  3. Orange PI zero. Problem running the gateway
9 Posts 3 Posters 3.3k Views 3 Watching
    moskovskiy82
    Have followed the instructions on creating the orange pi zero gateway.
    The only difference - i am running a dietPi OS (couldn't install armbian).
    Wired all as recommended and also have added the IRQ pin (GPIO10)
    Strangely enough didn't have to alter the bin2fex /boot/script.bin /tmp/orange.fex as it already contained the necessary information.
    Ran the config with the following options
    ./configure --spi-spidev-device=/dev/spidev1.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=13 --my-rf24-irq-pin=10 --my-gateway=ethernet --my-port=5003
    Everything compiled but upon launching got the
    # sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q-,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: Could not open /sys/class/gpio/gpio10/direction
    Tried
    #echo "10" |sudo tee /sys/class/gpio/export
    tee: /sys/class/gpio/export: Device or resource busy
    Any ideas on this would be much appreciated...
      moskovskiy82
      Tried to compile without IRQ pin. So there is no communication with the radio (tried different radio modules).
      Seems some problem with GPIO pins on DietPI?
        moskovskiy82
        # gpio readall
         +-----+-----+----------+------+---+-Orange Pi+---+---+------+---------+-----+--+
         | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
         |     |     |     3.3v |      |   |  1 || 2  |   |      | 5v       |     |     |
         |  12 |   8 |    SDA.0 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
         |  11 |   9 |    SCL.0 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
         |   6 |   7 |   GPIO.7 | ALT3 | 0 |  7 || 8  | 1 | OUT  | TxD3     | 15  | 13  |
         |     |     |       0v |      |   |  9 || 10 | 0 | ALT5 | RxD3     | 16  | 14  |
         |   1 |   0 |     RxD2 | ALT5 | 0 | 11 || 12 | 0 | ALT3 | GPIO.1   | 1   | 110 |
         |   0 |   2 |     TxD2 | ALT5 | 0 | 13 || 14 |   |      | 0v       |     |     |
         |   3 |   3 |     CTS2 | ALT3 | 0 | 15 || 16 | 0 | ALT3 | GPIO.4   | 4   | 68  |
         |     |     |     3.3v |      |   | 17 || 18 | 0 | ALT3 | GPIO.5   | 5   | 71  |
         |  64 |  12 |     MOSI | ALT4 | 0 | 19 || 20 |   |      | 0v       |     |     |
         |  65 |  13 |     MISO | ALT4 | 0 | 21 || 22 | 0 | OUT  | RTS2     | 6   | 2   |
         |  66 |  14 |     SCLK | ALT4 | 0 | 23 || 24 | 0 | ALT4 | CE0      | 10  | 67  |
         |     |     |       0v |      |   | 25 || 26 | 0 | ALT3 | GPIO.11  | 11  | 21  |
         |  19 |  30 |    SDA.1 | ALT4 | 0 | 27 || 28 | 0 | ALT4 | SCL.1    | 31  | 18  |
         |   7 |  21 |  GPIO.21 | ALT3 | 0 | 29 || 30 |   |      | 0v       |     |     |
         |   8 |  22 |  GPIO.22 | ALT3 | 0 | 31 || 32 | 0 | ALT3 | RTS1     | 26  | 200 |
         |   9 |  23 |  GPIO.23 | ALT3 | 0 | 33 || 34 |   |      | 0v       |     |     |
         |  10 |  24 |  GPIO.24 |  OUT | 1 | 35 || 36 | 0 | ALT3 | CTS1     | 27  | 201 |
         |  20 |  25 |  GPIO.25 |  OUT | 1 | 37 || 38 | 0 | ALT5 | TxD1     | 28  | 198 |
         |     |     |       0v |      |   | 39 || 40 | 0 | ALT5 | RxD1     | 29  | 199 |
         +-----+-----+----------+------+---+-Orange Pi+---+------+----------+-----+-----+
          try reinstalling wiringPi if you have updated the firmware after it was installed
            moskovskiy82
            wrote on last edited by moskovskiy82
            I took the plunge. And now ready to give up.
            Got out another sd card. Installed fresh armbian.
            Ubuntu server – legacy kernel
            Did nothing else to the installation. Than followed the guide step by step. No deviations. The only part that it is not clear in the manual - about configure options. I believe some will first run
            and then run
            ./configure --my-gateway=ethernet --my-port=5003
            Won't this overwrite the first config file? So just ran the first one.
            And no success.
            mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
            mysgw: TSF:LRT:OK
            mysgw: TSM:INIT
            mysgw: TSF:WUR:MS=0
            mysgw: !TSM:INIT:TSP FAIL
            mysgw: TSM:FAIL:CNT=1
            mysgw: TSM:FAIL:DIS
            mysgw: TSF:TDI:TSL
            mysgw: TSM:FAIL:RE-INIT
            mysgw: TSM:INIT
            mysgw: TSM:FAIL:CNT=2
            mysgw: TSM:FAIL:DIS
            mysgw: TSF:TDI:TSL
            ^Cmysgw: Received SIGINT
            Put some more solder on the connectors of OrangePi. No success. Put a 10uF 50V capacitor on the nrf24 - no success.
            Maybe something has change in the inner workings?
            P.S. On fresh armbian
            root@orangepizero:~/MySensors# gpio readall
            -bash: gpio: command not found
              you have to enable SPI in the dietconfig I think, the ./configure needs to be one single command and you need to add wiringPi in the dietpi-software
                moskovskiy82
                @gohan Thanks for helping out. Is SPI supposed to be enabled? Doesn't state it anywhere. Will try it out.
                Yes i also believe ./configure shoul be one line - it's just that documentation is not that clear for not tech guys like me. So if maintainer of the page is reading this - it should be better done like for the Raspberry gateway page. It's more clear.
                Will try the SPI - hope it helps.
                P.S. Have just reconnected the radio to my RPi3... So it's not necessary problem with myself ;) Will try to update the topic with OrangePi struggle
                RPI3 output
                sudo ./bin/mysgw -d
                mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                  Since you are using a SPI device, you need to enable SPI on the operating system, that's what I did for my rpi3 so I'm expecting the same for the orange pi
                  • M moskovskiy82
                    RPI3 output
                    sudo ./bin/mysgw -d
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    @moskovskiy82 said in Orange PI zero. Problem running the gateway:
                    I've updated the Orange Pi page. Thanks for catching this.
