  3. Battery power outside in the winter?
7 Posts 3 Posters 2.0k Views 3 Watching
  • raptorjrR Offline
    raptorjrR Offline
    raptorjr
    Is it possible to have a battery powered sensor outside in the winter?
    Have anyone tried it? I know that batteries loose some effect when it is cold. But is it still enough with two AA batteries?
    • T Offline
      T Offline
      tbowmo
      @raptorjr
      I've had a battery powered sensor outside for the last 1.5 years, still works like a charm. (2 x AA batteries, sensebender micro, nrf24, and a bmp280 barometric pressure sensor)
      raptorjrR 1 Reply Last reply
      • T tbowmo
        @raptorjr
        raptorjrR Offline
        raptorjrR Offline
        raptorjr
        @tbowmo Thank you. That sounds good. Maybe my concerns were exaggerated.
        Do you have some kind of logging of the battery so you can see that the voltage drops a little bit during the winter? Or maybe the amps required is so low it isn't noticeable?
        I will have a pro mini,nrf24 and some temperature/humidity sensor.
        • raptorjrR raptorjr
          @raptorjr -20C seems to work fine for this user, except that bigger capacitors were required: https://forum.mysensors.org/topic/5826/nrf24-problems-with-cold-temperatures
            raptorjrR Offline
            raptorjrR Offline
            raptorjr
            @mfalkvidd Thanks. Good to know that the capacitors can be a problem. And how to solve it. But don't say much about the battery. Will it last over the winter? Because of lower capacity of the battery?
            In the end I guess I'll just have to try =)
              @raptorjr according to http://drkfs.net/coldbattery.htm -30C is not a problem for alkaline batteries, especially not at the very low discharge currents used by MySensors nodes.
                raptorjrR Offline
                raptorjrR Offline
                raptorjr
                @mfalkvidd Thank you. Then there should be no problem.
                12.1k
