  2. Announcements
  3. 💬 Distance Sensor
💬 Distance Sensor
92 Posts 18 Posters 52.4k Views 18 Watching
  • jjkJ jjk
    o.k. folks, here's another update. Thanks to a number of rainy days, I have worked on the setup in my lab environment, even got myself a fritzing pcb to make things a bit more stable. Indoors, with a new sensor, things worked out o.k., the readings were stable. With the sun back in our area, brought everything out to the tank. First finding: I proved the sensor that was still out there was faulty! Now everything is installed, readings are transmitted every 15 minutes. That's the good news. The bad news is, the readings are again not consistent! The following is a list of the last 20 or so readings:
    120
    86
    82
    84
    85
    67
    85
    80
    84
    126
    84
    85
    84
    60
    85
    51
    82
    I'd be happy with the "around 85cm" readings, but the other ones really bug me. Anyone has a clue what can cause that? Has anyone ever experienced something similar?
    Boots33B
    Boots33B
    Boots33
    wrote on last edited by Boots33
    #33
    @jjk said in 💬 Distance Sensor:
    You may need to run a waterproof ultrasonic sensor as condensation inside the tank will probably affect unsealed units. I have found the DYP-ME007 units work well for tank sensors.
    Power supply is critical for the ultrasonic sensor. In testing i could only get stable readings from the DYP out to just over 1m when the circuit was running from my computer usb port. When i ran the same from a stable 5v supply it all worked as it should.
    The two best filtering methods for ultrasonic sensor are to:
    A: check for a number of identical readings in a row before transmitting the reading or
    B: use median filtering to obtain a stable reading
    if you are using the newping library it has median filtering built in and is very easy to use. See the sketch in my tank sensor project to see how.
    • jjkJ
      jjkJ
      jjk
      @Boots33 thanks for your detailed response! Is the DYP-ME007 the same as the JSN-SR04? As my experience with the latter is not too exciting... Anyways, I might as well give it another try! Also, thanks for the lead to your project and the median filtering in newping. I will definitely look into that and might just have to increase the number of readings the node takes and than filter for a transmission every 15 mins or so.
      Boots33B 1 Reply Last reply
      • jjkJ jjk
        Boots33B
        Boots33B
        Boots33
        They certainly look the same but not sure if they are identical. definitely check on the power, i went around in circles for a while and was nearly ready to give up on the DYP until i found they are very fussy on voltage. at 4.7v I could not get mine to be stable over 1.2m yet it was still rock solid under 1.2m.... nearly drove me crazy :)
        • jjkJ
          jjkJ
          jjk
          @Boots33 o.k. that's good advice! I just ordered some DYP and they have a bit of a lead time, that gives me time to think about getting an extra and stable 5V to the sensor.
          • jjkJ jjk
            zboblamontZ
            zboblamontZ
            zboblamont
            @jjk The JSN-SR04 looks very similar to the DYP-ME007 sensor, but what I found even more confusing is that there is a direct board mounted single transducer type advertised under the same type number for both models numbers when you do a search. As Boots33 has said and not the first to say it, these seem very voltage 'fussy'. I was about to order a JSN-SR04T variety to test out when I spotted this exchange. If you still have the JSN version would it not be worth trialling with a beefier supply as a test? I am most curious if this a case of voltage/current rather than faulty device.
            I would suggest a 5v booster in your own scenario running off two AAs, they are cheap enough these days...
            • jjkJ
              jjkJ
              jjk
              @zboblamont, excellent idea, but unfortunately my previous tries with the JSN-SR04T were in a "previous life" of arduino experimenting quite a while ago and at the time, I dumped pretty much most of it (I hate to say, the JSN failures were one if the reasons...). That said, I have ordered some DYP and will give it another try. The tips you and @Boots33 have provided should get me much farer than last time ;) The key information I guess I was missing at the time was the sensitivity to voltage.
              On another note... has anyone played around with alternative ways to measure water level, like a pressure tube or so? I'd be interested to see if that's an easier way, maybe?!
              zboblamontZ Boots33B 3 Replies Last reply
              • jjkJ jjk
                zboblamontZ
                zboblamontZ
                zboblamont
                @jjk Fair enough. It will be interesting nevertheless to see how you get on with the newer version now you are looking at voltage, it does seem sensitive to power, both in volts and current (however small the latter).
                I had a long look at pressure sensors before looking again at ultrasonics, and it is almost impossible to strike a balance between submerged IP68 and cheap. Closest I found were differential sensors (loads of them available from RS, Mouser, etc. to very low mBar ratings) but the problem was always the correspondence between measuring fluid pressure as air pressure. At a near constant temperature there should be no issues, but where you have the pressure vary as it must between -20 and + 45c environmental temperature throws out accuracy, ignoring gassing off.
                For sewage only non-contact works, for clean water, DP cells can work but only under consistent environmental circumstances. Submerged low pressure cells should work, if you find a cheap one post it up....
                • jjkJ jjk
                  Boots33B
                  Boots33B
                  Boots33
                  That's the spirit. My tank sensor using the DYP has been running for a few months now and is performing very well so far. During our summer we had daytime temperatures well over 40 deg c and the readings remained stable. So I think the DYP is up to the task.
                  • Boots33B Boots33
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @Boots33 So it seems on balance from the above experiences that the DYP sensor is proven reliable in use once given good voltage but questions remain on the JSN. The DYP type is not so readily available at reasonable cost over here so will order up a JSN and trial it. If it fails at least it is only $10 wasted, if not, it will answer this puzzle.
                    • zboblamontZ zboblamont
                      Boots33B
                      Boots33B
                      Boots33
                      @zboblamont It will be good to see the final results of both yours and @jjk
                      zboblamontZ 2 Replies Last reply
                      • Boots33B Boots33
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @Boots33 Still waiting on the gateway to arrive, as well as the DYP sensor, so had a go at assembling the electronics. Having red elsewhere about potential interference between a booster and ultrasonic, have mounted the booster with the ground plane facing the board and direct mounted onto the SR04T (I see this is 2.0 version which reportedly gave problems before). Although it works electrically with 3v firing the bistable relay feeding the booster feeding the SR04T, and switches off fine, any opinions on the proximity issues?
                        • jjkJ jjk
                          zboblamontZ
                          zboblamontZ
                          zboblamont
                          @jjk Well I think I am done trying to get this JSN-SR04T-2.0 to work, tried different versions of ping and newping, as well as other sketches from suppliers of this device, but got no joy at all. Even separated the 5v booster in case of potential interference, no joy whatsoever.
                          Recent complaints on supplier sites seem to confirm problems persist for this version 2.0, and on one site there was a note "Note: Version 2.0 requires echo pin to be pulled up to VCC. A 4.7K to 10K resistor can be used as pull-up resistor."
                          Fat lot of use that is to me with a 3.3v unit, and if it needs a dedicate sketch to work, good luck with those sales..
                          I guess I can only wait on the DYP to arrive now....
                            Boots33B
                            Boots33B
                            Boots33
                            @zboblamont Still no luck with the JSN unit I see. Hope the DYP unit will bring better results.
                            • Boots33B Boots33
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @Boots33 It seems that the newer version (2.0) is the one giving problems, the previous version did not. Presumably the sensor head is unchanged and common across all of them, so perhaps not a total waste of $10.
                              It will be interesting to see if mounting the 5v booster so close on the DYP causes any issues, as it makes for a compact arrangement in a corner of a box.
                              As an aside, with one of these heads needed in a sewage tank I needed a robust holder. The sensor head is a snug fit in the big end of a 3/4" to 1/2" GS tube reducer, giving both protection and rigidity.
                              • ArthurA
                                ArthurA
                                Arthur
                                I have tried to compile this sketch, but it fails, see error below. Any idea what's the reason and how it can be fixed ?
                                I use the latest Arduino 1.8.3 (windows) version, mysensors 2.x and the above NewPing library.
                                C:\Users\arthur\AppData\Local\Temp\ccAlQHJ9.ltrans2.ltrans.o: In function `setup':
                                Y:_Domotica\NRF24L01\DistanceSensor/DistanceSensor.ino:53: undefined reference to `getControllerConfig()'
                                exit status 1
                                Fout bij het compileren van board Arduino/Genuino Uno
                                • ArthurA
                                  ArthurA
                                  Arthur
                                  Fixed the problem by changing some code:
                                  // metric = getControllerConfig().isMetric;
                                  • Boots33B Boots33
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @Boots33 Now I am flummoxed.... Got the DYP unit and yet, no difference in responses.... I can only conclude this has to be a hardware or device issue, as I checked all wiring (unless I missed something really stupid), tried the same 6 sketches even on a spare 3v3 device with the same result. Now ordered up a couple of Pro-Mini 5v to check out whether this is a 5v related issue since I cannot create a timed response otherwise, nothing makes sense with respect to the ultrasonic units now otherwise unless my earlier information that 3v3 was sufficient to trigger the device was wrong... Time for a slow drink, a long smoke, and shout abuse at passing dogs.... Nice weather, 26c, Friday, what's not to smile about.... Ah, Port..
                                    • Boots33B Boots33
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @Boots33 Well, finally I got some positive results, but not quite as expected...
                                      The JSN-SR04T-2.0 nor the DYP-ME007Y I could get to work on all six variations of sketches tried. Still not sure why neither would work using this 3v3 board even with 5v to the ultrasonic board and dropper resistors on the echo. Allegedly the ping from 3.3v should work.
                                      So, bought and finished today trialling a 5v/16MHz Pro-Mini ;
                                      The JSN version 2.0 nor the DYP would not respond to NewPing, simply churning out zeroes.
                                      Other sketches would turn out fixed numbers and zeroes which did not alter irrespective of the transducer/object distance.
                                      The JSN finally got working with a simple PulseIn calculation loop with a 500 delay. First reading was always Zero, all the rest consistent and rock solid.
                                      The DYP unexpectedly responded only to the SoftwareSerial method originally found to work from a Russian site. The readings are spot on from the start.
                                      Now that they work, I need to figure out if there is a workaround for the 3.3v transceiver node....
                                      Phew....
                                        Phew....
                                        Boots33B
                                        Boots33B
                                        Boots33
                                        @zboblamont it certainly has been a bumpy road for you. good to see you making some headway.
                                        • ben999B
                                          ben999B
                                          ben999
                                          wrote on last edited by ben999
                                          #52
                                          I've been fighting with DYP-ME007Y myself for the last few days...
                                          Originally i wanted to monitor the level of a water tank with an SR04 ; as it is not waterproof i assumed that it would die fairly quickly.
                                          So i ordered a DYP-ME007... but the last letter ("Y") means that it uses serial communication, so the ping Library doesn't apply.
                                          Bouncing from site to site i found the following code that @zboblamont refers to :
                                          #include <SoftwareSerial.h>
                                          SoftwareSerial mySerial =  SoftwareSerial(10,11);
                                          #define echoPin 10
                                          #define trigPin 11
                                          unsigned int reading;
                                          byte readByte;
                                          byte read_buffer[4];
                                          byte crcCalc;
                                          word distance;
                                          String outText;
                                            mySerial.begin (9600);
                                            Serial.println("start");
                                            for (byte loopstep = 0; loopstep <= 3; loopstep++) {
                                              read_buffer[loopstep] = 0;
                                            if (mySerial.available() < 1) {
                                              return;
                                            readByte = mySerial.read();
                                            for (byte loopstep = 0; loopstep <= 2; loopstep++) {
                                              read_buffer[loopstep] = read_buffer[loopstep + 01];
                                            read_buffer[03] = readByte;
                                            if (read_buffer[00] != 0xff) {
                                              return;
                                            crcCalc = read_buffer[00] + read_buffer[01] + read_buffer[02];
                                            if (read_buffer[03] != crcCalc) {
                                              return;
                                            distance = (read_buffer[01] * 0xff) + read_buffer[02];
                                            outText = "bytes: ";
                                            outText = String(outText + read_buffer[00]);
                                            outText = String(outText + "+");
                                            outText = String(outText + read_buffer[01]);
                                            outText = String(outText + read_buffer[02]);
                                            outText = String(outText + read_buffer[03]);
                                            outText = String(outText + " = ");
                                            outText = String(outText + distance);
                                            outText = String(outText + " mm");
                                            Serial.println(outText);
                                            delay(1000);
                                            while (mySerial.available() > 0) {
                                          Worked first shot
