  3. Driveway motion light
8 Posts 2 Posters 4.5k Views 3 Watching
  • dbemowskD
    dbemowskD
    So my latest project has been to replace an X-10 FloodCam (VT38A) motion sensor light controller with a MySensorized controller. I had been having some problems with the light getting stuck on for very long periods of time. The other issue was that this, like a lot of my other X-10 modules, I couldn't get a status reading from it, which was annoying. It had a built in camera which was wireless, but you needed an X-10 receiver to use it, and where I had my equipment, the picture was crappy at best.
    I had some relay modules that were given to me by a friend, so I thought I would use one on this node. The node has 3 parts, the motion sensor, an LDR sensor, and the relay module. The concept is simple. The LDR is used to detect dusk/dawn to only allow the motion to turn on the relay/light when it is dark outside. I had a project box that I bought a while back for another project that I never used, so I figured this was the perfect project for it, but the trick was making everything fit.
    The relay module was a 12 volt module, so I needed a 12 volt supply. I opted for the HiLink HLK-PM12. On the 5 volt pro mini that I was using, the regulator would get quite hot with 12 volts on the RAW input, so I decided to use a second regulator (LM7808) to drop the RAW voltage from 12 to 8 volts. It meant that I was regulating the voltage twice, but it worked well.
    I took the old mounting tube off of the old floodcam and used it on the new setup. That now lets me swivel and point the sensor box to wherever I need it. It also lets me run my 120 volt power wires into the light assembly. The power wires are:
    • Black - Hot
    • White - Neutral
    • Blue - Switched hot for lights
    One other thing that can't be seen in the pics is that I put hot glue over most of the screws and nuts that were coming out of the plastic case. I did this to help prevent them from getting wet and rusting. I did this at the last minute before I installed it which is why it can't be seen in the pics.
    Here are some pics of the setup.
    BoardsPartially assembledClosed assemblyFull assembly
    • dbemowskD
      dbemowskD
      For those interested, here is version 1.0 of the code written for MySensors 2.0. This presents all 3 devices to the controller, in my case Domoticz.
       * Version 1.0 - Henrik Ekblad
       * Example sketch showing how to control physical relays.
       * This example will remember relay state after power failure.
       * http://www.mysensors.org/build/relay
      //Set up the nRF24L01+
      #define SKETCH_NAME "Driveway motion light"
      #define SKETCH_VERSION "1.0"
      #define RELAY_PIN       3  // Arduino digital I/O pin for the relay
      #define LIGHT_LEVEL_PIN A0 // Arduino analog I/O pin for the light level sensor
      #define MOTION_PIN      5  // Arduino digital I/O pin for the motion sensor
      #define RELAY_ID        1 // Relay child ID
      #define LIGHT_LEVEL_ID  2 // Light level sensor child ID
      #define MOTION_ID       3 // Motion sensor child ID
      #define RELAY_ON        1  // GPIO value to write to turn on attached relay
      #define RELAY_OFF       0 // GPIO value to write to turn off attached relay
      // Sleep time between reads (in milliseconds)
      unsigned long SLEEP_TIME = 100000;
      unsigned long T = 1;
      // Initialize light relay
      MyMessage relay_msg(RELAY_ID, V_LIGHT);
      // Initialize light sensor
      MyMessage light_level_msg(LIGHT_LEVEL_ID, V_LIGHT_LEVEL);
      // Initialize motion message
      MyMessage motion_msg(MOTION_ID, V_TRIPPED);
      int lastLightLevel;
      bool lastMotion;
      int relay;
      int lastRelay;
       * presentation - Present the garage door sensor
        sendSketchInfo( SKETCH_NAME, SKETCH_VERSION );
        // Register the relay to the gateway
        present(RELAY_ID, S_LIGHT);
        // Register the light level sensor to the gateway
        present(LIGHT_LEVEL_ID, S_LIGHT_LEVEL);
        // Register the motion sensor to the gateway
        present(MOTION_ID, S_MOTION);
      } //End presentation
        pinMode(RELAY_PIN, OUTPUT);
        // Flash the relay 4 times to indicate initialization
        for ( int i = 0; i < 4; i++) {
          digitalWrite(RELAY_PIN, RELAY_ON);
          delay (500);
          delay (500);
        relay = loadState(RELAY_ID) ? RELAY_ON : RELAY_OFF;
        digitalWrite(RELAY_PIN, relay);
        // Define the LDR pin for analog input
        pinMode(LIGHT_LEVEL_PIN, INPUT);
        // Define the motion sensor pin for digital input
        pinMode(MOTION_PIN, INPUT);
      } //End setup
        // Read digital motion value
        bool motion = digitalRead(MOTION_PIN) == HIGH;
        if (motion != lastMotion) {
          // Send tripped value to gw
          send(motion_msg.set(motion ? "1" : "0"));
          lastMotion = motion;
        // Read the value measured from the LDR
        int16_t lightLevel = analogRead(LIGHT_LEVEL_PIN)/10.23;
        if (lightLevel < 10 && motion && relay == RELAY_OFF) {
          send(relay_msg.set(RELAY_ON));
          relay = RELAY_ON;
        } else if (!motion && relay == RELAY_ON) {
          send(relay_msg.set(RELAY_OFF));
          relay = RELAY_OFF;
        T++;
        if (T > SLEEP_TIME) {
          T = 1;
          Serial.print("Motion: ");
          Serial.println(motion);
          if ((lightLevel != lastLightLevel)) {
            send(light_level_msg.set(lightLevel));
            // Display the value in the serial monitor
            Serial.print("Light Level: ");
            Serial.println(lightLevel);
            lastLightLevel = lightLevel;
      } //End loop
        if (message.type==V_LIGHT) {
           // Change relay state
           digitalWrite(RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
           // Store state in eeprom
      } //End receive
      On the device, the motion sensor will only turn on the relay/light when the LDR lux level is below 10. This ensures that the light will only come on at night. However, with the presentation of all 3 devices to the controller, the device can be used for much more. With scripting, I can use the sensed lux level to do other functions based on the light level by my driveway if I want. Likewise, the motion sensor will still register motion to the controller so if at some point I install a camera outside to monitor my driveway and/or front door (which I plan to do). I can use the motion sensor to start the camera recording at any time. And last, I have manual control of the light if I need at any point in the day.
      Currently I have the light set to only turn on at a hard coded lux level of 10. If I find that this needs to be adjusted, I may modify the code so that I can set the lux threshold level from the controller using S_INFO or something similar and have it store that value at the device.
      • BeniKB
        BeniKB
        BeniK
        wrote on last edited by BeniK
        @dbemowsk Hi and thanks for the sketch! I don't know if you still using this setup - I tried it and it works flawlessly. But (there is always a "but"), I am having problems lighting up the relay when light levels drop. My LDR sensor reports light the opposite it needs to be reported; meaning I get 100 when no light at all and 0 light level when I shine a light into the sensor (full light situation).
        Surely I resolved the relay firing up thing by changing
        into
        if (lightLevel > 90 && motion && relay == RELAY_OFF)
        and the relay works, but I really love to use the right LDR Level on my Domoticz setup so a little help will be really appreciated.
        Is this something that my LDR sensor is faulty or is this something it could be resolved by modifying the sketch?
        Thanks in advance!
        dbemowskD 1 Reply Last reply
        • BeniKB BeniK
          into
          Thanks in advance!
          dbemowskD
          dbemowskD
          @BeniK Your LDR sensor is most likely not faulty. To invert the values read by the sensor, all you need to do is reverse how it is wired to your reference power. There are two ways to wire these:
          0_1497440065614_upload-7672eea9-9cac-4ea6-8162-2ac8d9dc0876 0_1497440096381_upload-30441621-11c7-4020-9b9e-6c0d869e738c
          I am pretty sure that you have yours wired like the first one. To invert the values, switch your + and - on the LDR voltage divider. Basically, which ever way you have it wired, wire it the other way and my code should work.
          Here is a great page that explains using LDRs with an arduino. https://learn.adafruit.com/photocells/using-a-photocell
          BeniKB 1 Reply Last reply
          • dbemowskD dbemowsk
            BeniKB
            BeniKB
            BeniK
            @dbemowsk Thnk You very much for your help!
            Yhe sensor breakout board I am using is this one on the pictures. Is there any way to modify it or do I have to build my own LDR Sensor board? I so, what R1 value do you think is best?
            Thanks again!!
            • BeniKB BeniK
              Thanks again!!
              dbemowskD
              dbemowskD
              @BeniK Try this simple code change:
              change this line:
              to this:
              int16_t lightLevel = 100-(analogRead(LIGHT_LEVEL_PIN)/10.23);
              I will explain this change so you can understand it. The analogRead analogRead(LIGHT_LEVEL_PIN) will return a value in the range of 0 to 1023. by dividing that by 10.23, that will give you a value from 0 to 100, the percentage of light. Because you are getting inverted values, subtracting the value read by 100 will invert it. So you could change the following line from 90 back to 10:
              if (lightLevel < 90 && motion && relay == RELAY_OFF) {
              because now that you are subtracting the value from 100, 100 - 90 = 10, and all should be good.
              Hope that makes sense.
                change this line:
                to this:
                BeniKB
                BeniKB
                BeniK
                @dbemowsk Yes, it makes sense and it works flawlessly !
                Thank You very much!
                • BeniKB BeniK
                  dbemowskD
                  dbemowskD
                  @BeniK Always glad to help
