  3. Raspberry Pi3 Gateway
16 Posts 3 Posters 5.7k Views 3 Watching
    @rajeev2301 could you post the configure command you used and what linux distribution you are running on the pi? Which version of MySensors are you using?
    rajeev2301R
    rajeev2301R
    rajeev2301
    @mfalkvidd
    I. am using Raspbian which was achieved through NOOBs
    gohanG 1 Reply Last reply
    • rajeev2301R rajeev2301
      @mfalkvidd
      @rajeev2301 please also include the configure settings you used and what mysensors version you are using
      rajeev2301R 1 Reply Last reply
        rajeev2301R
        rajeev2301R
        rajeev2301
        [0_1516950236523_config.txt](Uploading 100%) @gohan
        Please find the attached config settings.
        Sensor version : git clone https://github.com/TMR20/RF24.git
        <<problem comes here, when I tried installing PiRaspberrySerial========================>>
        pi@raspberrypi:~ $ git clone https://github.com/mysensors/Raspberry.git
        Cloning into 'Raspberry'...
        remote: Counting objects: 292, done.
        remote: Total 292 (delta 0), reused 0 (delta 0), pack-reused 292
        Receiving objects: 100% (292/292), 220.51 KiB | 0 bytes/s, done.
        Resolving deltas: 100% (126/126), done.
        pi@raspberrypi:~ $ cd Raspberry
        pi@raspberrypi:~/Raspberry $ make all && make install
        g++ -c -o MyGateway.o MyGateway.cpp -Wall -Ofast -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -I. -I/usr/local/include/RF24
        MyGateway.cpp: In member function ‘void MyGateway::setInclusionMode(boolean)’:
        MyGateway.cpp:234:3: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
        if (newMode != inclusionMode)
        MyGateway.cpp:237:5: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the ‘if’
        serial(PSTR("0;0;%d;0;%d;%d\n"), C_INTERNAL, I_INCLUSION_MODE, inclusionMode?1:0);
        g++ -c -o MySensor.o MySensor.cpp -Wall -Ofast -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -I. -I/usr/local/include/RF24
        g++ -c -o MyMessage.o MyMessage.cpp -Wall -Ofast -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -I. -I/usr/local/include/RF24
        g++ -c -o PiEEPROM.o PiEEPROM.cpp -Wall -Ofast -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -I. -I/usr/local/include/RF24
        g++ -c -o PiGateway.o PiGateway.cpp -Wall -Ofast -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -I. -I/usr/local/include/RF24
        g++ -o PiGateway MyGateway.o MySensor.o MyMessage.o PiEEPROM.o PiGateway.o -Wall -Ofast -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -I. -I/usr/local/include/RF24 -lrf24-bcm
        g++ -c -o PiGatewaySerial.o PiGatewaySerial.cpp -Wall -Ofast -lpthread -g -D__Raspberry_Pi -mfloat-abi=hard -D_TTY_NAME="/dev/ttyMySensorsGateway" -D_TTY_GROUPNAME="tty" -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -I. -I/usr/local/include/RF24
        In file included from /usr/include/c++/6/bits/char_traits.h:39:0,
        from /usr/include/c++/6/ios:40,
        from /usr/include/c++/6/ostream:38,
        from /usr/include/c++/6/iostream:39,
        from ./MyMessage.h:37,
        from ./MySensor.h:18,
        from ./MyGateway.h:16,
        from PiGatewaySerial.cpp:36:
        /usr/include/c++/6/bits/stl_algobase.h:243:56: error: macro "min" passed 3 arguments, but takes just 2
        min(const _Tp& __a, const _Tp& __b, _Compare __comp)
        /usr/include/c++/6/bits/stl_algobase.h:265:56: error: macro "max" passed 3 arguments, but takes just 2
        max(const _Tp& __a, const _Tp& __b, _Compare __comp)
        In file included from ./MySensor.h:18:0,
        /usr/include/c++/6/bits/stl_algobase.h:195:5: error: expected unqualified-id before ‘const’
        min(const _Tp& __a, const _Tp& __b)
        /usr/include/c++/6/bits/stl_algobase.h:195:5: error: expected ‘)’ before ‘const’
        /usr/include/c++/6/bits/stl_algobase.h:195:5: error: expected initializer before ‘const’
        /usr/include/c++/6/bits/stl_algobase.h:219:5: error: expected unqualified-id before ‘const’
        max(const _Tp& __a, const _Tp& __b)
        /usr/include/c++/6/bits/stl_algobase.h:219:5: error: expected ‘)’ before ‘const’
        /usr/include/c++/6/bits/stl_algobase.h:219:5: error: expected initializer before ‘const’
        /usr/include/c++/6/bits/stl_algobase.h:243:5: error: ‘std::min’ declared as an ‘inline’ variable
        /usr/include/c++/6/bits/stl_algobase.h:246:7: error: expected primary-expression before ‘if’
        if (__comp(__b, __a))
        /usr/include/c++/6/bits/stl_algobase.h:246:7: error: expected ‘}’ before ‘if’
        /usr/include/c++/6/bits/stl_algobase.h:246:7: error: expected ‘;’ before ‘if’
        /usr/include/c++/6/bits/stl_algobase.h:248:7: error: expected unqualified-id before ‘return’
        return __a;
        /usr/include/c++/6/bits/stl_algobase.h:265:5: error: ‘max’ declared as an ‘inline’ variable
        /usr/include/c++/6/bits/stl_algobase.h:268:7: error: expected primary-expression before ‘if’
        if (__comp(__a, __b))
        /usr/include/c++/6/bits/stl_algobase.h:268:7: error: expected ‘}’ before ‘if’
        /usr/include/c++/6/bits/stl_algobase.h:268:7: error: expected ‘;’ before ‘if’
        /usr/include/c++/6/bits/stl_algobase.h:270:7: error: expected unqualified-id before ‘return’
        return __a;
        /usr/include/c++/6/bits/stl_algobase.h:271:5: error: expected declaration before ‘}’ token
        Makefile:61: recipe for target 'PiGatewaySerial.o' failed
        make: *** [PiGatewaySerial.o] Error 1
          return __a;
          return __a;
          @rajeev2301 the raspberry pi code you are trying to use isn't functional anymore. Use the instructions at https://www.mysensors.org/build/raspberry instead.
          Do you remember where you found the instructions you are following? We should try to get them removed if we can, so they don't fool someone else.
            rajeev2301R
            rajeev2301R
            rajeev2301
            @mfalkvidd Thanks a lot ! I followed the exact process at https://www.mysensors.org/build/raspberry.It looks like I have the required environment setup correctly. But when I run the below code , I still don't receive the correct message comming from Arduino ( I am using NRFL01 transceivers) .. Please suggest what am I missing..
            mport RPi.GPIO as GPIO
            from lib_nrf24 import NRF24
            import time
            import spidev
            GPIO.setmode(GPIO.BCM)
            pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
            radio = NRF24(GPIO, spidev.SpiDev())
            radio.begin(0,8)
            radio.setPayloadSize(32)
            radio.setChannel(0x76)
            radio.setDataRate(NRF24.BR_1MBPS)
            radio.setPALevel (NRF24.PA_MAX)
            radio.setAutoAck(True)
            radio.enableDynamicPayloads()
            radio.enableAckPayload()
            radio.openReadingPipe(1 ,pipes[1])
            radio.printDetails()
            radio.startListening()
            radio.GPIO.cleanup()
            while True:
            while not radio.available(0):
               time.sleep(1/100)
            Temp = []
            radio.read(Temp, radio.getDynamicPayloadSize())
            print("Received Temp: {}".format(Temp))
            print("Translating our received Message into Unicode character...")
            string1 = ""
            for n in Temp:
                      if (n >=32 and n <= 126):
                         string1 += chr(n)
            print (" Our received message decodes to : {} ".format(string1))
            ===============output =========
            STATUS = 0x01 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=1
            RX_ADDR_P0-1 � =
            0x001effffff 0xffffffffff
            RX_ADDR_P2-5 � =
            0xff
            0xfe
            0xfe
            0xfe
            TX_ADDR =
            0xffffffffff
            RX_PW_P0-6 � =
            0x00
            0x00
            0x00
            0x00
            0x00
            0x00
            EN_AA =
            0x03
            EN_RXADDR � =
            0x00
            RF_CH =
            0x07
            RF_SETUP � =
            0x00
            CONFIG =
            0x00
            DYNPD/FEATURE � =
            0x00
            0x00
            Data Rate = 1MBPS
            Model = nRF24L01
            CRC Length = Disabled
            PA Power = PA_MIN
            Received: [4]
            Translating the receivedMessage into unicode characters
            Out received message decodes to:
            Received: [5]
            Received: []
            Received: []
            Received: []
            Received: []
              import time
              import spidev
              radio.begin(0,8)
              while True:
                 time.sleep(1/100)
              Temp = []
              string1 = ""
              for n in Temp:
                           string1 += chr(n)
              RX_ADDR_P0-1 � =
              RX_ADDR_P2-5 � =
              0xff
              0xfe
              0xfe
              0xfe
              TX_ADDR =
              0xffffffffff
              RX_PW_P0-6 � =
              0x00
              0x00
              0x00
              0x00
              0x00
              0x00
              EN_AA =
              0x03
              EN_RXADDR � =
              0x00
              RF_CH =
              0x07
              RF_SETUP � =
              0x00
              CONFIG =
              0x00
              DYNPD/FEATURE � =
              0x00
              0x00
              Data Rate = 1MBPS
              Model = nRF24L01
              PA Power = PA_MIN
              Received: [4]
              Received: [5]
              Received: []
              Received: []
              Received: []
              Received: []
              @rajeev2301 that looks like python code. To my knowledge, MySensors does not have any pyhon code. I'm completely lost. Sorry.
                rajeev2301R
                rajeev2301R
                rajeev2301
                @mfalkvidd
                1. What is your recommendation for doing general programming on raspeberry Pi?
                2. if not python , what code/programming language do you recommend to setup a serial gateway on raspberry pi so that I can receive messages from multiple arduino,s.
                  @mfalkvidd
                  @rajeev2301 I would suggest no programming at all. Just create a raspberry pi gateway and connect a controller to it.
                  If you want to program yourself, use the serial api and connect to the gateway using a tcp, mqtt or serial port connection.
                    rajeev2301R
                    rajeev2301R
                    rajeev2301
                    @mfalkvidd
                    Thanks , I really appreciate your time for helping me out on this. I have recently started diggging into IOT world so I may be asking a trivial question. ( my apology and Thanks in advance
                    I have a following scenario:
                    I am trying to pull the temperature and humidity data from Arduino Nano and then transmitting it through NRF24L01 transreceivers. It works perfectly fine between arduino to Arduino Communication. However I am stuck when I am trying to receive the same information into my Raspeberry Pi3.
                    I believe , I have successfully setup a gateway by following step by step instruction (https://www.mysensors.org/build/raspberry) but now I want to receive the message relaying through my Arduino Nano for which I need to write a code in Raspberry Pi. That’s the reason I am writing a simple python code to receive that message. Please suggest if there are alternate way to receive the message from my arduino’s.
                    Thanks again for your kind guidance.
                      @mfalkvidd
                      @rajeev2301 thanks for explaining your use case.
                      You can compile the MySensors raspbery pi gateway as an ethernet gateway, and let your python program connect to the raspberry pi gateway using tcp. The python program would not be concerned with nrf at all. MySensors will present sensor information the same way regardless which transport (nrf, rfm or rs485) used by the sensors.
                      The information presented by the gateway will follow the specification of the serial protocol that I linked earlier.
                        rajeev2301R
                        rajeev2301R
                        rajeev2301
                        @mfalkvidd
                        Thanks , really appreciate your quick response. Yes , I am aware of TCP but isn’t that it needs an Internet for communication.My plan is to exchange data between sensors wirelessly using radio frequency ( e.g, NRF24L01) so that I don’t have dependency on TCP/Internet. Also, my plan is to create a master-slave kind of setup. Where all sensor’s data really into central raspberry pi environment and then I can play around with dataset from multiple sources.
                        Your guidance would be highly appreciated.
                          If I were you I'd start looking at controllers like Domoticz, MyController, Home Assistant, Node-red etc etc, as there is already documentation on how to connect to a MySensors gateway and the rest
                            @mfalkvidd
                            @rajeev2301 it sounds like you want to do pretty much what MySensor does, but you want to program every detail yourself? If that's the case, MySensors might not be the right forum/library. Most people use MySensors because they don't want to program all the details themselves. We just want a communication network, and that's what MySensors provides.
                              rajeev2301R
                              rajeev2301R
                              rajeev2301
                              @mfalkvidd
                              Thanks for your valuable input. I think I got some direction to move on.
