  3. Low power Distance Sensor - Hardware issues
37 Posts 11 Posters 22.2k Views 8 Watching
  • qqlapralineQ
    qqlapralineQ
    qqlapraline
    The finale update !
    After numerous tests (using used batteries, adapted software and a lot of patience), it appears that the step up booster was not working under a certain voltage (around 2.7v).
    Futhermore, the sleep time before distance measure was very variable.
    I have questionned myself a lot and finally, my doubts went to the capacity of the Arduino to feed the dc-dc converter with enough current.
    To fix this issue, I have used a BC548B transistor with a base resistor of 1K to drive the step-up converter. And, miracle, it works !
    My finale test was with a set of used batteries delivering 2 V !
    Now, I have a sensor that tests distance, temp/hum and battery level every 15 minutes. The average power consumption is 55 µA (25 µA during sleep time and 15 mA for 1 second during measures).
    QQ.
    • qqlapralineQ
      qqlapralineQ
      qqlapraline
      wrote on last edited by qqlapraline
      And here the latest battery graph displaying two things:
      • The first phase with not that optimal battery consumption (until Jan, 14th)
      • The second one with everything optimized (after Jan, 14th).
      QQ.
      • stevebusS
        stevebusS
        stevebus
        Very nice project and thanks for sharing. I have a deer feeder in a corner of my yard, and it's always getting empty without me knowing. I'm planning on this exact same type of project to measure the level of corn in the feeder. Would love to see your final schematic and parts list (as it changed across the thread), but no worry if you don't have it as I'm sure I can figure it out.
        Thanks again for sharing.
        Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
        Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
        qqlapralineQ 1 Reply Last reply
        • bjacobseB
          bjacobseB
          bjacobse
          I think batteries and sonar distance sensor is not the best, it consumes too much power, since you must measure too often. A better solution if possible is to only get a interrupt with a switch when water tank is empty, then Arduino can sleep forever, or maybe you want to let it wake up once a day to provide a live puls. with a sonar you must check often and spend precious battery for distance measuring. Also there is no need of a DC-DC converter when using the switch, since the DC-DC converter also drains your batteries
          Can you use something like this instead?
          http://www.ebay.com/sch/sis.html?_nkw=New+Hot+Sale+Small+Liquid+Water+Level+Sensor+Horizontal+Float+Switch+WB&_id=301886450361&&_trksid=p2060353.m2749.l2658
          • stevebusS stevebus
            qqlapralineQ
            qqlapralineQ
            qqlapraline
            Thank you @stevebus. It's now live at its outdoor spot measuring the water in my well. It works perfectly :)
            I'll post the photos and schemas once I get back from skiing ;)
            • bjacobseB bjacobse
              qqlapralineQ
              qqlapralineQ
              qqlapraline
              @bjacobse , I do understand your concern ! That was my challenge for the past months. But the combination of digital output to trigger on/off the sensor, low update frequency (15 minutes) and a low power ultrasonic sensor makes it possible (ser posts above).
              Qq.
              • HarrySteffH
                HarrySteffH
                HarrySteff
                Hello @qqlapraline
                i want to build exactly this sensor like you do.
                Can you help me with a wiring schema and a parts list?
                Thank you so much!
                • qqlapralineQ
                  qqlapralineQ
                  qqlapraline
                  Here is the schematics (freshly made for you :))
                  0_1496348113224_upload-8af864a8-ed84-400a-ad21-5adc67c72da4
                  And here the part list:
                  • Arduino pro mini (3.3v with BOD disabled) or Sensebender Micro
                  • Ultrasonic sensor: ME007-ULS (available here)
                  • NRF24L01+ (I use the PA - LNA version for long range communication)
                  • NPN Transistor: BC548 (the B version if prefered)
                  • Base resistor: 1k
                  • 3.3V Step-up Voltage regulator: NCP1402 (available here)
                  • Logic Level Converter (available here): it says 3.3/5 but actually it's any to any voltage.
                  • Waterproof case (available here)
                  And finally here is my code (not cleaned, sorry).
                  0_1496348693347_DistanceSensebenderMicro.ino
                  And the Eagle SCH
                  0_1496348714531_Low power Distance Sensor.sch
                  And now, I realize that it may have been wise to upload that to openhardware.io :)
                  Regards,
                  QQ.
                  sq9njjS 1 Reply Last reply
                  • HarrySteffH
                    HarrySteffH
                    HarrySteff
                    Thank you very much!
                    • qqlapralineQ qqlapraline
                      • Base resistor: 1k
                      And the Eagle SCH
                      Regards,
                      QQ.
                      sq9njjS
                      sq9njjS
                      sq9njj
                      @qqlapraline would you mind reupload your sketch?
                      • sq9njjS sq9njj
                        @sq9njj the link works if it is opened in a new window or if you right-click and select "save as".
                        • qqlapralineQ
                          qqlapralineQ
                          qqlapraline
                          Does it work fine ?
                          In case, you need it, here it goes again :)
                          0_1504557254355_DistanceSensebenderMicro.ino
                          Beware, it uses a former version of the MySensors library.
                          QQ.
                            Does it work fine ?
                            QQ.
                            sq9njjS
                            sq9njjS
                            sq9njj
                            @qqlapraline thanks! It works fine, thanks again!
                            • C
                              C
                              chbla
                              I tried this with a similar setup but RFM95 for LoRaWan and without the transistor as I'm testing it directly on USB.
                              A pololu 5V stepup regulator does not even work directly on VCC - if I connect the HC-SR04, voltage drops from 5V
                              to 1.2V after the regulator.
                              I then tried a different regulator from aliexpress, this setup works with the regulator on VCC, but if I try to control it through a
                              Pin, Voltage also drops and does not even power the regulator (it has a LED) :(
                              • qqlapralineQ
                                qqlapralineQ
                                qqlapraline
                                From my experience, the transistor (or mosfet) is key to allow enough current to the DC-DC booster. Otherwise, it will not provide the appropriate voltage because max current getting out of a digital pin from Arduino is around 40 mA.
                                QQ.
                                • C
                                  C
                                  chbla
                                  wrote on last edited by chbla
                                  #28
                                  I have a working setup now, however, it seems that I lose current through the trigger pin.
                                  If I disconnect it, it drops.
                                  @qqlapraline what I don't get is: Do you really have GND on the high side of the LVL converter connected to GND as in your schematic?
                                  Since the GND sides on the converter are connected, this closes the loop for the regulator, thus it would be turned on all the time?
                                  Same for the HC-SR04
                                  • C chbla
                                    qqlapralineQ
                                    qqlapralineQ
                                    qqlapraline
                                    @chbla well, yes. As the level adapter AND the booster are triggered only when needed (during the measure time), I don't see where it closes the loop.
                                    By maybe I misunderstand something. Where do you loose some current ? The trigger pin from the HC-SR04 ?
                                    QQ.
                                    • C
                                      C
                                      chbla
                                      What I mean is, those should be connected to GNDT not GND as in your diagram - right?
                                      GND is permanent ground.
                                      I noticed I'm losing current through the trigger pin, the cause is apparently that if disconnected, the system is only on VCC.
                                      Since the trigger bin is set to LOW in my previous sketch, it loses current there.
                                      But I found out that if I set the trigger pin to HIGH before sleeping, it's fine. My sketch uses 78ua while sleeping. Using a MOSFET at the moment
                                      to switch.
                                      • C chbla
                                        to switch.
                                        qqlapralineQ
                                        qqlapralineQ
                                        qqlapraline
                                        @chbla, you are right. As mentionned on the schema, it should be connected to GNDT (the triggered GND). And now I do understand your point.
                                        C 1 Reply Last reply
                                          C
                                          C
                                          chbla
                                          @qqlapraline good to hear! :) Thanks for the confirmation
