  3. Sensebender Micro - Abnormal power consumption
14 Posts 8 Posters 5.0k Views 6 Watching
  • qqlapralineQ
    qqlapralineQ
    qqlapraline
    Nice try but removing the radio was part of my tests (especially with Sketch J).
    Qq.
    • tbowmoT
      tbowmoT
      tbowmo
      Has it been exposed to extreme humidity or something else external that could cause this?
      • qqlapralineQ
        qqlapralineQ
        qqlapraline
        No, not at all. Actually, it sits on one of my bookshelves. It has been there for a while.
        I thought for a long period that the battery drain was due to some software issue until I conducted some deep analysis.
        Qq
          very strange!
          pics of your board? And what do you use to measure current ?
          • qqlapralineQ
            qqlapralineQ
            qqlapraline
            Here are some photos (frontside and backside). I use a regular multimeter to monitor the current (serial through the battery power).
            QQ.
            rborerR 1 Reply Last reply
            • qqlapralineQ qqlapraline
              QQ.
              rborerR
              rborerR
              rborer
              Hi @qqlapraline , I experience the same issue. I've already built door sensors + Temp + humidity with a pro mini 3.3v and it working since 7 months with the same 2AA's.
              I've done the same with the sensebender micro and in 2 weeks the battery are ko. I send temp/hum every 5 min, use sleep and interrupt for the door sensor.
              • qqlapralineQ
                qqlapralineQ
                qqlapraline
                I've found it...Yep, several months later, I've found it.
                Actually, there were some ghost connections. I have cleaned the different soldering flows using an Exacto. Furthermore, I have re-done the connection (to the NRF and the batteries) using a pump...
                And...tadah ! now the sleep current consumption is around 25µA.
                  ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  @qqlapraline so bad soldering caused this ?!
                  • qqlapralineQ
                    qqlapralineQ
                    qqlapraline
                    If « bad soldering » means some imperfections left unfortunately considering my close-to-perfection soldering skills..I would have to say yes..:)
                    That, or oxydation or any other issue.
                    Qq.
                      Qq.
                      @qqlapraline said in Sensebender Micro - Abnormal power consumption:
                      I've seen much worse:
                      0_1509125965672_upload-74ce712e-65db-4632-8c70-641fd8455023
                      :grimacing:
                      qqlapralineQ gohanG 2 Replies Last reply
                      • YveauxY Yveaux
                        :grimacing:
                        qqlapralineQ
                        qqlapralineQ
                        qqlapraline
                        @Yveaux, thanks for your support ;)
                        • YveauxY Yveaux
                          :grimacing:
                          @Yveaux I think that some people deserve to go to jail for that 😁
