  3. OpenHAB
  4. Can't link rfid node item
13 Posts 3 Posters 5.3k Views 3 Watching
  • ben999B
    ben999B
    ben999
    Hi
    I found this... :
    https://github.com/eclipse/smarthome/pull/2033/commits/008b4871ef308ae67400fe039e51e104fa061d83
    But what can i do with that?
    Seems to me that the file in question is some kind of install file that doesn't exist on my gateway as it is, right?
    Thanks for your help
    • ben999B ben999
      Hi
      I found this... :
      TimO
      Hi @ben999 !
      The fix you've mentioned was already merged into ESH and because of the date (23. Aug 2016) I'm pretty sure it is already merged into OpenHAB. So I suppose we need to search somewhere else.
      Please dump the complete log (in DEBUG mode) of the karaf console starting from the presentation messages arriving at the gateway till the message in your first post. I'll then try to reproduce the behaviour.
      Greetings
      Tim
      ben999B 1 Reply Last reply
      • T TimO
        Hi @ben999 !
        Greetings
        Tim
        ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        Hi @TimO
        My digital Knight coming (once again) to save me :blush:
        I logged into karaf (mysensors debug).
        That is when powering my rfid node (nano 328+nRF+RC532+relays)
        21:37:09.617 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:37:19.543 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;0;0;17;2.1.1
        21:37:19.566 [DEBUG] [ternal.handler.MySensorsThingHandler] - Setting last update for node 2 to 2017-05-09T21:37:19.554+0200
        21:37:19.567 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;6;0
        21:37:19.570 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - I_CONFIG request received from M, answering: (is imperial?)false
        21:37:19.573 [DEBUG] [rs.internal.protocol.MySensorsWriter] - Sending to MySensors: 2;255;3;0;6;M
        21:37:19.589 [INFO ] [marthome.event.ItemStateChangedEvent] - MySensorsDevice21_LastUpdate changed from NULL to 2017-05-09T21:37:19.554+0200
        21:37:19.595 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;11;RFID Lock
        21:37:19.609 [INFO ] [marthome.event.ItemStateChangedEvent] - hallUpdate01 changed from NULL to 2017-05-09T21:37:19.554+0200
        21:37:19.618 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:37:19.627 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;255;3;0;12;07.05.2017
        21:37:19.629 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;0;0;19;
        21:37:22.698 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;1;0;36;0
        21:37:29.619 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        That is when playing with a valid tag :
        21:37:49.622 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:37:58.475 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;1;0;36;1
        21:37:59.624 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:38:02.988 [DEBUG] [rs.internal.protocol.MySensorsReader] - 2;1;1;0;36;0
        21:38:09.625 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        And this is when i am in paperUI trying to link the "lock" item:
        21:38:49.631 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:38:59.360 [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP PUT request at 'items/MySensorsDevice21_Lock' with an invalid item type 'Status'.
        21:38:59.633 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        And lastly this is when i "unlink" the "lastupdate" item and link it again. Dunno if relevant...
        21:45:09.706 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:45:14.418 [INFO ] [smarthome.event.ItemRemovedEvent    ] - Item 'MySensorsDevice21_LastUpdate' has been removed.
        21:45:19.708 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:45:39.711 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        21:45:41.713 [INFO ] [smarthome.event.ItemAddedEvent      ] - Item 'MySensorsDevice21_LastUpdate' has been added.
        21:45:42.396 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'MySensorsDevice21_LastUpdate-mysensors:lock:65885f11:Lock_2_1:lastupdate' has been added.
        21:45:49.713 [DEBUG] [al.protocol.ip.MySensorsIpConnection] - Bridge is connected, connection skipped
        Once again, thanks a lot Tim for taking the time to look at that :)
        • ben999B ben999
          Hi @TimO
          TimO
          Hey @ben999 !
          Thanks for reporting and your patience!
          There was a bug in the binding. Please update your binding via IoT Marketplace or by replacing the jar with THIS version.
          • T TimO
            Hey @ben999 !
            ben999B
            ben999B
            ben999
            @TimO
            Smashing !!! You're an ace!
            How did you manage to spot the bug? Was it just applying to "Lock"?
            Anyway thank you very very much
            • ben999B ben999
              @TimO
              TimO
              @ben999
              It was a bug in the description of the lock thing. You seem to be the first one that is using this thing type. ;-)
              Here is the commit, I only had to change one word.
              It was easy to spot with your help!
              ben999B 2 Replies Last reply
              • T TimO
                @ben999
                ben999B
                ben999B
                ben999
                @TimO
                Great job, thanks again :smiley:
                I'm sure we all have weird setups :stuck_out_tongue_winking_eye:
                • T TimO
                  @ben999
                  ben999B
                  ben999B
                  ben999
                  @TimO
                  Dude, it's awesome :)
                  I even get a slider in paperUI to control the lock as well !!!
                  BUT... (there's alway's a "but")
                  Auto-discovery doesn't work anymore :cry:
                  Here is what i get from Karaf when clicking on "refresh" (in Inbox > MySensors Binding > Search )
                  21:50:27.220 [DEBUG] [.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
                  21:50:27.227 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                  No more hourglass... no searching...
                  Doc, i think we've lost it...
                  • ben999B ben999
                    @TimO
                    TimO
                    @ben999 :D
                    Well thank you again! That's an old bug and was totally overdue.
                    An internal cache that was only cleaned up on a restart of the binding was preventing a (re)discovery after a removal.
                    https://github.com/tobof/openhab2-addons/issues/39
                    • T TimO
                      @ben999 :D
                      ben999B
                      ben999B
                      ben999
                      @TimO
                      Thanks a lot :)
                      Having grown-up together with Windows got me used to reboot many time a day :laughing:
                      I think i did reboot a few times last night but not sure about the timing though... might have done so for other reasons. I just gave up on discovery and went on with "manual mode"
                      I will check tonight.
                      Thanks @TimO for looking after us so well ;)
                      12.5k
