  3. Domoticz
  4. Dimmable LED help needed !
8 Posts 3 Posters 3.7k Views 2 Watching
  • PlantexP
    PlantexP
    Plantex
    Hi
    I'm testing Dimmable LED Actuator --> https://www.mysensors.org/build/dimmer
    Everything seems to work with Domoticz except one thing - It doesn't remember last dimming value (This is a feature I really need).
    After switching the light off and back on , no matter what value was before it goes everytime to 100%
    Figured out If I change the value 100 : 1 to 10 : 1 - It goes to 10% - but still It doesnt remember the last dimming value.
            requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );```
    I've found a sketch DimmableLight in My sensors examples which I would like to test unfortunately I cannot force it to work with LED stripe connected according to dimmer sketch( Mosfet , led pin 3 etc..)
    Could someone help me please with the code ?
    Which part is responsible for sending the information to LED_PIN 3 ? I tried to define LED pin3, also fade delay etc... to the below sketch - no luck.
    Does it matter if the variables are V_LIGHT and V_DIMMER if the type is S_DIMMER ? (both sketches) Shouldn't it be V_STATUS and V_PERCENTAGE ?
    Any help very welcome !
    Thanks in advance.
     * Version 1.0 - January 30, 2015 - Developed by GizMoCuz (Domoticz)
     * This sketch provides an example how to implement a Dimmable Light
     * It is pure virtual and it logs messages to the serial output
     * It can be used as a base sketch for actual hardware.
     * Stores the last light state and level in eeprom.
    // Enable debug prints
    #define CHILD_ID_LIGHT 1
    #define EPROM_LIGHT_STATE 1
    #define EPROM_DIMMER_LEVEL 2
    #define LIGHT_OFF 0
    #define LIGHT_ON 1
    #define SN "Dimable Light"
    #define SV "1.0"
    int16_t LastLightState=LIGHT_OFF;
    int16_t LastDimValue=100;
    MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
    MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
    	//Retreive our last light state from the eprom
    	int LightState=loadState(EPROM_LIGHT_STATE);
    	if (LightState<=1) {
    		LastLightState=LightState;
    		int DimValue=loadState(EPROM_DIMMER_LEVEL);
    		if ((DimValue>0)&&(DimValue<=100)) {
    			//There should be no Dim value of 0, this would mean LIGHT_OFF
    			LastDimValue=DimValue;
    	//Here you actualy switch on/off the light with the last known dim level
    	SetCurrentState2Hardware();
    	Serial.println( "Node ready to receive messages..." );
    	sendSketchInfo(SN, SV);
    	present(CHILD_ID_LIGHT, S_DIMMER );
    		Serial.println( "V_LIGHT command received..." );
    		int lstate= atoi( message.data );
    		if ((lstate<0)||(lstate>1)) {
    			Serial.println( "V_LIGHT data invalid (should be 0/1)" );
    			return;
    		LastLightState=lstate;
    		saveState(EPROM_LIGHT_STATE, LastLightState);
    		if ((LastLightState==LIGHT_ON)&&(LastDimValue==0)) {
    			//In the case that the Light State = On, but the dimmer value is zero,
    			//then something (probably the controller) did something wrong,
    			//for the Dim value to 100%
    			LastDimValue=100;
    			saveState(EPROM_DIMMER_LEVEL, LastDimValue);
    		//When receiving a V_LIGHT command we switch the light between OFF and the last received dimmer value
    		//This means if you previously set the lights dimmer value to 50%, and turn the light ON
    		//it will do so at 50%
    	} else if (message.type == V_DIMMER) {
    		Serial.println( "V_DIMMER command received..." );
    		int dimvalue= atoi( message.data );
    		if ((dimvalue<0)||(dimvalue>100)) {
    			return;
    		if (dimvalue==0) {
    			LastLightState=LIGHT_ON;
    			LastDimValue=dimvalue;
    		Serial.println( "Invalid command received..." );
    		return;
    	//Here you set the actual light state/level
    void SetCurrentState2Hardware()
    	if (LastLightState==LIGHT_OFF) {
    		Serial.println( "Light state: OFF" );
    		Serial.print( "Light state: ON, Level: " );
    		Serial.println( LastDimValue );
    	//Send current state to the controller
    	SendCurrentState2Controller();
    void SendCurrentState2Controller()
    	if ((LastLightState==LIGHT_OFF)||(LastDimValue==0)) {
    		send(dimmerMsg.set((int16_t)0));
    		send(dimmerMsg.set(LastDimValue));
    mfalkviddM Boots33B 2 Replies Last reply
    • PlantexP Plantex
      Hi
      Thanks in advance.
      #define LIGHT_OFF 0
      #define LIGHT_ON 1
      #define SV "1.0"
      			return;
      			LastDimValue=100;
      			return;
      		if (dimvalue==0) {
      		return;
      @Plantex could you post the serial output fom the node? That would be very useful, allowing us to see what happens.
      • PlantexP Plantex
        Hi
        Thanks in advance.
        #define LIGHT_OFF 0
        #define LIGHT_ON 1
        #define SV "1.0"
        			return;
        			LastDimValue=100;
        			return;
        		if (dimvalue==0) {
        		return;
        Boots33B
        Boots33B
        Boots33
        wrote on last edited by Boots33
        @plantex said in Dimmable LED help needed !:
        Hi
        Yes that is how that sketch was written to work. You can change it to work the way you want. There are several ways you could attack the problem, you could save the dimmer level to eeprom or perhaps request the dimmer level from the controller.
        Which part is responsible for sending the information to LED_PIN 3 ? I tried to >define LED pin3, also fade delay etc... to the below sketch - no luck.
        It is the line
         analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        But as you have already found the line below is responsible for turning on the lights at 100% when the switch is used
        Does it matter if the variables are V_LIGHT and V_DIMMER if the type is >S_DIMMER ? (both sketches) Shouldn't it be V_STATUS and V_PERCENTAGE ?
        While they are interchangeable and working for the present V_LIGHT and V_DIMMER have both been deprecated and may not work in future releases of MySensors. You should use V_STATUS and V_PERCENTAGE instead.
        To get you started I have made a quick change to the the code from the build dimmer page. I have not tested it so give it a try and see if it does what you want.
         * Version 1.0 - February 15, 2014 - Bruce Lacey
         * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
         * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
         * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
         * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
         * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
         * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
         * to the LED negative terminal and the MOSFET Source pin is connected to ground.
         * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
         * http://www.mysensors.org/build/dimmer
        #define SN "DimmableLED"
        #define SV "1.1"
        #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
        #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
        static int16_t currentLevel = 0;  // Current dim level...
        int dimmerSetting = 0 ;
        MyMessage dimmerMsg(0, V_PERCENTAGE);
        MyMessage lightMsg(0, V_STATUS);
         * Dimmable LED initialization method
        	// Pull the gateway's current dim level - restore light level upon sendor node power-up
        	request( 0, V_PERCENTAGE );
        	// Register the LED Dimmable Light with the gateway
        	present( 0, S_DIMMER );
         *  Dimmable LED main processing loop
        	if (message.type == V_LIGHT || message.type == V_DIMMER) {
        		Serial.print( "Changing level to " );
        		Serial.print( ", from " );
        		Serial.println( currentLevel );
        		fadeToLevel( requestedLevel );
        		send(lightMsg.set(currentLevel > 0));
        		// hek comment: Is this really nessesary?
        		send( dimmerMsg.set(currentLevel) );
        switch (message.type) {
          case V_STATUS:                                           // message is from the switch
           if(message.getBool()){
             fadeToLevel( dimmerSetting );                         // turn light on at current dimmer level
           else fadeToLevel( 0 );                                  // fade light to 0 (off)
         case V_PERCENTAGE:                                        // message is from the dimmer
           dimmerSetting = message.getInt();                       // get the new dimmer setting from the message
           fadeToLevel( dimmerSetting );                           // fade to the new dimmer setting
           send(lightMsg.set(dimmerSetting > 0 ? 1 : 0), false);   // send switch  state to controller , no ack requested
         *  This method provides a graceful fade up/down effect
        void fadeToLevel( int toLevel )
        	int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
        	while ( currentLevel != toLevel ) {
        		currentLevel += delta;
        		delay( FADE_DELAY );
        • PlantexP
          PlantexP
          Plantex
          @Boots33
          Thank You
          I've uploaded Your sketch. I don't know why but LED went from 0 to 100% six times in a row, then it stayed on.
          When I opened serial monitor in Arduino - it did the same (six times 0-100%) and my debug stopped on the line:
          2202 TSF:MSG:READ,0-0-153,s=0,c=2,t=3,pt=0,l=3,sg=0:666
          8909 TSF:MSG:SEND,153-153-0-0,s=0,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
          (666 interesting ;) )
          Then from Domoticz
          Status of the switch was OFF but LED was actually physically ON - so I moved the bar to 33% and it did again (six times but this time from 100% to 33% and stayed on 33%)
          After that It started to behave normally when I moved the bar to 56% and to 9%
          So basically It works but every initial start whatever it is (uploading sketch, serial monitor, switch on from domoticz) it is doing 6 times complete range
          Any Idea why it is doing that ?
          Right now I'm planning to extend it to few more led stripes but this will be next step.
          Below my debug from the steps described above:
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          13 TSF:SID:OK,ID=153
          14 TSM:FPAR
          51 TSF:MSG:SEND,153-153-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          128 TSF:MSG:READ,0-0-153,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          133 TSF:MSG:FPAR OK,ID=0,D=1
          2058 TSM:FPAR:OK
          2059 TSM:ID
          2060 TSM:ID:OK
          2062 TSM:UPL
          2065 TSF:MSG:SEND,153-153-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          2071 TSF:MSG:READ,0-0-153,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          2076 TSF:MSG:PONG RECV,HP=1
          2079 TSM:UPL:OK
          2080 TSM:READY:ID=153,PAR=0,DIS=1
          2085 TSF:MSG:SEND,153-153-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          2093 TSF:MSG:READ,0-0-153,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          2100 TSF:MSG:SEND,153-153-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
          2109 TSF:MSG:SEND,153-153-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          2116 TSF:MSG:READ,0-0-153,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          2123 TSF:MSG:SEND,153-153-0-0,s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
          2131 TSF:MSG:SEND,153-153-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:DimmableLED
          2141 TSF:MSG:SEND,153-153-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
          2148 MCO:REG:REQ
          2151 TSF:MSG:SEND,153-153-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          2158 TSF:MSG:READ,0-0-153,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          2163 MCO:PIM:NODE REG=1
          2165 MCO:BGN:STP
          2168 TSF:MSG:SEND,153-153-0-0,s=0,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          2174 MCO:BGN:INIT OK,TSP=1
          267588 TSF:MSG:READ,0-0-153,s=1,c=1,t=3,pt=0,l=2,sg=0:33
          267593 TSF:MSG:ACK REQ
          267597 TSF:MSG:SEND,153-153-0-0,s=1,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:33
          273975 TSF:MSG:SEND,153-153-0-0,s=0,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
          276599 TSF:MSG:READ,0-0-153,s=1,c=1,t=3,pt=0,l=2,sg=0:56
          276604 TSF:MSG:ACK REQ
          276609 TSF:MSG:SEND,153-153-0-0,s=1,c=1,t=3,pt=0,l=2,sg=0,ft=0,st=OK:56
          276848 TSF:MSG:SEND,153-153-0-0,s=0,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
          281715 TSF:MSG:READ,0-0-153,s=1,c=1,t=3,pt=0,l=1,sg=0:9
          281720 TSF:MSG:ACK REQ
          281724 TSF:MSG:SEND,153-153-0-0,s=1,c=1,t=3,pt=0,l=1,sg=0,ft=0,st=OK:9
          282206 TSF:MSG:SEND,153-153-0-0,s=0,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
          Boots33B 1 Reply Last reply
          • PlantexP Plantex
            @Boots33
            Thank You
            Then from Domoticz
            3 TSM:INIT
            4 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            14 TSM:FPAR
            2058 TSM:FPAR:OK
            2059 TSM:ID
            2060 TSM:ID:OK
            2062 TSM:UPL
            2079 TSM:UPL:OK
            2148 MCO:REG:REQ
            2165 MCO:BGN:STP
            Boots33B
            Boots33B
            Boots33
            @plantex
            I think the 666 is coming from the initial request made in setup part of the sketch. Perhaps because it is made before the presentation of the node we are getting invalid data?
            I see that in the original part of the sketch that I commented out there is code to constrain the percentage value between 0 and 100 . So maybe this is a known issue. We may need to move the request to the main loop instead.
            In any case we can make a couple of changes to see if it is the cause of the multi switching.
            at the start of the sketch change
            to
            int dimmerSetting = 100 ;
            Then comment out the request call in the setup section.
            //request( 0, V_PERCENTAGE );
            Now when the node first boots it should turn the lights on to 100% when the switch is used. However once you have set the dimmer it will use that percentage instead.
            I know this is not how you want the final node to work, this is just to see if the request is what is causing the trouble.
            • PlantexP
              PlantexP
              Plantex
              wrote on last edited by Plantex
              Hi
              Instead of trying to solve the problem for 1 Led stripe I've decided to go with 6 pcs now - basically I'm gonna need this anyway to do my "high-end" stairs.
              So what I've done is I've combined Your sketch with some other especially the part with few led's declaration
              #define MY_RF24_CE_PIN 49
              #define MY_RF24_CS_PIN 53
              #define MY_NODE_ID 153
              #define SV "1.1"
              #define noLEDs 6
              const int LED_Pin[] = {3, 5, 6, 9, 10, 11};
              //#define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
              MyMessage dimmerMsg(noLEDs, V_PERCENTAGE);
              MyMessage lightMsg(noLEDs, V_STATUS);
               for (int sensor=1; sensor<=noLEDs; sensor++){
                  //request( sensor, V_PERCENTAGE );
               present(sensor, S_DIMMER);
               wait(2);
                   fadeToLevel( dimmerSetting, message.sensor );                         // turn light on at current dimmer level
                 else fadeToLevel( 0, message.sensor  );                                  // fade light to 0 (off)
                 fadeToLevel( dimmerSetting, message.sensor );                           // fade to the new dimmer setting
              void fadeToLevel( int toLevel, int ledid ) {
                  analogWrite( LED_Pin[ledid-1], (int)(currentLevel / 100. * 255) );
              So I have right now 6 LEDs in Domoticz connected to Arduino Mega 3,5,6,9,10,11 pins ( I hope all of them are PWM)
              At first usage It behaves crazy - It's like every switch needs the first on and off sequence to start behave normally.
              What happens then:
              LED 1 ,2, 3, 5 - all work ok , every single one saves the last state when switch off/on , dimmer bar works fine
              now the best part :D
              LED 4 - when I switch it On (mouse click in Domoticz) LED is going ON (physically) but the same time LED 1,2,3 is going ON (but only in Domoticz so let's say they are virtually ON but in reality OFF) - dimmer bar LED 4 works ok , saves the last status, You can switch it off but 1,2,3 will be still ON (you have to click each one to take off the virtual status)
              LED 6 - works very similar to 1,2,3,5 - when I move the dimmer bar to e.g. 15% LED it is reacting it is ok BUT suddenly after 1-2 seconds dimmer bar goes to full range (led still shines 15%)
              LED 6 Is also unique - if I play with any of the switches and dimmer (1,2,3,4,5) this one is going virtually ON (domoticz reporting it is on - and its bar is going to full range)
              Please help me to understand where is this behavior coming from.
              Honestly I am not a programmer I am not even sure If the sketch which I combined is anyhow feasible.
              I had to add some messages so I added everywhere after Your dimmerSetting a line.. message.sensor - but I have no idea what it does. Not sure if it should be message.sensor or something else.
              and this
              and this
              I am thinking maybe I can sacrifice "save the last dimmer value" - just to get this leds working normal :( :( :(
              Help Anybody !
              P.S
              I can paste my debug but there is so many problems I dont even know which bahavior case ( LED 4 or LED 6 or LED1 etc..) I should paste from my debug
              • PlantexP Plantex
                Hi
                #define SV "1.1"
                #define noLEDs 6
                 wait(2);
                What happens then:
                and this
                and this
                Help Anybody !
                P.S
                Boots33B
                Boots33B
                Boots33
                Hi
                I do not think it is a good idea to add complexity to an already non working sketch. You should concentrate on getting the single sketch to work first and then add more later.
                You should also have a clear idea of how you want the lights to work before you proceed any further. It will certainly make a difference to the coding.
                P.S
                This is why you should keep it simple and get that to work first
                • PlantexP
                  PlantexP
                  Plantex
                  @Boots33 I think I wasn't precise enough.
                  So below the sketch which is working fine but for one LED stripe. It remembers the last dimmer value.
                  I 've changed it a little bit. It works better for me to receive and display in Domoticz a % dimmer value info instead of information ON/OFF
                  send(lightMsg.set(dimmerSetting > 0 ? 1 : 0), false)  changed to  send(dimmerMsg.set(dimmerSetting));
                  Now my target is to use the maximum quantity of PWM pins in Arduino MEGA (in total I need 16 so I think I am gonna need two Arduinos)
                  Anyway could You help me please to add extra LEDs into this sketch ?
                  #define SN "Dimmable_LED"
                  #define SV "1.1"
                  int dimmerSetting = 10 ;
                     send(dimmerMsg.set(dimmerSetting));                    // send switch  state to controller , no ack requested
                     wait( FADE_DELAY );
                  12.5k
