  3. relay statue doesn't change
22 Posts 3 Posters 4.4k Views 3 Watching
  • L ludoarchi
    arduini 1.6.5 + Mysensors libraries 1.5.4
    and relay actuator code come from mysensors 1.5.4 exemple
    @ludoarchi Is there a reason why you don't update arduino to 1.8.5 and mysensors to 2.2?
    L 1 Reply Last reply
      L
      L
      ludoarchi
      @gohan because i remenber that it used to work in that old version. But i have test yesterday with mysensors 2.2.0 et code V2 and it s ths same problem ... an idea ?
      • Boots33B Boots33
        1.5.4 is a few versions back now so it will help if you post the code you are using, even if it is the standard version. That will give us a starting point to work from.
        Also what controller are you using.
        L
        L
        ludoarchi
        wrote on last edited by gohan
        @boots33 that s the code V1
        // Example sketch showing how to control physical relays.
        // This example will remember relay state even after power failure.
          gw.sendSketchInfo("Relay", "1.0");
          // Fetch relay status
            gw.present(sensor, S_LIGHT);
            pinMode(pin, OUTPUT);
            digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
          if (message.type==V_LIGHT) {
             // Change relay state
             // Store state in eeprom
        • Boots33B Boots33
          L
          L
          ludoarchi
          @boots33 that s the code V2
           * Version 1.0 - Henrik Ekblad
           * Example sketch showing how to control physical relays.
           * This example will remember relay state after power failure.
           * http://www.mysensors.org/build/relay
          #define MY_REPEATER_FEATURE
          void before()
          		present(sensor, S_BINARY);
          	if (message.type==V_STATUS) {
          • Boots33B Boots33
            L
            L
            ludoarchi
            @boots33 i m using mysensor 2.2 with jeedom last version on rpi3 (serial gateway and node with 4.7uf condo).
            i also used my old rpi2 with Mysensors 1.5.4 for test
              are you checking the right relay pin? Pls post a v2 node log
                L
                L
                ludoarchi
                @gohan 16 MCO:BGN:INIT REPEATER,CP=RNNRA---,VER=2.2.0
                26 MCO:BGN:BFR
                27 TSM:INIT
                28 TSF:WUR:MS=0
                35 TSM:INIT:TSP OK
                37 TSF:SID:OK,ID=136
                39 TSM:FPAR
                75 TSF:MSG:SEND,136-136-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2083 !TSM:FPAR:NO REPLY
                2085 TSM:FPAR
                2121 TSF:MSG:SEND,136-136-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2568 TSF:MSG:READ,0-0-136,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                2573 TSF:MSG:FPAR OK,ID=0,D=1
                2842 TSF:MSG:READ,5-5-136,s=255,c=3,t=8,pt=1,l=1,sg=0:2
                2851 TSF:MSG:READ,45-45-136,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                4129 TSM:FPAR:OK
                4130 TSM:ID
                4131 TSM:ID:OK
                4133 TSM:UPL
                4136 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                4148 TSF:MSG:READ,0-0-136,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                4153 TSF:MSG:PONG RECV,HP=1
                4156 TSM:UPL:OK
                4157 TSM:READY:ID=136,PAR=0,DIS=1
                4162 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                4169 TSF:MSG:READ,0-0-136,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                4179 TSF:MSG:SEND,136-136-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
                4195 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                4220 TSF:MSG:READ,0-0-136,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                4228 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
                4236 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                4244 TSF:MSG:SEND,136-136-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                4251 MCO:REG:REQ
                4254 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                4261 TSF:MSG:READ,0-0-136,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                4267 MCO:PIM:NODE REG=1
                4269 MCO:BGN:STP
                4271 MCO:BGN:INIT OK,TSP=1
                22720 TSF:MSG:READ,0-0-136,s=1,c=1,t=2,pt=0,l=1,sg=0:0
                22724 TSF:MSG:ACK REQ
                22737 TSF:MSG:SEND,136-136-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                Incoming change for sensor:1, New status: 0
                31295 TSF:MSG:READ,0-0-136,s=1,c=1,t=2,pt=0,l=1,sg=0:0
                31299 TSF:MSG:ACK REQ
                31337 !TSF:MSG:SEND,136-136-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
                  The last you got was a NACK btw. Have you tried a different controller like domoticz or MyController? Also remember to check your logs on https://www.mysensors.org/build/parser if you meed help decoding it
                    L
                    L
                    ludoarchi
                    @gohan i think the nack came when i unplleged the node but i will try again.
                    there is no nack in the V1log
                    i would like to try myscontroler but i m not able to start with it ... i ve configured the COM but nothing happened ... i don't find How To for it 😕
                    i also try Double State Relay code V2 and it s the same think ... no statue change
                      I am talking about MyController, not MySController
                        L
                        L
                        ludoarchi
                        @gohan oups ! sorry no i don't have try another controller yet
                          try it, it is quite simple to run
