Input will communicate as a "Sensor" to the gateway.
        Because the Pimatic plugin need to know where to look.
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        #if F_CPU == 8000000L
        #define MY_BAUD_RATE 115200
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        #define ArrayLenth 10
        #define PH_SENSOR_ANALOG_PIN A0
        unsigned long lastSend = 0;
        static const unsigned long SEND_FREQUENCY = 5000;
        float lastPhValue;
        static const float deltaPhValue = 0.5;
        #define MY_NODE_ID 10
        #define CHILD_ID_PH_LOCAL 1
        MyMessage msg(0, V_PH);
        double analogReadAverage(uint8_t pin, unsigned long ms)
            return average;
        float getPH()
            if (sendTime || abs(PhValue - lastPhValue) > deltaPhValue)
                Serial.print("pH:");
                Serial.print(PhValue, 2);
               // Serial.println(" ");
                lastPhValue = PhValue;
                //send(msg.set(PhValue, 1));
                send(msg.set(PhValue, 51));
          return lastPhValue;
        	sendSketchInfo("PH Local","1.1");
          present(CHILD_ID_PH_LOCAL,S_WATER_QUALITY);
          float ph = getPH();
        Here the working Pimatic config for a Sensor through a gateway.
              "plugin": "mysensors",
              "driver": "serialport",
              "protocols": "1.5.1",
              "startingNodeId": 1,
              "driverOptions": {
                "//": "'/dev/ttyUSB0' if using serial Gateway",
                "serialDevice": "/dev/ttyUSB1",
                "baudrate": 115200
              "id": "phmeter",
              "name": "pHmeter",
              "class": "MySensorsPH",
              "nodeid": 9,
              "sensorid": 0,
              "xAttributeOptions": []
        • F free118
          Ok great,
          float lastPhValue;
              return average;
          float getPH()
            return lastPhValue;
            float ph = getPH();
                "driverOptions": {
                  "baudrate": 115200
                "id": "phmeter",
                "name": "pHmeter",
                "nodeid": 9,
                "sensorid": 0,
          I have no experience with Pimatic, but the child ID will be CHILD_ID_PH_LOCAL and the node ID will be 0 (gateways always have node ID=0).
          • F Offline
            F Offline
            free118
            Thanks for the answer. I tried this and it didn't work. I've started a thread in pimatic forum as well. Maybe they know how to do this.
            12.1k
