  3. OpenHAB
  4. Help make Openhab2 MQ2 AirQuality work
9 Posts 3 Posters 3.8k Views 3 Watching
  • T Offline
    T Offline
    Tommas
    wrote on last edited by Tommas
    Dear All!
    I would like to configure my ethernet gateway + NODE 1 (DHT+MQ2) sensor node with openhab2
    Some friends from here helped to me , so i could create the node's sketch. The temperature+humidity works, but i cant make the mq2 sensor work. I use the airquality sketch for it mixed it with the temperaturehumidity sketch.
    The openhab get the value from the mq2 (based on the logs) but i cant display it on the website.
    I have just seen that based on this table Controller table the airquality is not supported in the openhab 2 + mysensors . Is it true?
    Node's sketch:
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    #define MY_NODE_ID 1
    // Enable debug prints
    //#define MY_RS485
    /* TemperatureAndHumidity */
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 5000;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    /*---------------------------------MQ2---------------------------------------------------------*/
    #define   CHILD_ID_MQ                   2
    /************************Hardware Related Macros************************************/
    #define   MQ_SENSOR_ANALOG_PIN         (0)  //define which analog input channel you are going to use
    #define         RL_VALUE                     (5)     //define the load resistance on the board, in kilo ohms
    #define         RO_CLEAN_AIR_FACTOR          (9.83)  //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
    //which is derived from the chart in datasheet
    /***********************Software Related Macros************************************/
    #define         CALIBARAION_SAMPLE_TIMES     (50)    //define how many samples you are going to take in the calibration phase
    #define         CALIBRATION_SAMPLE_INTERVAL  (500)   //define the time interal(in milisecond) between each samples in the
    //cablibration phase
    #define         READ_SAMPLE_INTERVAL         (50)    //define how many samples you are going to take in normal operation
    #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
    //normal operation
    /**********************Application Related Macros**********************************/
    #define         GAS_LPG                      (0)
    #define         GAS_CO                       (1)
    #define         GAS_SMOKE                    (2)
    /*****************************Globals***********************************************/
    //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
    unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
    //VARIABLES
    float Ro = 10000.0;    // this has to be tuned 10K Ohm
    int val = 0;           // variable to store the value coming from the sensor
    float valMQ =0.0;
    float lastMQ =0.0;
    float           LPGCurve[3]  =  {2.3,0.21,-0.47};   //two points are taken from the curve.
    //with these two points, a line is formed which is "approximately equivalent"
    //to the original curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
    float           COCurve[3]  =  {2.3,0.72,-0.34};    //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
    float           SmokeCurve[3] = {2.3,0.53,-0.44};   //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.53), point2:(lg10000,-0.22)
    /*--------------------MQ2 end---------------------------------*/
    DHT dht;
    MyMessage msg(CHILD_ID_MQ, V_LEVEL);
      // sendSketchInfo("TemperatureAndHumidity", "1.1");
      sendSketchInfo("Temperature, Humidity and Gas", "1.1"); /*MQ2*/
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_MQ, S_AIR_QUALITY); /*MQ2*/
      // present(CHILD_ID_MQ, S_SMOKE); /*MQ2*/
      /*---MQ2---------------------------------------------------------*/
      Ro = MQCalibration(MQ_SENSOR_ANALOG_PIN);  //Calibrating the sensor. Please make sure the sensor is in clean air
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
    /*----MQ2----*/
    uint16_t valMQ = MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO);
      Serial.println(val);
      Serial.print("LPG:");
      Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_LPG) );
      Serial.print( "ppm" );
      Serial.print("    ");
      Serial.print("CO:");
      Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO) );
      Serial.print("    ");
      Serial.print("SMOKE:");
      Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_SMOKE) );
      Serial.print("\n");
      if (valMQ != lastMQ) {
        send(msg.set((int16_t)ceil(valMQ)));
        lastMQ = ceil(valMQ);
      sleep(UPDATE_INTERVAL);
    /*----MQ2----*/
    /****************** MQResistanceCalculation ****************************************
    Input:   raw_adc - raw value read from adc, which represents the voltage
    Output:  the calculated sensor resistance
    Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
             across the load resistor and its resistance, the resistance of the sensor
             could be derived.
    float MQResistanceCalculation(int raw_adc)
      return ( ((float)RL_VALUE*(1023-raw_adc)/raw_adc));
    /***************************** MQCalibration ****************************************
    Input:   mq_pin - analog channel
    Output:  Ro of the sensor
    Remarks: This function assumes that the sensor is in clean air. It use
             MQResistanceCalculation to calculates the sensor resistance in clean air
             and then divides it with RO_CLEAN_AIR_FACTOR. RO_CLEAN_AIR_FACTOR is about
             10, which differs slightly between different sensors.
    float MQCalibration(int mq_pin)
      int i;
      float val=0;
      for (i=0; i<CALIBARAION_SAMPLE_TIMES; i++) {          //take multiple samples
        val += MQResistanceCalculation(analogRead(mq_pin));
        delay(CALIBRATION_SAMPLE_INTERVAL);
      val = val/CALIBARAION_SAMPLE_TIMES;                   //calculate the average value
      val = val/RO_CLEAN_AIR_FACTOR;                        //divided by RO_CLEAN_AIR_FACTOR yields the Ro
      //according to the chart in the datasheet
      return val;
    /*****************************  MQRead *********************************************
    Output:  Rs of the sensor
    Remarks: This function use MQResistanceCalculation to caculate the sensor resistenc (Rs).
             The Rs changes as the sensor is in the different consentration of the target
             gas. The sample times and the time interval between samples could be configured
             by changing the definition of the macros.
    float MQRead(int mq_pin)
      int i;
      float rs=0;
      for (i=0; i<READ_SAMPLE_TIMES; i++) {
        rs += MQResistanceCalculation(analogRead(mq_pin));
        delay(READ_SAMPLE_INTERVAL);
      rs = rs/READ_SAMPLE_TIMES;
      return rs;
    /*****************************  MQGetGasPercentage **********************************
    Input:   rs_ro_ratio - Rs divided by Ro
             gas_id      - target gas type
    Output:  ppm of the target gas
    Remarks: This function passes different curves to the MQGetPercentage function which
             calculates the ppm (parts per million) of the target gas.
    int MQGetGasPercentage(float rs_ro_ratio, int gas_id)
      if ( gas_id == GAS_LPG ) {
        return MQGetPercentage(rs_ro_ratio,LPGCurve);
      } else if ( gas_id == GAS_CO ) {
        return MQGetPercentage(rs_ro_ratio,COCurve);
      } else if ( gas_id == GAS_SMOKE ) {
        return MQGetPercentage(rs_ro_ratio,SmokeCurve);
      return 0;
    /*****************************  MQGetPercentage **********************************
             pcurve      - pointer to the curve of the target gas
    Remarks: By using the slope and a point of the line. The x(logarithmic value of ppm)
             of the line could be derived if y(rs_ro_ratio) is provided. As it is a
             logarithmic coordinate, power of 10 is used to convert the result to non-logarithmic
             value.
    int  MQGetPercentage(float rs_ro_ratio, float *pcurve)
      return (pow(10,( ((log(rs_ro_ratio)-pcurve[1])/pcurve[2]) + pcurve[0])));
    /*----MQ2----*/```
    Openhab2 logs:
    2017-07-25 21:17:29.818 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: temp(V_TEMP) value to: 27.0
    2017-07-25 21:17:29.821 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/1 to 2017-07-25T21:17:29.000+0200
    2017-07-25 21:17:29.821 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;0;1;0;1;36.0
    2017-07-25 21:17:29.822 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
    2017-07-25 21:17:29.822 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 0 found in node 1
    2017-07-25 21:17:29.822 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: hum(V_HUM) value to: 36.0
    2017-07-25 21:17:29.823 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/0 to 2017-07-25T21:17:29.000+0200
    2017-07-25 21:17:30.838 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;2;1;0;37;32111
    2017-07-25 21:17:30.839 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
    2017-07-25 21:17:30.839 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 not present in node 1
    Openhab codes:
    Bridge mysensors:bridge-eth:gateway [ ipAddress="100.100.6.41", tcpPort=5003, sendDelay=200, startupCheckEnabled=false,networkSanCheckEnabled=false ] {
    humidity hum01 [ nodeId=1, childId=0 ]
    temperature temp01 [ nodeId=1, childId=1 ]
    airquality airq01 [ nodeId=1, childId=2 ]
    items
    Number hum01 "Humidity" { channel="mysensors:humidity:gateway:hum01:hum" }
    Number temp01 "Temperature" { channel="mysensors:temperature:gateway:temp01:temp" }
    Number airq01 "AirQuality" { channel="mysensors:airquality:gateway:airq01:level" }
    Thanking you in advance for the helping..
    • T Offline
      T Offline
      Tommas
      Dear All!
      I dont know exactly what i did to make it work, but it is almost OK now.
      Almost, because on the PaperUI the Control tab shows the right value of the Air Quality Meter, but on the BasicUI sitemap and in the OPENHAB ios APP shows only the Text (Air Quality ...) without the value
      I attach the new sketch and code, if somebody could help me:
      Sketch
      //#define MY_RS485
      #define CHILD_ID_MQ 2 /*MQ2*/
      float lastTemp;
      float lastHum;
      bool metric = true;
      //normal operation
      #define         GAS_LPG                      (0)
      #define         GAS_CO                       (1)
      //VARIABLES
      float valMQ =0.0;
      float lastMQ =0.0;
      DHT dht;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      /*----MQ2----*/
        Serial.print("    ");
        Serial.print("    ");
        Serial.print("\n");
      /*----MQ2----*/
               could be derived.
        int i;
        float val=0;
        return val;
        int i;
        float rs=0;
        return rs;
        return 0;
               value.
      /*----MQ2----*/
      Openhab codes:
      /etc/openhab2/sitemaps# cat /etc/openhab2/things/demo.things
      airQuality airq01 [ nodeId=1, childId=2 ]
      /etc/openhab2/sitemaps# cat /etc/openhab2/items/demo.items
      :/etc/openhab2/sitemaps# cat /etc/openhab2/sitemaps/demo.sitemap
      sitemap demo label="Main Menu" {
      Frame {
      Text item=hum01
      Text item=temp01
      Default item=airq01
      Thank you in advance!
      Best regards,
      • T Tommas
        Dear All!
        Sketch
        //#define MY_RS485
        float lastTemp;
        float lastHum;
        bool metric = true;
        //normal operation
        #define         GAS_LPG                      (0)
        #define         GAS_CO                       (1)
        //VARIABLES
        float valMQ =0.0;
        float lastMQ =0.0;
        DHT dht;
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            nNoUpdatesHum++;
        /*----MQ2----*/
          Serial.print("    ");
          Serial.print("    ");
          Serial.print("\n");
        /*----MQ2----*/
                 could be derived.
          int i;
          float val=0;
          return val;
          int i;
          float rs=0;
          return rs;
          return 0;
                 value.
        /*----MQ2----*/
        Openhab codes:
        Frame {
        Text item=hum01
        Text item=temp01
        Default item=airq01
        Best regards,
        T Offline
        T Offline
        TimO
        Hey @Tommas !
        Add a placeholder [] to the text in items file.
        Number hum01 "Humidity [%.1f %%]" { channel="mysensors:humidity:gateway:hum01:hum" }
        Number temp01 "Temperature [%.1f °C]" { channel="mysensors:temperature:gateway:temp01:temp" }
        Number airq01 "AirQuality [%d]" { channel="mysensors:airquality:gateway:airq01:level" }
        • T TimO
          Hey @Tommas !
          T Offline
          T Offline
          Tommas
          Dear @TimO
          Unfortunately it isnt enough. A - sign appeares but the value missing :(
          Best regrards
          • T Tommas
            Dear @TimO
            Best regrards
            M Offline
            M Offline
            MagnusF
            Hey @Tommas
            What happens if you in the sitemap change "Defult item=airq01" to "Text item=airq01"
            • M MagnusF
              Hey @Tommas
              T Offline
              T Offline
              Tommas
              @MagnusF
              Unfortunately nothing changed:(
              I paste the openhab log, when the mq2 sense something:
              2017-07-27 18:42:12.899 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
              2017-07-27 18:42:12.899 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 1
              2017-07-27 18:42:12.900 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: level(V_LEVEL) value to: 4
              2017-07-27 18:42:12.902 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/2 to 2017-07-27T18:42:12.000+0200
              2017-07-27 18:42:19.369 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;2;1;0;37;0
              2017-07-27 18:42:19.370 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
              2017-07-27 18:42:19.370 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 2 found in node 1
              2017-07-27 18:42:19.371 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: level(V_LEVEL) value to: 0
              2017-07-27 18:42:19.373 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/2 to 2017-07-27T18:42:19.000+0200
              • T Tommas
                @MagnusF
                T Offline
                T Offline
                Tommas
                @Tommas
                Dear all!
                Has someone any idea, why i cant display the mq2 value on the sitemap?
                Only a "-" appear. I would like to see the value. On the control tab on the paperui i see the changes.
                Another solution would be good as well, for example an alert if the mq2 value greater than X.
                T.
                • T Tommas
                  @Tommas
                  Dear all!
                  T.
                  M Offline
                  M Offline
                  MagnusF
                  Hi @Tommas
                  A new try. In your definition of the item airq01 you have in the channel="mysensors:airquality..." written "q" in lowercase letter.
                  When I look in MySensors Binding in Paper UI it is written with a capital "Q", "airQuality". I don't know if it matters.
                  • M MagnusF
                    Hi @Tommas
                    T Offline
                    T Offline
                    Tommas
                    @MagnusF
                    YESS! It was the problem :+1:
                    Thank you very much!!
