  2. Feature Requests
  3. Better security without the need of a cryptoprocessor: out-of-band authentication
Scheduled Pinned Locked Moved Feature Requests
54 Posts 5 Posters 16.8k Views 7 Watching
  • AnticimexA Anticimex
    @Eurbaix your proposal is in my opinion fully adequate from a security point of view.
    As for encryption on "legacy" hardware we already have a sw AES crypto driver (although weak).
    The button on the GW actually already exist for "inclusion mode". And we also already have a software equivalent that is triggered from the controller for those who don't have or don't want a button on the GW.
    A lightweight security personalizer should be enough to store the initial PSK in the nodes. For those who have used the current signing solution, that should not be a deterrent. Some new users might be annoyed by it but I don't see a good alternative. Sending it OTA is a big nono. And having it as an optional FW defined static is bad practice in case the FW leaks (even though we have inclusion mode).
    If you want we can set up some shared document to flesh out the implementation details for this?
    @d00616 do you have any additional input?
    E
    E
    Eurbaix
    @Anticimex I believe the difficulty is not in making "out-of-band" secure, as it has been used and reviewed many times from a security point of view. My concern was more: can we keep it simple enough so it could be deployed on existing 8 bit platforms.
    As for OTA, the initialization I proposed never send a clear key OTA. The initialization PSK is written on the sensor when you flash it (so, wired comms) and not part of the firmware. I was thinking something along the line of:
    • Flash and run a small firmware (which has the initialization PSK hardcoded) that will just store the initialization PSK in the EEPROM.
    • Flash and run the full MySensor firmware (which doesn't have the PSK hardcoded), then run the initialization using the PSK in the EEPROM.
      This way, the full MySensor firmware, that will be updated OTA, never have to include a PSK so it can be sent in clear. Also, since comms are now encrypted, OTA updates could be encrypted although I don't see a need to encrypt firmware updates since they do not contain sensitive information.
    As for packet size limitation, that's one of the reason I went with short TTL tokens that also act as nounce. The tokens are sent in a separate packet from the gateway so there is no need to exchange nounce for the rest of the communication as long as the token TTL is short enough. I would guess 5 or 10 packets using the same token should not be enough for a brute force attack. This leaves the entire packet free for payload (minus routing information), the usable payload is in fact the same as in non-secured comms.
    Last: Yes, a shared document would be a good idea so we don't have go through all the posts to remember what we already discussed. I have Google Docs and One Drive accounts, but can also register on another collaboration platform.
    AnticimexA Sergio RiusS 2 Replies Last reply
    • E Eurbaix
      AnticimexA
      AnticimexA
      Anticimex
      @Eurbaix I know. Hence my connection to the existing security personalizer which does the exact same thing.
      The packet size concern is more about that certain crypto algorithms produce a ciphertext of a specific size, which had to fit in the message frame. So if parts of the buffer is in plain text, some limitation is put in the allowed size of the ciphertext (and the original plaintext which could produce a ciphertext spanning multiple crypto blocks which then would not fit the message buffer). But this is specific to the chosen algorithm.
      I'll look into facilitating some document sharing later. A bit busy right now and out of computers reach.
      E 1 Reply Last reply
        E
        E
        Eurbaix
        @Anticimex You raise a good point regarding cyphertext size. I was thinking initially AES 128 would be a good choice but, if routing is in clear, the encrypted part of the packet is now reduced to 16 bytes. Something to look at... or may be 16 bytes is acceptable in the use case scenario of MySensors since not all information is necessarily sensitive.
        Also, what are you referring to when you say "security personalizer"? I don't remember something with this name in the current security in MySensors?
        P.S.: No rush for the document sharing. It will take a while anyway to come up with something that covers all the basics so a few days more or less won't make a real difference.
        I
        AnticimexA 1 Reply Last reply
        • E Eurbaix
          I
          AnticimexA
          AnticimexA
          Anticimex
          @Eurbaix security personalization is the corner stone of the current signing solution :) you can't use it without personalization (except for the simplified security flag on the development branch).
            E
            E
            Eurbaix
            @Anticimex Well, it seems I missed something important in the current signing implementation. I'll have a second look.
            • d00616D
              d00616D
              d00616
              I had similar ideas with two firmwares. One for initialization and one running MySensors.
              If asymetric encryption is used, there is no need for an PSK for encryption. A key is calculated on both sides this can be used as a node key. A library supporting 8 bit and 32 bit MCU is micro-ecc. The problem is, the key must be compared on both sides to detect man in the middle attacks. This could be by synchronous LED blinking the hash of the calculated key and accepting the key on the gateway. This allows to integrate sensors without the need of the SecurityPersonalizer.
              The 32 byte package size can be extended by an nRF24/ECB protocol extension. First packet is send without ACK and when a second packet is received the ACK payload reports if the first packet is received. Then we have 64 byte packages, compatible with classic hardware.
              I'm unsure if routing encrypted packages is a good idea. An attacker can force the relay to route invalid packages. On the other side the attacker can block the complete channel by sending invalid data.
              When the motivation of the new security scheme is to reduce the cost. There are nRF51822 boards starting at less than 2.50€ and nRF52832 boards for less than 4.50€.
              Compared the Arduino Pro Mini + nRF24 solution with the nRF51 you get ~100 times more performance without the 2k RAM limit and a lot of Flash for 0.50€ more costs. The nRF51 has an better range compared with the nrf24, allows to implement better radio protocols or switching to BLE (actually without MySensors) and it's possible to connect RFM modules. I think in six month the pricing is eqal.
              With an bootloader like mcuboot, which needs porting to MySensors the key can be protected by disallowing flashing unsigned firmware and disable debugging.
              I think we shouldn't do compromises to support 8 bit MCUs.
              E KoreshK 2 Replies Last reply
              • E Eurbaix
                @Anticimex There are, in fact, three different keys in my proposal:
                • A initialization PSK which should be stored in EEPROM, not the firmware, so it can be erased after the sensor registration. This PSK is common to all new sensors but only used once.
                • A sensor PSK, which is sent over the air during the registration, encrypted with the initialization PSK.
                • The sensor PSK is used to encrypt the token request and answer so another sensor cannot "read" the token since it doesn't have the same sensor PSK.
                • The token is then used as an authentication and encryption key during the rest of the communication.
                So here's a few more details about how it would work:
                • When firmware is initially loaded on a new sensor, the initialization PSK is also loaded in the sensor EEPROM.
                • The GW needs a "WPS" button (as modern routers have)
                • Just before powering-up a sensor for the first time, press the GW's "WPS" button, the sensor will accept a connection with the initialization PSK for a few seconds (10-15s) and, along the normal sensor "registration", also send a new key to the sensor. The sensor will then erase the original PSK and replace it with this "sensor PSK", which is specific to this sensor. Since this original PSK is only used during the initial registration then deleted, it will only exist in the sensor memory while the sensor is in a secure location. In case this PSK is compromised, you only need to create a new key in the gateway, that will then be used when you load new sensors.
                • This sensor PSK is then used to encrypt the token request since the GW knows each sensor key. The token is sent encrypted with this sensor PSK so another sensor cannot "read" this token. If the token is requested for a sensor-to-sensor communication, the GW will also send the token to the second sensor, encrypted with the second sensor PSK.
                • For the rest of the communication (sensor to sensor, or sensor to GW), this token becomes the encryption key and authentication key.
                This way, a common PSK is only used during the initialization and can only be used for initialization. This PSK is not accepted for regular communication with the GW (or other sensors). Also, a rogue sensor who have this initialization PSK can only request a "sensor PSK" when the WPS button is pressed. The chance of a rogue sensor sending a initialization request just after the WPS button has been pressed is minimal (except if you routinely initialized dozens of sensors everyday). If fact, the chances are low enough that the initialization PSK is even optional, in my opinion. After all, router use WPS without initialization PSK and this approach is considered reasonnably secure.
                Last, if a "sensor PSK" is compromised, you only have to erase this entry in the sensor PSK table on the GW and the rest of your sensor network will be secure. If we are not using a cryptoprocessor to store the sensor PSK, the risk of the sensor PSK to be read in a stolen sensor exist, but the fact that sensor PSK are individuals make this risk easier to mitigate (as long as you notice that a sensor has been stolen of course).
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                @Eurbaix said in Better security without the need of a cryptoprocessor: out-of-band authentication:
                Here you're basically proposing a handshake system, but, what you talk about in the first section of points, are you referring to the GW or nodes?
                I don't see the need of this first key. Anything that identifies the sensor, like it's name would serve the same purpose. Or I understand it wrong?
                I think that if you have two networks/channels, as I have, sensors from the two networks would have different keys. Then if we wanted to add a new sensor to one of the networks, what prevents the GW1 to see a sensor from the second network (that may have connectivity issues, alias it may be asking for reconnection) as a new sensor?
                • d00616D
                  d00616D
                  d00616
                  For an mixed network with classic hardware and new hardware we can work with two address ranges. This is possible for nRF networks.
                  • Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    #34
                    I see, but I always try to address security and script burning in general trying to arrive an scenario where programming knowledge isn't necessary. Like choosing from a web page the sensor I want, connecting it to the computer via usb and letting the page/program/whatever to do it all.
                    WPS was considered insecure because there where ways of wirelessly force the router to start the WPS procedure. Then added a password to the WPS process and now they're removing this support, whats I think it's an error.
                    • E Eurbaix
                      Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      #35
                      Why not having mysensors framework generating this key on the first start-up? If you're concerned about some-one getting through the algorithm, it could require some seed from the user that may be common for him. That's still compatible with my approach of a code generator if the generator asks for the seed.
                      Also, I don't understand why the repeaters are a problem. I don't see why they have to read all the messages, hence being deciphered. Why they don't just "relay" them?
                      AnticimexA E 2 Replies Last reply
                      • Sergio RiusS Sergio Rius
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Sergio-Rius if the message is fully encrypted, how would the repeaters know how to route?
                          Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          #37
                          @Anticimex It may not be fully encrypted, but having description packets. Other protocols do like this.
                          I understand that the repeaters should only care for messages directly sent to them. Like a remote-button to a garage door node. Other messages should then be relayed to the network. I think that is more productive and increase performance.
                          Perhaps I miss a more complex scenario.
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @Sergio-Rius no that is correct. But repeaters to understand if a message is directed for them or to be repeated, part of the message need to be in plain text and then we need to mind the crypto algorithm vs payload limitations.
                            There are many solutions to this, I am just saying that it has to be taken into account as well.
                            This is not an issue when encryption is handled by the physical layer (the radio itself) but then security is specific to the radio. And we don't want that.
                            • d00616D d00616
                              E
                              E
                              Eurbaix
                              @d00616 asymetric encryption has some advantages but ECC is more computing intensive and asymetric encryption needs double decryption compared to single decryption with a symetric algorithm. I went with symetric because it's usually lighter and faster. Also, you would still need an initializing PSK to be able to differentiate a rogue sensor trying to register on your network vs. one of your own sensors. I don't thing a LED flashing a hash is really practical.
                              P.S.: I know that current cheap platforms, like NRF5, are much more powerful for not much more money, but we should also keep in mind that a lot of existing sensors have already been deployed. If we drop the Atmega328 support, anyone who want to benefit of the new security solution will have to throw away all its existing sensor and rebuild new ones. That's why I am a strong advocate of legacy support, I hate throwing away something that could still works just because there is something new and shinner available for the same price.
                              d00616D 1 Reply Last reply
                              • Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                #40
                                In fact I initially thought that more than one GW was possible in a MyS network. That messages where broadcast until a receiver ACK-ed for it.
                                @Anticimex I totally agree with you.
                                @Eurbaix Not only the hardware. Some people are doing a great job in NodeManager that could need re-adaptations (dunno).
                                I almost always work with async encryption. Well... I think a mixed, cascaded solution may be ideal on this scenario. Just use sha256 ciphered key, surrounded by more packets sync-ciphered and wrapped together.
                                I don't know if the hardware may support it, but could be like peeling an onion, if you understand. Only the GW knows the key and deciphers the message.
                                Payload is hardly inescapable.
                                • E Eurbaix
                                  d00616D
                                  d00616D
                                  d00616
                                  I agree here. Atmega can be supported by switching back to the old scheme or by dropping features for this platform.
                                    E
                                    E
                                    Eurbaix
                                    @Sergio-Rius The reason for the initialization PSK is to be able to differentiate a sensor you flashed yourself from a sensor someone else flashed and try to register on your network.Of course, you could use the sensor name as the key, but it is a weak key and it would also require to store the new sensor name on the GW every time you want to initialize a new sensor. The initialization PSK being common to all nodes, you don't need to change anything on the GW when you build a new sensor.
                                    You can't use an initial key generated by the GW because it would then need to be sent OTA to the sensor. Since the sensor do not have a PSK yet, this generated key would have to be send in clear. A rogue sensor listening at this moment could read this key and register instead of your own sensor. Although limiting the time during which a GW would accept a new sensor is limited by the "WPS" button, you have to think about a rogue sensor constantly listening and trying to register on your network until the GW is in "WPS" mode. (Note that I only refer to the basic concept of "WPS", which is limiting the time when a new sensor can register by using a button to initiate a 5-10 seconds window where the GW would accept a new sensor. The idea is simply that, since the initialization is using a common PSK which is a security risk if it is stored in easily accessible EEPROM, you want to limit as much as possible when this initialization PSK can be used, so only once during the initialization then it is deleted, and only if a button has been pressed on the GW within the last 5-10 seconds).
                                    Also, when using several separate networks (i.e. different GW linked to the same controllers, but each GW talking to its own sensor network), by using a different initialization PSK on each gateway (and on the sensors that must register on a specific gateway), you make sure that a sensor can only register on the right gateway. Then, each GW has only the list of sensor PSK for his own network so there is no risk a sensor attempt to talk to a GW it is not supposed to (if that's a concern, like having a low security sensor network and a high security sensor network).
                                    Also, I assume that GW are always in a secure location (cannot be stolen and read). If a GW can be compromised, we're opening an entirely new can of worms.
                                    And regarding your last comment: I, also, think async encryption is a better solution on non-constrained network (i.e. when memory and computing power is not a big concern). But, in this context, if we want to keep legacy support, we better look for the most lightweight encryption algorithms. Also, anything using a 256 key cannot be used with the current protocol since a 256 key or token would take the entire packet, with no room left for the routing information. Since "out-of-band" needs to send new tokens regularly, we have to stay with 128 bits. Going with 256 keys would require to also modify the protocol and make the entire thing much more complex to implement
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      No matter what path we choose it is not dropping support per se. Worst case is that atmega users have to stick with current solution. Best case is a sw equivalent that might or might not leverage features of the atsha204a to accomplish the things needed by a new security infrastructure capable of fitting into legacy devices with reasonable space to spare.
                                      • E Eurbaix
                                        Sergio RiusS
                                        Sergio RiusS
                                        Sergio Rius
                                        We are seeing this from a different point of view. I can't get the controller out of this equation (by my own limitations). I would like to start the pairing process from the controller, see whats available and only authorize what it was meant to. That's why I was thinking more on a "identification key"
                                        If I understand well:
                                        A key is hardcoded (to say) in the GW.
                                        Then you must write that key in the new sensor (other network will have a different key).
                                        The pairing process is initiated, so you turn on the sensor.
                                        The GW acknowledges with the sensor and sends to him a new key that is saved and then starts authentication and encryption as normal.
                                        As for sha256, anything below that is crackeable. And so, yes, were're not designing the next pentagon network here. But you must think if 256+ size messages will be the next logical step or a question of time.
                                        By now, I totally agree with you.
                                        I personally think atmega is so charismatic. ESP32 had to be the panacea, but I'm still waiting for it.
                                          E
                                          E
                                          Eurbaix
                                          @Anticimex Totally agree. The initial idea of my proposal was a security scheme compatible with existing sensors where a compromised sensor without an atsha204a can be easily blacklisted, this preferably with a minimal impact on the firmware size compared to the purely software solution already implemented. Also, it would provide obfuscation in addition to authentication, since I am not really comfortable with someone knowing if my house is empty and/or locked.
                                          Since the existing software solution already have AES, and "out-of-band" with token generated from the GW doesn't require a random number generator on the sensors, I think the "out-of-band" security could be implemented without a significant increase in the firmware size. The only compromise would be a 16 bytes encrypted payload if we stay with AES 128. Personnaly, I would accept this compromise so people using more modern platform can take advantage of the HW AES and free up some memory for the more complex sensors. After all, MySensors don't normally send tons of data, so it would only mean sending 2-4 packets instead of 1-2. Also, since the firmware updates do not contain any key, they don't need to be encrypted and can use the full payload.
