  3. Power sensors stopped working
openhab2
13 Posts 4 Posters 3.1k Views 3 Watching
    Did you try to reflash them? Did you try to do a debug to see if they are actually measuring something?
    • jocke4uJ jocke4u
      I have 3 power sensors running (total, house heater and water heater). They have been working for a long time.
      Last weekend I had a power outage and they stopped working.
      Other sensors works.
      Watching in MYSController and power sensors reports V_VAR1 but message is empty.
      Any idea why?
      C
      C
      chorob
      @jocke4u could you share some more information on your power sensors? Pictures and sketch? I am trying to replace my ubiquiti mfi setup and power sensors are my last sensors to go. Thanks!
      gohanG 1 Reply Last reply
      • C chorob
        @chorob I got a sonoff pow and some gewiss material to make a similar unifi mfi, but I only have one relay
        • jocke4uJ
          jocke4uJ
          jocke4u
          I have been debugging a bit now and the sensor receives pulses but the issue seems to be that it doesn't receive the old pulse count from GW (Ethernet) and therefore doesn't send the values.
          I have upgraded the GW to 2.1.1 and with the sketch below
           * Version 1.0 - Henrik EKblad
           * LED purposes:
          #define MY_GATEWAY_W5100
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          // Enable to UDP
          //#define MY_USE_UDP
          #define MY_IP_ADDRESS 192,168,1,11   // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
          #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
          #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
          #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
          #include <Ethernet.h>
          Do I need to have any other implementation to save pulses?
          The Sketch for the energy meter looks like below (currently some extra printout's):
           * This sketch provides an example how to implement a distance sensor using HC-SR04
           * Use this sensor to measure KWH and Watt of your house meeter
           * You need to set the correct pulsefactor of your meeter (blinks per KWH).
           * The sensor starts by fetching current KWH value from gateway.
           * Reports both KWH and Watt back to gateway.
           * Unfortunately millis() won't increment when the Arduino is in
           * sleepmode. So we cannot make this sensor sleep if we also want
           * to calculate/report watt-number.
           * http://www.mysensors.org/build/pulse_power
          // Enable debug prints
          #define MY_NODE_ID 5
          #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
          #define CHILD_ID 0              // Id of the sensor child
          unsigned long SEND_FREQUENCY =
              20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
          double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
          bool pcReceived = false;
          unsigned long oldPulseCount = 0;
          unsigned long oldWatt = 0;
          double oldKwh;
          unsigned long lastSend;
          MyMessage wattMsg(CHILD_ID,V_WATT);
          MyMessage kwhMsg(CHILD_ID,V_KWH);
          MyMessage pcMsg(CHILD_ID,V_VAR1);
            request(CHILD_ID, V_VAR1);
            pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
            attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
            lastSend=millis();
            sendSketchInfo("Heater Energy", "2.0");
            present(CHILD_ID, S_POWER);
            unsigned long now = millis();
            if (pcReceived && sendTime) {
              if (watt != oldWatt) {
                if (watt<((unsigned long)MAX_WATT)) {
                Serial.print("Watt:");
                Serial.println(watt);
                oldWatt = watt;
              // Pulse cout has changed
              if (pulseCount != oldPulseCount) {
                send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                oldPulseCount = pulseCount;
                if (kwh != oldKwh) {
                  send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                  oldKwh = kwh;
              lastSend = now;
            } else if (sendTime && !pcReceived) {
              // No count received. Try requesting it again
              Serial.println("No count received. Try requesting it again");
              lastSend=now;
            Serial.print("MessageType:");
            Serial.println(message.type);
            Serial.print("Message:");
            Serial.println(message.getLong());
            if (message.type==V_VAR1) {
              pulseCount = oldPulseCount = message.getLong();
              Serial.print("Received last pulse count from gw:");
              Serial.println(pulseCount);
              pcReceived = true;
          void onPulse()
            Serial.println("Got Pulse");
            unsigned long interval = newBlink-lastBlink;
            if (interval<10000L) { // Sometimes we get interrupt on RISING
              return;
            watt = (3600000000.0 /interval) / ppwh;
            lastBlink = newBlink;
            pulseCount++;
          The debug log looks like:
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          13 TSM:INIT:STATID=5
          14 TSF:SID:OK,ID=5
          16 TSM:FPAR
          52 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2060 !TSM:FPAR:NO REPLY
          2062 TSM:FPAR
          2098 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2983 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          2989 TSF:MSG:FPAR OK,ID=0,D=1
          4106 TSM:FPAR:OK
          4107 TSM:ID
          4108 TSM:ID:OK
          4110 TSM:UPL
          4147 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
          6154 TSM:UPL
          6159 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
          6168 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          6173 TSF:MSG:PONG RECV,HP=1
          6175 TSM:UPL:OK
          6177 TSM:READY:ID=5,PAR=0,DIS=1
          6182 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          6189 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          6232 !TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
          6243 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
          6259 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          6305 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=NACK:Heater Energy
          6349 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=NACK:2.0
          6391 !TSF:MSG:SEND,5-5-0-0,s=0,c=0,t=13,pt=0,l=0,sg=0,ft=2,st=NACK:
          6397 MCO:REG:REQ
          6435 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=NACK:2
          8476 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
          10486 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=OK:2
          10493 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          10499 MCO:PIM:NODE REG=1
          10501 MCO:BGN:STP
          10528 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
          Got Pulse
          10534 MCO:BGN:INIT OK,TSP=1
          Got Pulse
          Got Pulse
          Got Pulse
          Got Pulse
          Got Pulse
          Got Pulse
          30570 !TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=NACK:
          Got Pulse
          Got Pulse
          Got Pulse
          Got Pulse
          Got Pulse
          Got Pulse
          Got Pulse
          50546 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=1,st=OK:
          Got Pulse
            Then it could be the controller not responding to requests for value?
            • jocke4uJ
              jocke4uJ
              jocke4u
              I guess so - using openHAB 2.2.0 stable and quite late snapshot mysensors-binding for 2.2.0.
              Maybe @TimO have an idea?
                I remember another post about Openhab not responding to requests not long ago, maybe it is related
                  sundberg84S
                  sundberg84S
                  @gohan - I have had this issue in Domoticz as well several times. A nod requestiong a V_Var1 can sometimes takes up to 30 min to get a response and I think its something to do with timing and/or repeaters in the response. It seems like Domoticz is answering. That was the main reason i build my logger to debug this but so far I have not encountered it again.
                  • sundberg84S sundberg84
                    @sundberg84 said in Power sensors stopped working:
                    30 min
                    That is quite a lot of time
                      30 min
                      sundberg84S
                      sundberg84S
                      @gohan in my mind and without any evidence its like the request comes fine to the gw, responded by domoticz but the answer from the gw and back to the node gets lost through the repeater... I dont know this for sure though!
                        without repeater it works better then?
                          sundberg84S
                          sundberg84S
                          Without any evidence - yes. I have not made that much tests yet since I waited for my logger. I have made some posts about this on the forum. I dont want to make any conclusions yet. @gohan
