  3. USB-C PD PSU
USB-C PD PSU
10 Posts 3 Posters 3.5k Views 3 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    I have a USB-C PD 26850mAh power bank, which I used to charge my gadgets. I wanted to use the same power bank to charge my Microsoft laptop, which does not have USB-C PD port . USB-C PD can vary voltage / amperage from 5-20V upto 3A. And laptop must be supplied with 15V. How do I connect the two? Well, that’s the answer
    This is a USB-C PD Buddy Sink - a little board with a chip which negotiates a precise voltage / amperage one sets-up. Absolutely brilliant!
    Now I can use it to extract any voltage in the region 5-20V for any project.
    In theory can by mysensorised but I do not see any point in controlling it remotely
      I think I am a bit confused...
      alexsh1A 1 Reply Last reply
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @gohan said in USB-C PD PSU:
        About what?
          What your are trying to do and what this device does...
            alexsh1A Offline
            alexsh1A Offline
            alexsh1
            @gohan ok, do you have a phone / laptop charger USB-C PD (Power Deivery)? This is not a typical USB interface. With one PSU, one can charge a phone or a laptop. No need to have several chargers.
            My issue is this. I have a laptop, which does not have USB-C interface. I also have a power bank powerful enough to provide 30W USB-C PD charging. I do use it for my mobile phone as well as iPad. Unfortunately, I could not charge my laptop (remember, no USB-C port?) until now. I have got the board (in the photo above). It takes power from USB-C PD and you can select any voltage from 5-20V on the output. I programmed 15V (this is my laptop voltage) and used this cable to charge the laptop.
            https://www.amazon.co.uk/dp/B01DT9X1LI/ref=cm_sw_r_sms_c_api_i_rBP.AbP80WV49
            The same board can be used with USB-C PD charger for any project requiring higher than 5V voltage. You can program any voltage in the region 5-20V.
            Some time ago I needed 13V power supply and ended up using 24V one and lowering voltage to 13V.
              Basically you are turning the powerbank into one of those with variable DC output
                alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @gohan Basically yes. I just wanted to have one power bank for everything including my laptop. Obviously, there are plenty other ways this board can be used/setup. If I ever need a strange voltage source (say, 13V) for a project / breadboard and I do not have other sources, this is the way to go.
                PS Many modern laptops with a minor exception have USB-C PD. Even Apple introduced USB-C with power delivery for laptops.
                This is a great technology allowing just one PSU to be used for everything.
                • alexsh1A Offline
                  alexsh1A Offline
                  alexsh1
                  See this comparison USB-C PD and a normal USB power banks - https://www.anker.com/deals/usb-c?country=us
                  • alexsh1A alexsh1
                    @alexsh1 do you have a buy link for the buddy sink? Sounds like it could be very handy.
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      @mfalkvidd
                      Yes, you can buy it here
                      https://www.tindie.com/products/clayghobbs/pd-buddy-sink/
                      Or order the PCB and do it yourself here
                      https://oshpark.com/shared_projects/B7h1WKOi
                      This does require very fine SMD soldering!
