  3. [SOLVED] Newbie trying to get RFM69HCW working with ATMEGA328P
6 Posts 3 Posters 2.5k Views 4 Watching
  • G
    G
    Gaz83
    Hi, first post here. I followed the tutorial to get RFM69HCW working on a raspberry pi and have set one up as a gateway.
    I am now trying to get the RFM69HCW working with an ATMEGA328P
    I have checked the wiring and I have D0 going to PIN 2 of the ATMEGA328P
    In MySensors sketch, do I need to change anything?
    I have changed the following
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    #define MY_RADIO_RFM69
    //#define MY_RADIO_RFM95
    and I also added this
    #define MY_IS_RFM69HW
    • G Gaz83
      Welcome to the MySensors community @gaz83!
      That looks good (except that I think you wrote "not" instead of "now)".
      G 1 Reply Last reply
        G
        G
        Gaz83
        • JohnRobJ
          JohnRobJ
          JohnRob
          I have an RFM69HW running on a 328P. My code may help.
          You didn't specify your clock rate but if it is a std board running at 3.3V it is probably 8Mhz.
          The default DEBUG baud rate is 115k maybe a little too fast for the 8Mhz.
          I lowered mine to 9600 because I can't read that fast anyway :)
          #define MY_BAUD_RATE (9600ul)
          // === Hardware / MySensors Initialization ================
          #define MY_RFM69_FREQUENCY RFM69_915MHZ
          // === Node Initialization ================================
          #define CHILD_ID 5
          #define sensortype S_MULTIMETER
          #define LEDPIN 9 //PB1 is pin 9 on ProMini
          #define LED_TST A0
          #define NODE_TXT "Counting_test_Node"
          uint8_t MyCount;
          uint8_t ACK_Result;
          uint8_t NACK_Count;
          • G
            G
            Gaz83
            wrote on last edited by Gaz83
            Had a look at your code and the only thing I spotted was in the frequency you had RFM69_915MHZ where as I was using RF69_433MHZ... I missed the M.
            Tried again and still issues. Here is my monitor output, I am using the PassiveNode example sketch.
             __  __       ____
                    |___/                      2.2.0
            16 MCO:BGN:INIT NODE,CP=RRNPA---,VER=2.2.0
            25 TSM:INIT
            26 TSF:WUR:MS=0
            78 !TSM:INIT:TSP FAIL
            79 TSM:FAIL:CNT=1
            81 TSM:FAIL:DIS
            82 TSF:TDI:TSL
            The tutorial doesn't mention anything about wiring the RS but I know on the adafruit version of RFM69HCW, you do need RS wired.
            • G
              G
              Gaz83
              Solved the issue, I was using a custom PCB I had fabricated and the MOSI connection was not soldered properly.
