  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 470.8k Views 30 Watching
  • alexsh1A alexsh1
    @Anticimex Commenting #include <drivers/ATSHA204/ATSHA204.cpp> did help, I can compile the sketch.
    However, have a different issue now:
    0;255;3;0;9;28181 Signing backend: ATSHA204
    0;255;3;0;9;28234 SHA256: 19332EC2AF4F753F8D2ED9F9B3039897BDD3D5B847D7C3DB01907B97F80B064C
    0;255;3;0;9;28245 Will not sign message for destination 4 as it does not require it
    0;255;3;0;9;28303 !TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:19332EC2AF4F753F8D2ED9F9B3039897BDD3D5B847D7C3DB01
    0;255;3;0;9;28313 Failed to transmit nonce!
    0;255;3;0;9;29922 TSF:MSG:READ,4-4-0,s=2,c=1,t=1,pt=2,l=2,sg=1:46
    4;2;1;0;1;46
    AnticimexA
    AnticimexA
    Anticimex
    @alexsh1 That is a radio issue. You have NACK on !TSF:MSG:SEND.
    AnticimexA alexsh1A 2 Replies Last reply
    • AnticimexA Anticimex
      AnticimexA
      AnticimexA
      Anticimex
      @tbowmo We probably should conditionally include drivers/ATSHA204/ATSHA204.cpp based on the MY_SIGNING_ATSHA204 flag. Otherwise the ATSHA204.cpp file will be included in multiple places if ATSHA204 signing is enabled in the gw.
        alexsh1A
        alexsh1A
        alexsh1
        @Anticimex it says
        0;255;3;0;9;156987 TSF:MSG:READ,4-4-0,s=2,c=1,t=1,pt=2,l=2,sg=1:45
        4;2;1;0;1;45
        0;255;3;0;9;169466 Verification timeout
        Shall I try to increase timeout?
        AnticimexA 1 Reply Last reply
        • alexsh1A alexsh1
          @Anticimex it says
          4;2;1;0;1;45
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 First you have to resolve the NACKs. It will not help to increase the timeout if messages never arrive.
          alexsh1A 1 Reply Last reply
            alexsh1A
            alexsh1A
            alexsh1
            @Anticimex I think I have resolved it by changing this:
            to
            0;255;3;0;9;44594 Signing backend: ATSHA204
            0;255;3;0;9;44647 SHA256: CF003C2C5580A69303207910E37DA55E6A4B0C78B671218C3BEF40B895658B9D
            0;255;3;0;9;44658 Will not sign message for destination 6 as it does not require it
            0;255;3;0;9;44671 TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:CF003C2C5580A69303207910E37DA55E6A4B0C78B671218C3B
            0;255;3;0;9;44681 Transmitted nonce
            0;255;3;0;9;44951 TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=1:55.2
            One node is still bad - I'll change the radio and test it again.
            • alexsh1A alexsh1
              to
              AnticimexA
              AnticimexA
              Anticimex
              @alexsh1 :+1:
                @alexsh1 :+1:
                alexsh1A
                alexsh1A
                alexsh1
                @Anticimex
                Do you think that I may have verification timeout due to having a mixture 2.1.1 and 2.2.0?
                0;255;3;0;9;124541 Signing backend: ATSHA204
                0;255;3;0;9;124594 SHA256: 9CEF656D53F4C3722D72AE17346E310BD300161FAB992261DD5216C08D0D7950
                0;255;3;0;9;124605 Will not sign message for destination 16 as it does not require it
                0;255;3;0;9;124618 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:9CEF656D53F4C3722D72AE17346E310BD300161FAB992261DD
                0;255;3;0;9;124628 Transmitted nonce
                0;255;3;0;9;124799 TSF:MSG:READ,16-16-0,s=255,c=3,t=0,pt=1,l=1,sg=1:76
                16;255;3;0;0;76
                0;255;3;0;9;124809 TSF:MSG:READ,16-16-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
                0;255;3;0;9;124819 Signing backend: ATSHA204
                0;255;3;0;9;124872 SHA256: 326EB7828E5F02AB2F9FCE645FC5B7D2628DDD70FED64C78275AC1FA0D1C1AF5
                0;255;3;0;9;124883 Will not sign message for destination 16 as it does not require it
                0;255;3;0;9;124896 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:326EB7828E5F02AB2F9FCE645FC5B7D2628DDD70FED64C7827
                0;255;3;0;9;124906 Transmitted nonce
                0;255;3;0;9;125176 TSF:MSG:READ,16-16-0,s=0,c=1,t=38,pt=7,l=5,sg=1:2.9
                16;0;1;0;38;2.9
                0;255;3;0;9;137796 Verification timeout
                • alexsh1A alexsh1
                  @Anticimex
                  16;255;3;0;0;76
                  16;0;1;0;38;2.9
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alexsh1 Hm, it should not be a problem. Assuming your log snippet is from the GW, it basically says that it successfully transmit the nonce to your node as requested to, and then it expects the node to provide a signed message to the GW within a certain timeout. The node fails to do this within that time so the GW times out and will not accept the message if it arrives later on.
                  So there are two options;
                  1. The node takes too long to process the received nonce, sign the message and send it back (perhaps many repeater hops between node and gw, this can be resolved by increasing the signing timeout at the GW side).
                  2. The node does transmit the signed message but fails with a NACK. The GW will never see this message and therefore assumes the node did not send it and correctly times out.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    #397
                    @Anticimex On the node, changing nrf24l01+ orientation (I have two nrf24l01+ sockets) 90 degrees changed signing from
                    0;255;3;0;9;120620 Transmitted nonce
                    0;255;3;0;9;120630 TSF:MSG:READ,4-4-0,s=1,c=1,t=0,pt=7,l=5,sg=1:24.0
                    0;255;3;0;9;120644 Current nonce: 415DAB5FF6170E67F5B180ADC827C062D35CBF2DCE1B6B0264AAAAAAAAAAAAAA
                    0;255;3;0;9;120745 HMAC: 759A77B66BAC8F0AEA542685F4EA12DEB66B27FE15F57788F1D1022508984896
                    0;255;3;0;9;120756 Signature bad
                    0;255;3;0;9;120766 Signature verification failed!
                    0;255;3;0;9;120776 !TSF:MSG:SIGN VERIFY FAIL
                    0;255;3;0;9;120981 TSF:MSG:READ,4-4-0,s=2,c=1,t=1,pt=2,l=2,sg=1:70
                    0;255;3;0;9;120991 No active verification session
                    0;255;3;0;9;121001 Signature verification failed!
                    0;255;3;0;9;121011 !TSF:MSG:SIGN VERIFY FAIL
                    0;255;3;0;9;165728 Transmitted nonce
                    0;255;3;0;9;165944 TSF:MSG:READ,4-4-0,s=1,c=1,t=0,pt=7,l=5,sg=1:24.4
                    0;255;3;0;9;165958 Current nonce: BAC8828FEAAFB3A0C65DE6F8D4993E4D3D93F190B58AA3C737AAAAAAAAAAAAAA
                    0;255;3;0;9;166059 HMAC: 122222A7C324B3688BD98EC8EF9AD9557350B874CAB38F250A246EBB069805D3
                    0;255;3;0;9;166070 Signature OK
                    • alexsh1A alexsh1
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alexsh1 Looks like RF performance was significantly improved by that change.
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #399
                        @Anticimex It seems to me that 90% of all issues is actually RF.
                        Very annoying!
                        Thanks for your help!
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          I am using latest beta (2.2.0b). Does anyone know what this means in the log:
                          !SGN:NCE:GEN
                          I think this is related to signing
                          • alexsh1A alexsh1
                            !SGN:NCE:GEN
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @alexsh1 https://ci.mysensors.org/job/Verifiers/job/MySensors/job/development/Doxygen_HTML/group__MySigningDebugMessages.html
                            • alexsh1A alexsh1
                              !SGN:NCE:GEN
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @alexsh1 to be more specific; the backend failed to generate a nonce. If you use the soft backed, it did not initialize properly (and you should have a log entry for that failure as well).
                              If using atsha204a, it either failed init like described above, or it failed to communicate properly (which should also be visible in other failures in the log)
                                alexsh1A
                                alexsh1A
                                alexsh1
                                #403
                                @Anticimex Spot on -> there was a mistake :
                                #define MY_SIGNING_ATSHA204_PIN 3
                                and should have been
                                I was wondering why nonce was all zeros...
                                • alexsh1A alexsh1
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @alexsh1 excellent. Signing won't work well without proper communication with the chip :)
                                  I considered just hanging if that happened but decided it was a bit too harsh and might disguise the problem in case UART debug isn't enabled.
                                  • magpernM
                                    magpernM
                                    magpern
                                    wrote on last edited by magpern
                                    #405
                                    I cannot get my china USB to Serial device to work with the arduino boards, so I cannot program the board to run the personalization. As a work around a use a Arduino Uno board as the "USB to Serial" and now I can upload the sketch and the personalizer writes to serial output fine at 115200 baud.
                                    But, when it wants me to press SPACE, it responds with "Unexpected answer. Skipping lock."
                                    I tried an other sketch that does Serial.read() and echos back the result. It does not work at 115200 but works at 9600 baud. At 9600 I get char 32 back as SPACE, but 160 or 130 or 254 at 115200. Maybe the Uno board cannot handle 115200?
                                    So, question: Can the personalizer sketch be changed to use 9600 (or something slower than 115200)? I tried to change the Serial.begin(115200) to 9600, but it is still 115200.
                                    (of course, I can alter the code to bypass the press SPACE to press any key, but I want to get to the bottom with the problem)
                                    AnticimexA mfalkviddM 3 Replies Last reply
                                    • magpernM magpern
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @Magnus-Pernemark
                                      Question 1: so you run stable release or beta?
                                      Answer 1: yes you can change baud rate but it is handled differently between stable and beta.
                                      • magpernM magpern
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @Magnus-Pernemark there is a configuration switch to disable UART verification you can use
                                        • magpernM magpern
                                          @Magnus-Pernemark which version are you using?
                                          The development version from github supports
                                          #define MY_BAUD_RATE 9600
                                          at the start of the sketch.
                                          The 2.1.1 version has
                                          in the sketch. Just change that.
                                          magpernM 1 Reply Last reply
