  3. [security] Migrating from library version 2.1 to 2.2
48 Posts 7 Posters 15.7k Views 9 Watching
  • AnticimexA Anticimex
    @alowhum right, but if you update your sketches OTA, he can potentially sniff your key OTA as well and then he does not need to enter your house ;)
    alexsh1A
    alexsh1A
    alexsh1
    @anticimex I have a question - I have two GWs: one with ATSHA204A and one soft signing.
    I have noticed that when doing #define PERSONALIZE_ATSHA204A, AES key is saved to ATSHA204A and EEPROM. Is this correct? In what case I need a combination of HMAC + AES keys? I do not do whitelisting
    AnticimexA 1 Reply Last reply
    • alexsh1A alexsh1
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 AES key is never saved to atsha204. It is for encryption and always stored in eeprom.
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @anticimex Now I got more confused. What keys do I need for atsha204a signing?
        • alexsh1A alexsh1
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 it is pretty clearly documented. HMAC key is used for signing.
            alexsh1A
            alexsh1A
            alexsh1
            #43
            @anticimex Sorry, I think I need to re-read documentation. HMAC is for atsha204a signing and AES for encryption, right?
            I am in the process of re-personalising now :)
            • alexsh1A alexsh1
              AnticimexA
              AnticimexA
              Anticimex
              @alexsh1 correct
                @alexsh1 correct
                alexsh1A
                alexsh1A
                alexsh1
                @anticimex thank you! I set-up singing some time ago and it was working fine, but now I need to revise all that again.
                • alexsh1A alexsh1
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alexsh1 it is worth mentioning that if you personalize using 2.2.0, you are free to go back to earlier versions without re doing personalization. It is only when going from 2.1 to 2.2 it has to be redone due to the checksum. Of course, be aware that overwriting the checksum will cause signing to fail again.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @anticimex said in [security] Migrating from library version 2.1 to 2.2:
                    @alexsh1 Of course, be aware that overwriting the checksum will cause signing to fail again.
                    And what has to be done in this case? Re-personalising both GW and a node?
                    • alexsh1A alexsh1
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alexsh1 re-personalize the node that lost the checksum. Each node (including gw) has a unique personalization and checksum (possibly). Just because one node looses the checksum or gets a mismatch does not mean any other node has the same problem. Everything is stored in eeprom locally.
