  3. The new ESP8266 WIFI models
20 Posts 12 Posters 22.4k Views 3 Watching
  • YveauxY
    Please be aware that official documentation of these modules is very limited and there (currently) is no Arduino support for it.
    There is however an active community (http://www.esp8266.com/) trying to figure out how these chips work.
    • Z
      Z
      Zeph
      Odd little unit. Much higher OTA speed than the nRF24, but throttled through a slower serial interface. Uses a much wider spectrum, but hopefully for a short time. Seems like overkill for our short packets. I wonder what the datagram collision rate would be for UDP? There are a lot of WiFi networks in range where I live.
      Still, it's an amazingly cheap chip, considering how much more sophisticated it is than the nRF24L01+ (or even a nRF51822).
      • RJ_MakeR
        RJ_MakeR
        RJ_Make
        Anyone had a chance to mess around with this module?
        RJ_Make
        • RJ_MakeR RJ_Make
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @ServiceXp
          Just received a few, and will start messing with them while on holidays... I've seen progress on a few threads out there.
          • EasyIoTE
            EasyIoTE
            EasyIoT
            wrote on last edited by EasyIoT
            @ServiceXp, I've created ESP8266 library similar to MySensor library. I'm using V0.9.2.2 firmware. Because in firmware are some typos library will probably work only with this firmware. I've implemented couple of sensors with this module. Distance range of ESP8266 module is much better than NRF24l01, but also power consumtion is much bigger.
            Sources are on GitHub.
            EasyIoT framework http://iot-playground.com
            RJ_MakeR 1 Reply Last reply
            • EasyIoTE EasyIoT
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @dopustko How much more is the power consumption?
              RJ_Make
              EasyIoTE 1 Reply Last reply
              • RJ_MakeR RJ_Make
                EasyIoTE
                EasyIoTE
                EasyIoT
                @ServiceXp in spec is 215mA, which is more than 10x as NRF24L01 current consumption. I didn't measure current, but my configuration did't work with FDT power supply. I'm using additional AMS1117 regulator to power ESP8266 and Arduino.
                But ESP8266 can be put in sleep mode, and current consumption is much lower. I plan to add sleep support in ESP8266 EasyIoT library.
                • L
                  L
                  lunarok
                  Someone has get any success making a gateway with an ESP8266 ?
                  • greglG
                    greglG
                    gregl
                    I got a few ESP-03 modules the other week and last night got the MQTT client running on one of them.
                    Was able to turn on/off a led and detect state change of another I/O pin.
                    Really impressive little modules!
                    • greglG gregl
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @gregl
                      I have messed about with them too, but it seems for me they are not-ready-for-primetime, but with some hard-knocking effort you can get it to do some basic things. Smart guys will develop a great library and it will all come together, I am sure.
                      Spark Core is my new favorite. After sitting on the bench from last year's initial shipment, I finally got to play with it. It is amazing with its tremendous out of the box capabilities.
                      The Photon (which ships april) is only US$19, has 1 Mb of FLASH and 128 Kb of RAM, moving at 120Mhz... wow! Way overkill for a motion sensor, but it brings a lot of life to the world of Home Automation for a small price. ($10 for a surface mount version!!!)
                      I'm in the process of moving my Vera auxiliary controller project over to spark... I'll re-post the wireless version as soon as I can get it in a proper box.
