  3. Wemos XI
Wemos XI
17 Posts 6 Posters 10.9k Views 9 Watching
  • korttomaK
    korttomaK
    korttoma
    Received som WeMos XI modules the other day and I tried to compile a sketch for it but I ran in to some trouble:
    WARNING: library MySensors claims to run on [avr architecture(s) and may be incompatible with your current board which runs on esp8266 architecture(s).
    • Tomas
    • korttomaK
      korttomaK
      korttoma
      Got a little bit further by adding the following to the sketch:
      #define ARDUINO_ARCH_ESP8266
      Now I get the following error:
      \Arduino\libraries\MySensors/core/MyMainESP8266.cpp:22:22: fatal error: Schedule.h: No such file or directory
       #include "Schedule.h"
      compilation terminated.
      exit status 1
      Error compiling for board WEMOS XI.
      I really don't know what I'm doing here but I will try adding the Schedule.h file from somewhere to somewhere...
      • Tomas
      • korttomaK
        korttomaK
        korttoma
        Adding the Schedule.h to the MySensors core library folder just makes it ask for the next thing that is missing so I think I will leave this to someone who knows what they are doing.
        • Tomas
        EfflonE 1 Reply Last reply
        • korttomaK korttoma
          EfflonE
          EfflonE
          Efflon
          @korttoma Why use ESP8266? isnt it 328 clone so you could use Mini pro in arduino ?
          • L
            L
            lorisc
            I got too myself some boards. XI is indeed a 382 clone, but it seems that the XI core library is missing yield() functionality.
            I managed to compile my mysensors sketch with first forcing the #define ARDUINO_ARCH_AVR in the sketch and
            with some modifications at the XI core library:
            • I added the void yield(void); somewhere in ..\ARDUINO\hardware\wemos\XI\cores\lgt8f\Arduino.h
            • I added the hooks.c file to ..\ARDUINO\hardware\wemos\XI\cores\lgt8f\ from https://github.com/arduino/Arduino/blob/master/hardware/arduino/avr/cores/arduino/hooks.c
            However i did not yet upload the sketch to the board, I'll later when I get home.
            korttomaK 1 Reply Last reply
            • L lorisc
              korttomaK
              korttomaK
              korttoma
              Thanks @lorisc ! I managed to compile my sketch with the changes you suggested. Going to wait for your test results before I load anything to my board.
              • Tomas
              • Nca78N
                Missed the post from @lorisc it would have saved me some time as I ended up doing the same modifications :)
                Uploaded to a board and connected NRF24 with the same pin numbers than on normal Arduino: it runs.
                Tested the sleep() function from MySensors but it's not so great at the moment, using 1.5mA, I'll have to check why.
                • Nca78N
                  wrote on last edited by Nca78
                  I have just tested the sleep modes from the examples supplied with the lgt8 core, and all I can say is it's pretty disappointing :(
                  Even in PM_POFFS1 mode which is the lowest power mode possible (only wakes up with external interrupt) it consumes over 80µA.
                  There must be some settings that can be improved to get closer to what the datasheet seems to claim, but it's pretty hard to guess how we are supposed to do that with a chinese language datasheet...
                  EDIT: when I force pins to OUTPUT + LOW the power consumption drops significantly, it's below 20µA now. If someone has some knowledge in Chinese to find out if/how we can disable ADC/SPI/... that could get interesting.
                  But without proper sleep functions the Xi loses most of it's interest as battery powered sensor (low minimal voltage, no regulator & power led to remove etc). Only interest at the moment would be the 2 DACs that the atmega doesn't have, but that's of very marginal interest for MySensors. It doesn't even have a cost advantage as it's only 0.30$ cheaper that pro mini but with shipping fee.
                    So is this board really not good for battery powered sensors?
                    Nca78N 1 Reply Last reply
                      @gohan said in Wemos XI:
                      IMHO not at the moment and I don't think it will change soon as doc from wemos or the chip manufacturer are still very poor.
                      I fail to see the interest of the this board compared to a pro mini clone, except saving 0.5$. There's no obvious way to make it really low power and you have a different pinout so you can't use any of the existing PCBs.
