  3. How to get battery volt / percentage message send to mqtt?
15 Posts 3 Posters 3.2k Views 3 Watching
    it looks as the analogread keeps returning zero
      Mr_sensor
      @gohan Tried to find out what causing that but can not figure it out. I'm bot a real coderer so its trial and error :) and trying to understand form other sketches / posts. Any idea where to look for?
        try adding a delay(500) before the analogread
          Mr_sensor
          @gohan said in How to get battery volt / percentage message send to mqtt?:
          delay(500)
          Hi, tried that (already tried it with wait). Now I added it here:
          delay(500);
          Also tried it here:
                  // Power up radio after sleep
                  delay(500);
                  oldBatteryPcnt = batteryPcnt;
            sleep(SLEEP_TIME); //sleep a bit  ```
          Both did not help still ending up with 0 .
          So what should be the best place the right place to put the delay?
            the second one is useless. It is odd that it misses the analog reads. What AVR boards version are you using?
              Mr_sensor
              @gohan I'm using the EasyPCB board with an arduino pro mini 3,3v
                I mean in Arduino IDE library manager
                  Mr_sensor
                  @gohan
                  Arduino Pro or Pro Mini
                  Programmer AVR ISP
                  ATmega328P (3,3v 8mhz)
                  • M Mr_sensor
                    @gohan
                    Programmer AVR ISP
                    Mr_sensor
                    Still not getting it working! Any thoughts on this?
                      Try a simple example sketch that reads the analog pin just to make sure the hardware is OK, or try another pro mini
                        Mr_sensor
                        @gohan Ok will try that see if I made a fault somewhere
                        12.5k
