  3. OpenHAB
  4. Lost beginner - nodes, parent nodes and changes needed to sketches ?
18 Posts 3 Posters 5.9k Views 3 Watching
    make sure #define MY_NODE_ID 3 and all other mysensors related defines are written before the #include <MySensors.h>
    anonymouslemming
    @gohan said in Lost beginner - nodes, parent nodes and changes needed to sketches ?:
    I've got the following near the top of the sketch:
    There are no occurrences of MY_NODE_ID above this, but I'm seeing the same behaviour.
    Is this test even useful? insofar as testing radio connectivity without a gateway in place ?
    Is anyone able to share a circuit and a sketch for a simple relay that's known to work with OpenHAB, or should the examples be working ?
    thanks,
      What do you mean you don't have a gateway in place?
      A 1 Reply Last reply
        anonymouslemming
        Apologies - I mean that I don't have a controller in place at the moment. I do have the serial gateway running, but no node ID variables / defines in there.
        parachutesjP 1 Reply Last reply
        • A anonymouslemming
          parachutesjP
          parachutesjP
          parachutesj
          @anonymouslemming have you tried another arduino? I think I had once a similar issue, all was set correct but node did not connect. Changed the arduino and it worked.
          • parachutesjP parachutesj
            anonymouslemming
            @parachutesj said in Lost beginner - nodes, parent nodes and changes needed to sketches ?:
            I've tried 3 different Arduino Nano's on the switch module and 2 different radios. Replaced cables too. I tried a different Arduino Uno on the gateway module too.
              according to the log the node is not getting an ID otherwise it should show in the first lines that it is using ID = 3
              You could try running the cleareeprom sketch and upload your sketch again
              • A
                anonymouslemming
                I finally got this working. My problem was my radio's were not communicating. I went back to basics with an RF24 example sketch and found one of my radio's to be dead. After replacing it, I simply set
                MY_NODE_ID in my sketch and everything is now working.
                gohanG 1 Reply Last reply
                  @anonymouslemming it is always good to have spare parts around :D
                    anonymouslemming
                    @gohan I have SOOO many spare RF24's now - I bought a batch of 10 off of Amazon while debugging this.
                    :D
                      I hope yours are not the cheap crappy chinese clones like I got from Amazon too. If you paid less than 12$ for those, they most likely are too.
                        anonymouslemming
                        @gohan I'm almost 100% sure they're clones, yeah. But they've been going for 2 days now across the range of my house (while in low power mode - no capacitor in place yet), so they'll do for prototyping.
                        Once I get to designing and printing boards, then I'll be a lot fussier :)
