  2. Announcements
  3. πŸ’¬ Building a Raspberry Pi Gateway
  • M marceloaqno
    I forgot to mention in the guide:
    To communicate with the RPi using the RFM69 radio, all of your nodes need to use the new RFM69 driver available in the development branch.
    To make the change, add the following line to the node sketch:
    #define MY_RFM69_NEW_DRIVER
    @marceloaqno you forgot just a little little insignificant detail πŸ˜‚
      marceloaqno
      Code Contributor
      @gohan @ftw64 sorry for all the trouble
        It's OK, don't worry. We need to update the guide with the new instructions πŸ˜€
          marceloaqno
          Code Contributor
          @gohan Done!
          • F
            F
            ftw64
            @marceloaqno Thanks! That indeed does the trick! And no worries, it is my own decision to play with beta(!) code (and it was a fun weekend troubleshooting it - I learned a lot about the structure of the MySensors code)!
            Only 'bad' thing is that 2.2.0 is not compatible with my existing nodes :-).
            I appreciate all the work that has been put into MySensors.
            • Fat FlyF
              Fat FlyF
              Fat Fly
              This is really stupid. :D RFM69 radio need powered separately ?
                They shouldn't, but it's always a matter trying πŸ˜€
                • O
                  O
                  Oliver Acevedo
                  • Richard van der PlasR
                    How will this work with HASS running on the same pi ?
                    Fat FlyF 1 Reply Last reply
                      It's the same as it was running on separate hw, you will only set ip address of the gateway in hass
                        so i can attach the NRF24L01+ to the pi running HA, make it a Ethernet Gateway and point to his own ip adress ?, will this be a long job with converting from a USB connected GW (Arduino with local sensors ? )
                          That's pretty much it. I don't know what is your current setup and what sensors you have, but is should not be a long job. Anyway you can install the ethernet gateway and when you are done you take care of the sensors
                            excellent, will the cpu utilisation be much higher that with a usb connected gw ?
                              No, it uses very few cpu
                              • manulM
                                manulM
                                manul
                                @Richard van der Plas: I strongly recommend to use MQTT instead of Ethernet gateway, as it is a standard way for 2 processes to communicate, and platform-agnostic.
                                HASS comes with an embed MQTT broker taht works out of the box.
                                Plus:
                                • you can easily mock either your sensors network or your controller
                                • it does support secure communication
                                • you can add other clients to observe the event, e.g. to log what is coming from/what is sent to the gateway
                                  I suggested ethernet because it's easier to setup and configure, mqtt is the next step.
                                  • P
                                    P
                                    pettib
                                    Hi
                                    I also have problem to get the NRF24L01+ chip to work with the RPi3.
                                    I find that the masterbranch don't recognize the board as RPi3 and sets SoC and Type as unknown.
                                    But if i take development branch itΒ΄s detecting RPi3 and seems to work correct.
                                    This is result from development Branch configure:
                                    [OK] SPI driver detected:BCM.
                                    [OK] Finished.
                                    This is result from Master Branch configure:
                                    [OK] Finished.
                                    This is the result from cat /proc/cpuinfo:
                                    Hardware : BCM2835
                                    Revision : a02082
                                    //Peter
                                      That's odd, I have the 2.1.1 compiled on mine rpi 3
                                        marceloaqno
                                        Code Contributor
                                        wrote on last edited by marceloaqno
                                        #456
                                        @pettib @gohan There have been some changes in /proc/cpuinfo in newer versions of kernels which leads to a wrong detection.
                                        The problem was fix in #827 and will be available in the master branch in the next mysensor release.
                                          I'm using dietpi and I compiled it like 2 weeks ago..
                                          With your input, this post could be even better πŸ’—
