  3. ESP8266 failing with pm open,type:2 0
8 Posts 6 Posters 6.2k Views 6 Watching
  • L Offline
    L Offline
    lafleur
    wrote on last edited by lafleur
    The GW has been working just fine for that last few days, but when I rebooted it today, I now get the "pm open,type:2 0" from the ESP8266. When this happen, the GW stops working... Re building and loading of new code has same problem.
    I have tried 3 different ESP8266
    Any ideas on what is the root cause??
    GatewayESP8266MQTTClient with RFM95 radio
    Using beta 2.1. as of 1Dec2016
    IDE 1.6.13
    esp8266/hardware/esp8266/2.3.0
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RLNGE--,VER=2.1.0-beta
    0;255;3;0;9;TSF:LRT:OK
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:FAIL:CNT=1
    0;255;3;0;9;TSM:FAIL:PDT
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 2
    cnt
    connected with lafleur, channel 1
    dhcp client start...
    ip:192.94.167.240,mask:255.255.255.0,gw:192.94.167.4
    0;255;3;0;9;TSM:FAIL:RE-INIT
    0;255;3;0;9;TSM:FAIL:CNT=2
    pm open,type:2 0       <-----------------------------
    0;255;3;0;9;TSM:FAIL:CNT=3
     * TRL Ver 1 01 Dec 2016
     * MySensor 2.1b as of 23 Nov 2016
    #include <ESP8266WiFi.h>
    //#define MY_SPECIAL_DEBUG
    #define MY_DEBUG_VERBOSE_RFM95
    #error This program requires an ESP8266 CPU
    //#define MY_DEFAULT_RX_LED_PIN   16
    #define MY_DEFAULT_TX_LED_PIN     16
    //#define MY_DEFAULT_ERR_LED_PIN  26
    #define MY_BAUD_RATE 115200
    #define MY_RADIO_RFM95
    // Pin's defined below are for ESP8266
    #define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW125CR45SF128
    //#define MY_RFM95_RST_PIN RFM95_RST_PIN
    #define MY_RFM95_IRQ_PIN                15
    #define MY_RFM95_SPI_CS                 2
    #define MY_RFM95_TX_POWER               23  // max is 23
    //#define MY_RFM95_ATC_MODE_DISABLED
    #define MY_RFM95_ATC_TARGET_RSSI        (-60)
    #define MY_RFM95_FREQUENCY              (915.0f)
    #define MY_GATEWAY_ESP8266
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX   "MG1-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "MG1-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mysensors-2"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "test"
    #define MY_ESP8266_PASSWORD ""
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    #define MY_IP_ADDRESS 192, 94, 167, 42
    #define MY_IP_GATEWAY_ADDRESS 192, 94, 167, 4
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 94, 167, 32
    #define MY_PORT 1883
    #define MY_PARENT_NODE_ID   0
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    // All #define above need to be prior to #include <MySensors.h> below
     // this is part of MySensor core
    void before()
      Serial.println ("In before");
      //WiFi.mode(WIFI_AP);    // : set mode to WIFI_AP, WIFI_STA, or WIFI_AP_STA or WIFI_OFF
      //wifi_set_opmode_current(STATIONAP_MODE);
      //wifi_set_opmode_current(STATION_MODE);
      Serial.println("In Setup");
      // Send locally attach sensors data here
    C mppM 2 Replies Last reply
    • L lafleur
      IDE 1.6.13
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 2
      cnt
      void before()
      C Offline
      C Offline
      cbrum11
      @lafleur I am having almost an identical problem. Did you ever find a solution for this?
      • L lafleur
        IDE 1.6.13
        scandone
        state: 0 -> 2 (b0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 2
        cnt
        void before()
        mppM Offline
        mppM Offline
        mpp
        wrote on last edited by mpp
        @lafleur I also see "pm open,type:2 0". Did you happen to install the ping pong sketch?
        probably not related but I'm using an RFM69 with the ESP8266.
        ..ip:192.168.0.219,mask:255.255.255.0,gw:192.168.0.1
        .IP: 192.168.0.219
        IP: 192.168.0.219
        0;255;3;0;9;MQTT connected
        pm open,type:2 0
        MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
        • M Offline
          M Offline
          Matthew Ohlson de Fine
          I am also experiencing this using Sonoff relay sketch for ESP8266, any news on how to fix it?
          • mfalkviddM Offline
            I had a similar problem with MySensors >= 2.1.0. Switching to 2.0.0 made it go away. Maybe worth trying, at least to verify if 2.1 has a problem.
            The gateway rebooted every time a node sent a message.
            0;255;3;0;9;332 MCO:BGN:INIT GW,CP=RNNGE---,VER=2.2.0-beta
            0;255;3;0;9;338 TSF:LRT:OK
            0;255;3;0;9;341 TSM:INIT
            0;255;3;0;9;343 TSF:WUR:MS=0
            0;255;3;0;9;351 TSM:INIT:TSP OK
            0;255;3;0;9;354 TSM:INIT:GW MODE
            0;255;3;0;9;357 TSM:READY:ID=0,PAR=0,DIS=0
            0;255;3;0;9;361 MCO:REG:NOT NEEDED
            0;255;0;0;18;2.2.0-beta
            0;255;3;0;9;364 MCO:BGN:STP
            force slp enable,type: 2
            fpm open,type:2 0
            s2
            0;255;3;0;9;4902 MCO:BGN:INIT OK,TSP=1
            0;255;3;0;9;38508 TSF:MSG:READ,1-1-0,s=5,c=1,t=16,pt=1,l=1,sg=0:1
            1;5;1;0;16;1
            Fatal exception 3(LoadStoreErrorCause):
            epc1=0x4021dca2, epc2=0x00000000, epc3=0x00000000, excvaddr=0x40234734, depc=0x00000000
            Exception (3):
            epc1=0x4021dca2 epc2=0x00000000 epc3=0x00000000 excvaddr=0x40234734 depc=0x00000000
            ctx: cont
            sp: 3ffefc00 end: 3ffeff70 offset: 01a0
            Y 1 Reply Last reply
              fpm open,type:2 0
              s2
              1;5;1;0;16;1
              Exception (3):
              ctx: cont
              Y Offline
              Y Offline
              @mfalkvidd MySensors has a dependency for ESP8266 on the ESP Arduino version, as it duplicates the startup code.
              I'd suggest to try with MySensors 2.1.x and ESP8266 2.3.0 board support and fix any issues we run into.
              • M Offline
                M Offline
                I have tried to use 2.0 but still get the same response: pm open,type:2 0 in serial monitor. strangely I get no other serial responses, just that. Do I have to set debug on in the board settings?
                I can ping the sonoff so I know it's connected. What am I missing?
                mppM 1 Reply Last reply
                • M Matthew Ohlson de Fine
                  mppM Offline
                  mppM Offline
                  mpp
                  See this remark:
                  @tekka said in MySensors 2.0.0 Released:
                  @mpp said in MySensors 2.0.0 Released:
                  pm open,type:2 0
                  This is a message emitted by the ESP8266 core, not MySensors related.
                  I suggest you add the following to enable debugging on the serial interface:
                  Also tripple check your wiring, it seems to make the ESP very unstable if there's a loose/bad connection. TSM:FAIL:CNT could indicate a problem with the radio/transmission.
                  12.2k
