  3. [security] Migrating from library version 2.1 to 2.2
48 Posts 7 Posters 15.8k Views 9 Watching
  • B
    B
    bilbolodz
    I've a lot devices with very hard physical access to them. I'm using OTA to change firmware so please describe how to implement "new 2.2 checksum feature" into existing sketch using OTA.
    AnticimexA 1 Reply Last reply
    • B bilbolodz
      AnticimexA
      AnticimexA
      Anticimex
      @bilbolodz Not sure what you mean. Then you have to send personalization sketch OTA and that is really not recommended unless you can do that in a secure way. And the personalizer is not designed to use any radios so you cannot expect to be able to FOTA over a new sketch after personalization. You will have to "bring in" your devices if you want to redo personalization.
      • B
        B
        bilbolodz
        So it means that (If I want use signing) I'm stuck with mysensors version 2.1?
        I'm not able compile new code (using 2.2) and upload it over OTA because I will loose signing right (without changeing EEPROM content)?
        I think there should be a way to migrate sketch (which is using soft signing) from 2.1 to 2.2 with OTA. Secure sending of keys actually is NOT a problem because (as I understood) new in 2.2 is "only checksum" of EEPROM.
        So if I have "2.1 mysensors library" personalized devices, it's possible to write a program which gets existing data from EEPROM calculate checksum and write it to EEPROM (maybe also migrating other structures if there were other changes). Such sketch can be in safe way transferred via OTA because it doesn't contain any secret information. Then I can upload new (using 2.2 library) version of my sketch and I will have working "2.2" devices without touching it (only OTA). What do you think about it?
        Actually now I've realised (luckily) that in these "hard to get devices" I'm using hardware signing so it should be not a problem (?) :-)
        AnticimexA gohanG 2 Replies Last reply
        • B bilbolodz
          AnticimexA
          AnticimexA
          Anticimex
          @bilbolodz Correct, checksum is on EEPROM data, so you can make a sketch to read it and calculate the checksum yourself. It is all open source so you can just see in the personalizer how it is calculated and replicate that :)
          B 1 Reply Last reply
          • AnticimexA Anticimex
            B
            B
            bilbolodz
            @anticimex OK maybe I will try but I think it could be a good idea to extend you "migration guide".
            • B bilbolodz
              AnticimexA
              AnticimexA
              Anticimex
              @bilbolodz I disapprove manipulating security related data without the personalizer, so no. You can do it, but I do not endorse it.
              • B
                B
                bilbolodz
                "Your code your rules" but I'm little surprised with your standpoint.
                • B bilbolodz
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @bilbolodz That is fine. But as I have currently no means of verifying, I will not make a update to the guide. If you find a way to do it, you are free to post a guide if other need to make a similar thing.
                  • B bilbolodz
                    @bilbolodz you can still enable signing on gateway and make it optional, so you will have time to update nodes later on.
                      @alowhum right, but if you update your sketches OTA, he can potentially sniff your key OTA as well and then he does not need to enter your house ;)
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @anticimex I have a question - I have two GWs: one with ATSHA204A and one soft signing.
                      I have noticed that when doing #define PERSONALIZE_ATSHA204A, AES key is saved to ATSHA204A and EEPROM. Is this correct? In what case I need a combination of HMAC + AES keys? I do not do whitelisting
                      • alexsh1A alexsh1
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @alexsh1 AES key is never saved to atsha204. It is for encryption and always stored in eeprom.
                        alexsh1A 1 Reply Last reply
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @anticimex Now I got more confused. What keys do I need for atsha204a signing?
                          • alexsh1A alexsh1
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @alexsh1 it is pretty clearly documented. HMAC key is used for signing.
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #43
                              @anticimex Sorry, I think I need to re-read documentation. HMAC is for atsha204a signing and AES for encryption, right?
                              I am in the process of re-personalising now :)
                              • alexsh1A alexsh1
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @alexsh1 correct
                                  @alexsh1 correct
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @anticimex thank you! I set-up singing some time ago and it was working fine, but now I need to revise all that again.
                                  • alexsh1A alexsh1
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @alexsh1 it is worth mentioning that if you personalize using 2.2.0, you are free to go back to earlier versions without re doing personalization. It is only when going from 2.1 to 2.2 it has to be redone due to the checksum. Of course, be aware that overwriting the checksum will cause signing to fail again.
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @anticimex said in [security] Migrating from library version 2.1 to 2.2:
                                      @alexsh1 Of course, be aware that overwriting the checksum will cause signing to fail again.
                                      And what has to be done in this case? Re-personalising both GW and a node?
                                      • alexsh1A alexsh1
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @alexsh1 re-personalize the node that lost the checksum. Each node (including gw) has a unique personalization and checksum (possibly). Just because one node looses the checksum or gets a mismatch does not mean any other node has the same problem. Everything is stored in eeprom locally.
