  3. Home Assistant
  4. mysensors.json file structure
18 Posts 7 Posters 7.1k Views 8 Watching
  • archiijsA archiijs
    Hi @sindrome73 by instructions here https://home-assistant.io/components/mysensors/ you chose path to .json file (and it is automatically created after that) by adding path to it to your configuration.yaml
    maghacM
    maghacM
    maghac
    @sindrome73 It's not used unless you use Home Assistant as a controller for mysensors.
    @Richard-van-der-Plas It's a JSON file, so you can use any editor that understands json to edit it. No need to use nano or vi.
    I personally use notepad++ to remote edit files on my server, it has a nice json plugin to pretty print json files. You could also use an online editor, e.g https://jsonformatter.org/ or something.
    IrisPanabakerI 1 Reply Last reply
    • Richard van der PlasR
      wrote on last edited by Richard van der Plas
      @maghac problem is my limited editor / shell on chrome os makes it a tediuos job on selecting the line :(
      can you paste the formatted data back to the file? (with enters etc?). i thought the first round mysensors edits the file its a flat file again ?.
      • martinhjelmareM
        martinhjelmareM
        martinhjelmare
        I use atom editor where there's a plugin that can automatically format the json prettily. But we can add formatting to the dump, I don't see anything hindering that.
        I'll happily except a PR that adds indentation to the json dump. Otherwise I can do it when I find some time.
        • archiijsA
          archiijsA
          archiijs
          wrote on last edited by archiijs
          Hi all.
          @maghac Can you please share what plugin do You use? I already use np++ but have not thought of that, thanks.
          @martinhjelmare Can atom editor can connect to my home assistant files through ssh without using samba shares as np++ can with plugins? If so, I should check that.
          Otherwise, no worries about rushing this implementation and thanks for your work.
          martinhjelmareM maghacM 2 Replies Last reply
            Hi all.
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @archiijs
            I don't think atom can connect via ssh.
            • archiijsA
              archiijsA
              archiijs
              Sorry, I meant to say ftp/sftp... Its early morning for me :confused:
              I will definitely check atom after work, seems to be an answer to a lot of my problems, thanks for mentioning it.
              • martinhjelmareM
                martinhjelmareM
                martinhjelmare
                I think this plugin does what you want:
                https://atom.io/packages/remote-ftp
                • archiijsA
                  archiijsA
                  archiijs
                  Thanks for your help, could not wait and already downloaded portabble verssion on my work pc to test this thing out, seems to work as expected, thanks again for your recomendation.
                  • maghacM maghac
                    IrisPanabakerI
                    IrisPanabakerI
                    IrisPanabaker
                    @maghac I loved https://jsonformatter.org and also uses https://codebeautify.org/jsonviewer
                      Hi all.
                      maghacM
                      maghacM
                      maghac
                      @archiijs I use the NppFTP plugin, it supports both ftp and sftp.
                        mirodin
                        I made a pull request over on github, if @martinhjelmare accepts it we should be good to go.
