  3. SOLVED: ESP8266 RFM69H Gateway
5 Posts 2 Posters 2.4k Views 1 Watching
  • O Offline
    O Offline
    Omemanti
    wrote on last edited by Omemanti
    Hey,
    I got a little question regarding my ESP RFM gateway. I think the PCB should be oke.
    I got the ESP working, i can connect to it though MYSController but Sensors dont report to it.
    So I think, I may messed up my sketch or the connections between the ESP and the RFM.
    Is there someone who can Judge this?
    I cleaned up the Diagram. I should have plenty of caps for the ESP and RFM to work, 100Uf for the chips, some 100nf for and after the regulators.
    The question is, are the connections oke?
    0_1499418297327_upload-82fa2a3e-7435-4db2-9015-f9b32aca7dcd
    The second is my Gateway sketch.
    #ifdef ESP8266
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RF69_868MHZ // Set your frequency here
    #define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_RF69_IRQ_PIN 5 // GPIO5
    #define MY_RF69_SPI_CS 15 // NSS
    I got this working on my NODEMCU but not on this PCB.
    If your willing to help out, that would be great!.
    Thnx.
    If I got it working, ill upload it to openhardware.io.
    13-7-2017: GPIO 4 & 5 are switched on the ESP12. changing the IRQ from 5 to 4 did the trick.
    • S Offline
      would be easier if you could post your gw logs ;)
      O 1 Reply Last reply
      • O Offline
        O Offline
        Omemanti
        • S scalz
          O Offline
          O Offline
          Omemanti
          Here it is:
          Last line is when connecting MYScontroller
          when I boot up the sensor (with new uploaded sketches..) it stays silent.
          When I connect my other gateway a couple of minutes later, it start showing up at my other controllers
          0;255;3;0;9;TSF:LRT:OK
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSF:WUR:MS=0
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          scandone
          f 0, scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 4
          cnt
          connected with ***************, channel 3
          ip:192.168.2.111,mask:255.255.255.0,gw:192.168.2.254
          .IP: 192.168.2.111
          0;255;3;0;9;MCO:BGN:STP
          pm open,type:2 0
          0;255;3;0;9;Client 0 connected
          • O Offline
            O Offline
            Omemanti
            Seems like the ESP-12 switches GPIO5 and GPIO4.
            Changing the the GPIO 5 => 4 did the trick:
            #define MY_RF69_IRQ_PIN 4 // GPIO5```
            12.2k
