  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.7k Views 34 Watching
  • jocke4uJ jocke4u
    I am moving the topic here as more appropriate :) (old ref)
    I have OH v2.2 and latest MySensors 2.2.0 binding and my power sensors have stopped working.
    After some investigation it seems they cannot receive the old pulse count value and by that cannot start working.
    MySensors GW running 2.1.1 and the one power sensor I am testing also 2.1.1 (the rest 1.5.x)
    The debug (serial monitor) of the sensor shows that
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:STATID=5
    14 TSF:SID:OK,ID=5
    16 TSM:FPAR
    52 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2060 !TSM:FPAR:NO REPLY
    2062 TSM:FPAR
    2098 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2983 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2989 TSF:MSG:FPAR OK,ID=0,D=1
    4106 TSM:FPAR:OK
    4107 TSM:ID
    4108 TSM:ID:OK
    4110 TSM:UPL
    4147 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    6154 TSM:UPL
    6159 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
    6168 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    6173 TSF:MSG:PONG RECV,HP=1
    6175 TSM:UPL:OK
    6177 TSM:READY:ID=5,PAR=0,DIS=1
    6182 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    6189 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    6232 !TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
    6243 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
    6259 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    6305 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=NACK:Heater Energy
    6349 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=NACK:2.0
    6391 !TSF:MSG:SEND,5-5-0-0,s=0,c=0,t=13,pt=0,l=0,sg=0,ft=2,st=NACK:
    6397 MCO:REG:REQ
    6435 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=NACK:2
    8476 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=NACK:2
    10486 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=OK:2
    10493 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    10499 MCO:PIM:NODE REG=1
    10501 MCO:BGN:STP
    10528 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    Got Pulse
    10534 MCO:BGN:INIT OK,TSP=1
    Got Pulse
    Got Pulse
    Got Pulse
    Got Pulse
    Got Pulse
    Got Pulse
    No count received. Try requesting it again
    30570 !TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=NACK:
    Got Pulse
    Got Pulse
    Got Pulse
    Got Pulse
    Got Pulse
    Got Pulse
    Got Pulse
    50546 TSF:MSG:SEND,5-5-0-0,s=0,c=2,t=24,pt=0,l=0,sg=0,ft=1,st=OK:
    Got Pulse
    The sketch looks like this:
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a distance sensor using HC-SR04
     * Use this sensor to measure KWH and Watt of your house meeter
     * You need to set the correct pulsefactor of your meeter (blinks per KWH).
     * The sensor starts by fetching current KWH value from gateway.
     * Reports both KWH and Watt back to gateway.
     * Unfortunately millis() won't increment when the Arduino is in
     * sleepmode. So we cannot make this sensor sleep if we also want
     * to calculate/report watt-number.
     * http://www.mysensors.org/build/pulse_power
    // Enable debug prints
    #define MY_NODE_ID 5
    #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID 0              // Id of the sensor child
    unsigned long SEND_FREQUENCY =
        20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    bool pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
      request(CHILD_ID, V_VAR1);
      pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
      lastSend=millis();
      sendSketchInfo("Heater Energy", "2.0");
      present(CHILD_ID, S_POWER);
      unsigned long now = millis();
      if (pcReceived && sendTime) {
        if (watt != oldWatt) {
          if (watt<((unsigned long)MAX_WATT)) {
          Serial.print("Watt:");
          Serial.println(watt);
          oldWatt = watt;
        // Pulse cout has changed
        if (pulseCount != oldPulseCount) {
          send(pcMsg.set(pulseCount));  // Send pulse count value to gw
          double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
          oldPulseCount = pulseCount;
          if (kwh != oldKwh) {
            send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
            oldKwh = kwh;
        lastSend = now;
      } else if (sendTime && !pcReceived) {
        // No count received. Try requesting it again
        Serial.println("No count received. Try requesting it again");
        lastSend=now;
      Serial.print("MessageType:");
      Serial.println(message.type);
      Serial.print("Message:");
      Serial.println(message.getLong());
      if (message.type==V_VAR1) {
        pulseCount = oldPulseCount = message.getLong();
        Serial.print("Received last pulse count from gw:");
        Serial.println(pulseCount);
        pcReceived = true;
    void onPulse()
      Serial.println("Got Pulse");
      unsigned long interval = newBlink-lastBlink;
      if (interval<10000L) { // Sometimes we get interrupt on RISING
        return;
      watt = (3600000000.0 /interval) / ppwh;
      lastBlink = newBlink;
      pulseCount++;
    Today I realized that I likely need to have item(s) created in OH to save the values - so created Var1 (and then added one after another with no success). Currently it looks like:
    Number CellarAirHeaterSensorWatt   "Airheater Watt" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:watt", mqtt=">[rabbitmq:/myhouse/airpump/sensor/power:state:*:Power,sensor=${itemName},location=airpump watt=${state} ]" }
    Number CellarAirHeaterSensorKwh    "Airheater Kwh" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:kwh", mqtt=">[rabbitmq:/myhouse/airpump/sensor/power:state:*:Power,sensor=${itemName},location=airpump kwh=${state} ]" }
    Number CellarAirHeaterSensorVar   "Airheater Var" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:var" }
    Number CellarAirHeaterSensorVar1   "Airheater Var1" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:var1" }
    Number CellarAirHeaterSensorVA   "Airheater VA" <energy> { channel="mysensors:power:gateway:sensor-air-pump-power:va" }
    Still no success!
    Do you have any idea what's wrong?
    TimO
    wrote on last edited by TimO
    #91
    @jocke4u The request needs to be handled with rules because it is not allowed to access the value of an item via the binding API :smirk:.
    Please post the request (from the OpenHAB log, enable DEBUG with log:set DEBUG org.openhab.binding.mysensors if not already done in the karaf console) and we'll figure out the rule.
    NickBuilderN jocke4uJ 2 Replies Last reply
    • T TimO
      NickBuilderN
      NickBuilderN
      NickBuilder
      wrote on last edited by NickBuilder
      #92
      @timo regarding the issue with the pulse power node, the same as @jocke4u. I'm using a version of the same sketch and also the latest snapshot jar.
      This is the feedback in my openhab.log while looking att the debug level messages from the binding.
      15:59:15.829 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
      15:59:15.834 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
      15:59:15.839 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
      15:59:15.844 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 50
      15:59:15.849 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
      15:59:15.854 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
      15:59:15.859 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
      15:59:15.864 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 1 found in node 50
      15:59:15.869 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
      15:59:15.874 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 50;1;2;0;24;
      15:59:15.879 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 50 found in gateway
      As you can see the messages are quite frequent making it quite tedious for me to extract the relevant log messages. I'm no expert in browsing and searching text files from the command line.
      I guess because I'm using a version of the standard sketch my node does not wait for a response to the request before starting to count. I'm not sure how the node can neglect the response. Anyhow I restarted my node and now it tried to SET a new count instead.
      2018-01-10 16:26:22.341 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
      2018-01-10 16:26:22.571 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
      2018-01-10 16:26:22.791 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
      2018-01-10 16:26:23.011 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
      2018-01-10 16:26:23.230 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 50;1;1;0;24;150
      Hopefully this is useful feedback.
      jocke4uJ 1 Reply Last reply
      • T TimO
        jocke4uJ
        jocke4uJ
        jocke4u
        Hi @timo ,
        Here is the log when restarting the sensor:
        17:27:58.562 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;0;0;17;2.1.1
        17:27:58.573 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Presentation Message received
        17:27:58.583 [WARN ] [ors.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
        17:27:58.593 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;6;0
        17:27:58.603 [DEBUG] [ors.internal.gateway.MySensorsGateway] - I_CONFIG request received from M, answering: (is imperial?)false
        17:27:58.614 [DEBUG] [orsAbstractConnection$MySensorsWriter] - Sending to MySensors: 5;255;3;0;6;M
        17:27:58.674 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;11;Heater Energy
        17:27:58.682 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;255;3;0;12;2.0
        17:27:58.690 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;0;0;0;13;
        17:27:58.698 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Presentation Message received
        17:27:58.705 [WARN ] [ors.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
        17:27:58.719 [DEBUG] [orsAbstractConnection$MySensorsReader] - Message from gateway received: 5;0;2;0;24;
        17:27:58.727 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Node 5 found in gateway
        17:27:58.735 [DEBUG] [ors.internal.gateway.MySensorsGateway] - Child 0 found in node 5
        17:27:58.743 [WARN ] [ors.internal.gateway.MySensorsGateway] - Request received, but variable state is not yet defined
        • NickBuilderN NickBuilder
          jocke4uJ
          jocke4uJ
          jocke4u
          @nickbuilder Check the code here and there is a SEND_FREQUENCY of 20 sec - would reduce the load quite a lot :)
          • T
            TimO
            @jocke4u & @NickBuilder :
            Thank you! This will help me to find a solution. For reference, here is the corresponding issue on github: https://github.com/tobof/openhab2-addons/issues/69
            • T TimO
              jocke4uJ
              jocke4uJ
              jocke4u
              @timo Ok, so there is a plan to solve it in a better way than using rules?
              Do you have any guidance of using rules until then?
              T NickBuilderN 2 Replies Last reply
              • jocke4uJ jocke4u
                TimO
                @jocke4u I'll try to document an example for using rules tomorrow. I'm not yet sure about the best final solution. Maybe I'll experiment with persistence within the binding.
                • L
                  L
                  LastSamurai
                  wrote on last edited by LastSamurai
                  #98
                  @TimO Today I decided to finally read into how Openhab binding development works. And just when I started I saw that you finally fixed some of the problems that I reported via github (thank you very much for that). Had to laugh a little at that coincidence :rolling_on_the_floor_laughing:
                  I just started a pullrequest where I tried to implement pure white colors for RGBW values fixing one of my problems left open. If you find the time please have a look at it. I did not yet write any tests for it or test it on my actual RGBW nodes but I will do that as soon as possible
                  • K
                    K
                    kwull
                    wrote on last edited by kwull
                    #99
                    [Solved] I've solved the issue by changing docker base image. The issue described here - https://github.com/openhab/openhab-docker/issues/144
                    I'll keep the details for others:
                    @TimO, thanks for the great openhab binding. I've used it on openhab 2.0 and it works just great. Now I have totally fresh openhab 2.2 setup and cannot make mysensors binding working. I've tried many things but with no luck. Can you point me into direction how to fix that?
                    The gateway works as expected:
                    root@machine:/home/kwull# cat /dev/ttyUSB0
                    0;1;1;0;0;22.3
                    0;0;1;0;1;23.0
                    0;255;0;0;18;2.1.1
                    0;255;3;0;11;Garage Gateway
                    0;255;3;0;12;1.0
                    0;0;0;0;7;
                    0;1;0;0;6;
                    0;1;1;0;0;23.1
                    0;0;1;0;1;22.1
                    Bindings:
                    25 │ Active   │  80 │ 3.12.0.OH              │ nrjavaserial
                    210 │ Active   │  80 │ 1.0.2                  │ Paho MQTT Client
                    211 │ Active   │  80 │ 0.10.0.b1              │ Eclipse SmartHome MQTT Transport Bundle
                    214 │ Active   │  80 │ 2.3.0.201801160936     │ MySensors Binding
                    openhab.log:
                    2018-01-21 17:18:33.696 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                    2018-01-21 17:18:33.703 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                    2018-01-21 17:18:33.704 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: []
                    2018-01-21 17:18:33.710 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
                    2018-01-21 17:18:33.712 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
                    2018-01-21 17:18:33.715 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=325, service.bundleid=214, service.scope=singleton} - org.openhab.binding.mysensors
                    2018-01-21 17:18:33.716 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                    2018-01-21 17:18:33.716 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                    2018-01-21 17:18:36.027 [WARN ] [org.jline                           ] - Unable to create a system terminal, creating a dumb terminal (enable debug logging for more information)
                    Exception log:
                    Current thread (0x000055797e792800):  JavaThread "org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection" [_thread_in_native, id=641, stack(0x00007f12eb309000,0x00007f12eb409aa8)]
                    siginfo: si_signo: 11 (SIGSEGV), si_code: 1 (SEGV_MAPERR), si_addr: 0x00000000000037a6
                    Registers:
                    RAX=0x0000000000000000, RBX=0x00007f12e7403940, RCX=0x00007f13197e3f04, RDX=0x00007f131934828c
                    RSP=0x00007f12eb407d48, RBP=0x0000000000000001, RSI=0x0000000000000900, RDI=0x000055797ccb99a0
                    R8 =0x000055797ccb99ac, R9 =0x000055797ccb99a0, R10=0x00000006d600e9d0, R11=0x0000000000000206
                    R12=0x000055797ccb99a0, R13=0x000055797e7929e0, R14=0x00007f12eb407ec8, R15=0x0000000000000082
                    RIP=0x00000000000037a6, EFLAGS=0x0000000000010202, CSGSFS=0x0000000000000033, ERR=0x0000000000000014
                      TRAPNO=0x000000000000000e
                    Top of Stack: (sp=0x00007f12eb407d48)
                    0x00007f12eb407d48:   00007f12e64e0965 00007f12eb407de8
                    0x00007f12eb407d58:   00007f1300000001 00007f12e7403940
                    0x00007f12eb407d68:   000055797e792800 00007f12e7403940
                    0x00007f12eb407d78:   d85a256e98c0817f 00007f12eb407de8
                    0x00007f12eb407d88:   00007f1318b46afc 00007f12eb407de8
                    0x00007f12eb407d98:   00007f12eb407dc8 00007f12eb407de8
                    0x00007f12eb407da8:   00007f1318b46b68 000055797e792800
                    0x00007f12eb407db8:   00007f1318c99928 0000557981a9a5f0
                    0x00007f12eb407dc8:   000055797e792800 000055797e792800
                    0x00007f12eb407dd8:   00007f12e7403940 000055797e792800
                    0x00007f12eb407de8:   00007f12e7403940 000055797e792800
                    0x00007f12eb407df8:   d85a256e98c0817f 00007f12e7403940
                    0x00007f12eb407e08:   00007f12e7403940 00007f12eb407ea0
                    0x00007f12eb407e18:   0000000000000000 00007f12e7403940
                    0x00007f12eb407e28:   00007f12eb407ed0 000055797e792800
                    0x00007f12eb407e38:   00007f1308ccd7f4 00007f12eb407ea0
                    0x00007f12eb407e48:   00007f1308ccd579 fffffffe00000000
                    0x00007f12eb407e58:   00007f1308ccd542 00007f12eb407e60
                    0x00007f12eb407e68:   00007f12e7403940 00007f12eb407ed0
                    0x00007f12eb407e78:   00007f12e7405c28 0000000000000000
                    0x00007f12eb407e88:   00007f12e7403940 0000000000000000
                    0x00007f12eb407e98:   00007f12eb407ec0 00007f12eb407f18
                    0x00007f12eb407ea8:   00007f1308cbd7d0 0000000000000000
                    0x00007f12eb407eb8:   00007f1308cc7260 0000000000000001
                    0x00007f12eb407ec8:   00000006d600e9a8 00000006d600b490
                    0x00007f12eb407ed8:   00007f12eb407ed8 00007f12e7404122
                    0x00007f12eb407ee8:   00007f12eb407f98 00007f12e7405c28
                    0x00007f12eb407ef8:   0000000000000000 00007f12e7404270
                    0x00007f12eb407f08:   00007f12eb407ec0 00007f12eb407f80
                    0x00007f12eb407f18:   00007f12eb407fe0 00007f1308cbdffd
                    0x00007f12eb407f28:   0000000000000000 0000000000000000
                    0x00007f12eb407f38:   0000000000000000 00000006d600e9a8
                    Instructions: (pc=0x00000000000037a6)
                    0x0000000000003786:
                    [error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xb]
                    Register to memory mapping:
                    RAX=0x0000000000000000 is an unknown value
                    RBX={method} {0x00007f12e7403940} 'testRead' '(Ljava/lang/String;I)Z' in 'gnu/io/RXTXCommDriver'
                    RCX=0x00007f13197e3f04: getpid+0x7 in /lib/ld-musl-x86_64.so.1 at 0x00007f131978d000
                    RDX=0x00007f131934828c: gHotSpotVMStructs+0x218f4 in /usr/lib/jvm/java-1.8-openjdk/jre/lib/amd64/server/libjvm.so at 0x00007f1318861000
                    RSP=0x00007f12eb407d48 is pointing into the stack for thread: 0x000055797e792800
                    RBP=0x0000000000000001 is an unknown value
                    RSI=0x0000000000000900 is an unknown value
                    RDI=0x000055797ccb99a0 is an unknown value
                    R8 =0x000055797ccb99ac is an unknown value
                    R9 =0x000055797ccb99a0 is an unknown value
                    R10=0x00000006d600e9d0 is pointing into object: 0x00000006d600e9c0
                    [C
                     - klass: {type array char}
                     - length: 12
                    R11=0x0000000000000206 is an unknown value
                    R12=0x000055797ccb99a0 is an unknown value
                    R13=0x000055797e7929e0 is an unknown value
                    R14=0x00007f12eb407ec8 is pointing into the stack for thread: 0x000055797e792800
                    R15=0x0000000000000082 is an unknown value
                    Stack: [0x00007f12eb309000,0x00007f12eb409aa8],  sp=0x00007f12eb407d48,  free space=1019k
                    Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
                    C  0x00000000000037a6
                    Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
                    j  gnu.io.RXTXCommDriver.testRead(Ljava/lang/String;I)Z+0
                    j  gnu.io.RXTXCommDriver.registerValidPorts([Ljava/lang/String;[Ljava/lang/String;I)V+202
                    j  gnu.io.RXTXCommDriver.registerScannedPorts(I)V+1466
                    j  gnu.io.RXTXCommDriver.initialize()V+35
                    j  gnu.io.CommPortIdentifier.getPortIdentifiers()Ljava/util/Enumeration;+53
                    j  gnu.io.NativeResource.testNativeCode()V+0
                    j  gnu.io.NativeResource.inJarLoad(Ljava/lang/String;)V+37
                    j  gnu.io.NativeResource.loadLib(Ljava/lang/String;)V+54
                    j  gnu.io.NativeResource.load(Ljava/lang/String;)V+138
                    j  gnu.io.SerialManager.<init>()V+23
                    j  gnu.io.SerialManager.getInstance()Lgnu/io/SerialManager;+10
                    j  gnu.io.RXTXCommDriver.<clinit>()V+39
                    v  ~StubRoutines::call_stub
                    J 1368  java.lang.Class.forName0(Ljava/lang/String;ZLjava/lang/ClassLoader;Ljava/lang/Class;)Ljava/lang/Class; (0 bytes) @ 0x00007f1309151eba [0x00007f1309151e40+0x7a]
                    J 3010 C1 java.lang.Class.forName(Ljava/lang/String;)Ljava/lang/Class; (15 bytes) @ 0x00007f13096ee94c [0x00007f13096ee7a0+0x1ac]
                    j  gnu.io.CommPortIdentifier.<clinit>()V+12
                    j  org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection()Z+32
                    j  org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect()Z+2
                    j  org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run()V+46
                    J 10253 C2 java.util.concurrent.Executors$RunnableAdapter.call()Ljava/lang/Object; (14 bytes) @ 0x00007f1309884cac [0x00007f1309884c60+0x4c]
                    J 9236 C1 java.util.concurrent.FutureTask.runAndReset()Z (128 bytes) @ 0x00007f130a4cd17c [0x00007f130a4ccf00+0x27c]
                    J 9408 C1 java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run()V (59 bytes) @ 0x00007f130a57bb8c [0x00007f130a57b600+0x58c]
                    J 8894 C1 java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V (225 bytes) @ 0x00007f130a3b8e3c [0x00007f130a3b7e00+0x103c]
                    j  java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5
                    J 11172 C1 java.lang.Thread.run()V (17 bytes) @ 0x00007f1308f58584 [0x00007f1308f58440+0x144]
                    Additional logs:
                    2018-01-08 20:55:18.426 [ERROR] [org.openhab.binding.mysensors       ] - [org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService(195)] Error during instantiation of the implementation object
                    java.lang.InstantiationException: org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService
                    	at java.lang.Class.newInstance(Class.java:427) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:237) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
                    	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) ~[?:?]
                    	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
                    	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
                    	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
                    	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
                    	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
                    	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) ~[?:?]
                    	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
                    	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
                    	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
                    	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
                    	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
                    	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
                    	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
                    	at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
                    	at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
                    	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
                    	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
                    	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
                    	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) ~[?:?]
                    	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
                    	at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
                    	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
                    	at org.eclipse.smarthome.extensionservice.marketplace.internal.BindingExtensionHandler.install(BindingExtensionHandler.java:82) ~[?:?]
                    	at org.eclipse.smarthome.extensionservice.marketplace.internal.MarketplaceExtensionService.install(MarketplaceExtensionService.java:222) ~[?:?]
                    	at org.eclipse.smarthome.io.rest.core.internal.extensions.ExtensionResource.lambda$0(ExtensionResource.java:157) ~[?:?]
                    	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
                    	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?]
                    	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?]
                    	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?]
                    	at java.lang.Thread.run(Thread.java:748) [?:?]
                    Caused by: java.lang.NoSuchMethodException: org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService.<init>()
                    	at java.lang.Class.getConstructor0(Class.java:3082) ~[?:?]
                    	at java.lang.Class.newInstance(Class.java:412) ~[?:?]
                    	... 65 more
                    2018-01-08 20:55:18.450 [WARN ] [org.openhab.binding.mysensors       ] - FrameworkEvent WARNING - org.openhab.binding.mysensors
                    org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
                    	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
                    Any ideas where to look?
                    K 1 Reply Last reply
                    • K kwull
                      0;1;1;0;0;22.3
                      0;0;1;0;1;23.0
                      0;255;0;0;18;2.1.1
                      0;255;3;0;12;1.0
                      0;0;0;0;7;
                      0;1;0;0;6;
                      0;1;1;0;0;23.1
                      0;0;1;0;1;22.1
                      Bindings:
                      openhab.log:
                      Exception log:
                      Registers:
                      0x0000000000003786:
                      [C
                       - length: 12
                      Additional logs:
                      	... 65 more
                      K
                      K
                      kwull
                      @kwull, @TimO - I've solved the issue by changing docker base image. The issue described here - https://github.com/openhab/openhab-docker/issues/144
                      • seeersS
                        seeersS
                        seeers
                        wrote on last edited by seeers
                        #101
                        Hi, I'd like to use the expert mode for viewing the raw messages from the serial gateway.
                        I've created a new thing and item
                        Thing:
                         mySensorsMessage mySMsg01   [ nodeId=999, childId=999 ]
                        Item:
                        String mySMsg01  "MySensorsMessage"   { channel="mysensors:mySensorsMessage:gateway:mySMsg01:mySensorsMessage" }
                        unfortunately i get no item state :
                        openhab> smarthome:items list my*
                        mySMsg01 (Type=StringItem, State=NULL, Label=MySensorsMessage, Category=null)
                        did I do something wrong here?
                        • seeersS
                          seeersS
                          seeers
                          ok, it works after updating to snapshot 2.3
                          btw: 2.3 requeres esh-io-transport-mqtt
                          Intallation in karaf console:
                          feature:install esh-io-transport-mqtt
                          • seeersS seeers
                            TimO
                            @seeers yes, I've located a bug in the expert mode an fixed it recently!
                            • L
                              L
                              LastSamurai
                              @TimO I saw that you fixed some other bugs too in the repo. Will you create a new version 2.3 of the binding soon? Or will there be more changes first?
                              As most of the changes (at least also) concern RGBW lighting I would really like to use it but I can't seem to build the binding locally (I postet the error in the git pr).
                              • jocke4uJ jocke4u
                                NickBuilderN
                                NickBuilderN
                                NickBuilder
                                #105
                                @jocke4u, I really want my power node to work so I was going to try to make my own rule based on the "expert" strategy and the 999 node/child.
                                But first I tried an even simpler approach, I added a var1-item from the power thing and now I have communication between node and gateway. Please give it a try yourself and see if it works for you.
                                More specifically I defined the following item:
                                Number PulseVar "Var1 [%d]" { channel="mysensors:power:gateway:pulseThing:var1" }
                                Be sure to also persist the item. I store it in a mapdb dataset:
                                PulseVar : strategy = everyChange, restoreOnStartup
                                FYI, my thing is defined as follows:
                                power pulseThing [ nodeId=50, childId=1 ]
                                Please give it a try and come back with the outcome.
                                EDIT: this feels like a too simple fix, I suspect that @TimO has made some changes in the 2.3 snapshot...
                                • ร
                                  ร
                                  รอเรือ
                                  Hi there!
                                  Maybe someone would like to help me a bit?
                                  I'm on openHAB 2.2 with mysensors binding 2.3.0.201801160936. I'm using a serial gateway that I reflashed today using MySensors 2.2.0 library. I have turned off debugging in the sketch.
                                  The problem is that I encounter an exception each time OH starts up.
                                  2018-02-11 11:05:59.342 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
                                  java.io.IOException: Underlying input stream returned zero bytes
                                          at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:288) [?:?]
                                          at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326) [?:?]
                                          at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178) [?:?]
                                          at java.io.InputStreamReader.read(InputStreamReader.java:184) [?:?]
                                          at java.io.BufferedReader.fill(BufferedReader.java:161) [?:?]
                                          at java.io.BufferedReader.readLine(BufferedReader.java:324) [?:?]
                                          at java.io.BufferedReader.readLine(BufferedReader.java:389) [?:?]
                                          at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection$MySensorsReader.run(MySensorsAbstractConnection.java:328) [255:org.openhab.binding.mysensors:2.3.0.201801160936]
                                  Thing config:
                                  Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSBmys", baudRate=115200, sendDelay=200, startupCheckEnabled=false ]
                                  Everything seems to work otherwise. The problem is that the warning draws my attention every time and of course I need to check if it's something serious that I'd need to act upon. I'd rather see that I get no exceptions/warnings in case the "problem" can be ignored.
                                  My question to you guys is if there is anything that I can do about it? Thanks for your kind help.
                                  Cheers!
                                  • L
                                    L
                                    LastSamurai
                                    @TimO I finally got around to testing my pureWhite RGBW code and at least for me its working like it should be. I saw you already merged this so I guess others can use it too very soon.
                                    What is still not working is the acknowledgment feature. I have one node that only gets about 90% of the messages without error, so I tried activating it there and on some other nodes too for testing. Result: success rate is down to ~50% for each node and I get messages about some acknowledgment on the console when no message has even been sent (nothing about a message from mysensors on the console and no rx/tx leds on the gateway). When I tested this some months ago I also saw no message at the client so I am pretty sure none gets send.
                                    So I guess this issue is still unresolved ;) I have no clue why on a first glance but if I can help just send me a message.
                                    • F
                                      F
                                      forexsieno
                                      Hello, I try to start using OpenHab as a controller and
                                      need some help, regarding mysensors binding 2.3.0. I get the bindings installed, but in bundle:list it's just installed and i don't get it Active.
                                      All other instruction for installation are done.
                                      Did feature:install openhab-transport-serial and feature:install esh-io-transport-mqtt and and "nrjavaserial" is Active.
                                      But mysensor binding just installed. How can I get it ACTIVE?
                                      Thank you for your help.
                                      • L
                                        L
                                        LastSamurai
                                        Do you still have an older version of Mysensors installed? Thats the only time I had such behaviour
                                        • nick van alstN
                                          nick van alstN
                                          nick van alst
                                          I've been using the binding for a while now!
                                          must say that i still have some problems with auto discovery, but manually adding the sensors work fine!
                                          I encountered a bug in 1 for the components.
                                          The GAS meter should contain a variable for V_VOLUME but in the logs i'm getting errors that the variable does not exist.
                                          i searched in the code and found out the the class for SGAS is not containing the V_VOLUME variable.
                                          file: MySensorsChildSGas.java
                                          github link: https://github.com/tobof/openhab2-addons/blob/MySensors_Binding/addons/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/internal/sensors/child/MySensorsChildSGas.java
                                          as by: https://www.mysensors.org/download/serial_api_20#sensor-types SGAS should also include a V_VOLUME variable as wel as a V_FLOW
                                          For now i adjusted my sensor to use one of the custom var fields. but it would be nice to use the V_VOLUME variable for this.
