  3. Node-RED
  4. Node-Red ESPeasy and RF24 talking each other
Scheduled Pinned Locked Moved Node-RED
5 Posts 2 Posters 3.2k Views 2 Watching
    Surbyte
    I am using Node-Red under RPi with some ESP8266 nodes working with ESPEasy exchanging MQTT messages.
    Because there still are 5 nodes out of WIFI range, i decided to use some nRF24 with PA and LNA. I know that i could use some Extended WIFI Range devices but we must forget this option for now.
    I was reading Mysensors and found that ESP8266 Gateway might be a bridge between RF24 telegrams and Nodered.
    Am i right or am I forgetting something?
      Yes, you can make an esp8266 ethernet gateway that is supported by node red
        Surbyte
        I found a solution to my problem. Just i had to read a little more.
        Node-red is working fine with ESPEasy as firmware of ESP8266-12 over WIFI.
        Then i added a Bridge using a ESP8266 Gateway.
        I downloaded MySensors 2.1.0 library and built each new sketchs.
        I had to learn about how to program them using examples. It was easy.
        Then add node-red mysensor module to RPi and I wrote the flows. Easy too.
        My new system is mixing ESPEasy and RF24 with MySensors and is working under Node-Red.
          Can you share something about your flow?
            Surbyte
            Ok I'm going to share my solution but mixs too many things.
            Node-red with MySensors module installation
            ESPEasy for nodemcus
            MySensors for Arduino NANO + nRF24L01
            I will edit this post to add flow and codes.
