  3. OpenHAB
  4. Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable)
60 Posts 19 Posters 24.2k Views 23 Watching
  • A
    andre_m87
    Hey,
    same Problem here. After upgrading to OpenHAB 2.3 i receive the same errors in my /var/log/openhab2/openhab.log
    2018-05-31 16:28:42.776 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
    2018-05-31 16:28:42.918 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    • A andre_m87
      Hey,
      TimO
      @andre_m87 & @MasMat : I have the same problem here. Looks like a change in the OpenHAB MQTT implementation.
      I'm working on it.
      • T
        TimO
        @andre_m87 & @MasMat : I found a solution and indeed the MQTT implementation in OH2 (ESH) changed. This was a hard nut to crack, so it took me a while.
        Here are the steps you need to do:
        1. Rename: org.eclipse.smarthome.mqtt.cfg to org.eclipse.smarthome.mqttbroker.cfg
        2. Change the content to:
        name=mosquitto
        host=192.168.2.3
        secure=false
        port=1883
        username=USERNAME
        password=PASSWORD
        retain=false
        If you're using a secure connection (SSL): change secure to true and use the correct port.
        Another intersting feature in OpenHAB 2.3 is the embedded broker, so there is no need to have a separate MQTT server up and running.
        jogantJ 1 Reply Last reply
        • T TimO
          name=mosquitto
          host=192.168.2.3
          secure=false
          port=1883
          username=USERNAME
          password=PASSWORD
          retain=false
          jogantJ
          jogantJ
          jogant
          wrote on last edited by jogant
          @timo unfortunately this solution doesn't work for me.
          After update oh to version 2.3 I don't get mqtt to work. Prior I used mqtt for mysensors and for eventbus. I configured two broker connections and set up a mysensors-mqtt-bridge via things-file. In the broker all events from openhab arrived and all mysensors-messages arrived in openhab.
          After update mysensors doesn't work at all, allthough I followed your instructions. If I setup mqtt1 binding I can see eventbus messages in mqtt broker but my mysensors-mqtt-gateway remains initializing.
          What I'm doing wrong?
          • jogantJ jogant
            TimO
            @jogant Yeah. :-( There are still some problems with 2.3 to fix. The binding works fine within the development IDE, but only there. I'm still looking into it.
            • MasMatM
              MasMatM
              MasMat
              Did that, MQTT bridge stuck at "initializing". Not the full answer yet, but thanks @timo for your effort!
              Openhab.log when I checked the Services - MQTT in Paper UI
              2018-06-08 00:59:19.162 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
              2018-06-08 00:59:19.221 [WARN ] [me.config.core.internal.ConfigMapper] - Could not set field value for field 'port': For input string: "1883.0"
              java.lang.NumberFormatException: For input string: "1883.0"
              	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
              	at java.lang.Integer.parseInt(Integer.java:580) [?:?]
              	at java.lang.Integer.valueOf(Integer.java:766) [?:?]
              	at org.eclipse.smarthome.config.core.internal.ConfigMapper.objectConvert(ConfigMapper.java:159) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
              	at org.eclipse.smarthome.config.core.internal.ConfigMapper.as(ConfigMapper.java:98) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
              	at org.eclipse.smarthome.config.core.Configuration.as(Configuration.java:54) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
              	at org.eclipse.smarthome.io.transport.mqtt.internal.MqttBrokerConnectionServiceInstance.modified(MqttBrokerConnectionServiceInstance.java:77) [207:org.eclipse.smarthome.io.transport.mqtt:0.10.0.oh230]
              	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
              	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
              	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
              	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
              	at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeModifiedMethod(SingleComponentManager.java:772) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.manager.SingleComponentManager.modify(SingleComponentManager.java:727) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:645) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:609) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:426) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:284) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$1.configurationEvent(RegionConfigurationSupport.java:89) [41:org.apache.felix.scr:2.0.12]
              	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:2090) [8:org.apache.felix.configadmin:1.8.16]
              	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:2058) [8:org.apache.felix.configadmin:1.8.16]
              	at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [8:org.apache.felix.configadmin:1.8.16]
              	at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [8:org.apache.felix.configadmin:1.8.16]
              	at java.lang.Thread.run(Thread.java:748) [?:?]
              2018-06-08 00:59:19.340 [WARN ] [.MqttBrokerConnectionServiceInstance] - Ignore existing broker connection configuration for: mosquitto```
              • MasMatM MasMat
                TimO
                wrote on last edited by TimO
                @masmat please check your MQTT configuration. You're receiving an exception because it's trying to set "1883.0" for the value port.
                MasMatM 1 Reply Last reply
                • T TimO
                  MasMatM
                  MasMatM
                  MasMat
                  @timo I did. I can't figure out where it's finding that .0 it adds to the 1883 port I have in the cfg-file
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    How close is this for 2.3? Worth a try? or should I hold? Thanks for the work so far on it!
                    Home Automation Tinkerer
                    www.CrankyCoder.net
                    Gateway: MQTTClientGateway
                    MySensors: 2.3
                    • CrankyCoderC CrankyCoder
                      jogantJ
                      jogantJ
                      jogant
                      @crankycoder Unfortunately there are still issues with the mqtt implementation. I reverted back to 2.2 yesterday as all my fiddling didn't help.
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        my setup is still just using the direct mqtt subscription so i will hold off.
                        is there any discovery working (in 2.2 that is) how about once you configure the things. do you get all the properties of that item from when it presents?
                        www.CrankyCoder.net
                        MySensors: 2.3
                          jogantJ
                          jogantJ
                          jogant
                          @crankycoder in 2.2 with appropriate binding mysensors is working pretty well. All variables are presented with mysensors lib 2.2.
                          I only updated openhab to 2.3 as this release was presented on my debian system. But I didn't get 2.3 working with mysensors mqtt.
                          • CrankyCoderC
                            CrankyCoderC
                            CrankyCoder
                            I did an upgrade the other week from 1.8 to 2.2. Then right about the time I had some stuff working 2.3 came out. So I figured since I have to do all the learning curve anyways I might as well stick with 2.3. The variables being presented in mysensors would be HUGE for me. But hopefully it's not too far out.
                            www.CrankyCoder.net
                            MySensors: 2.3
                            • jogantJ
                              jogantJ
                              jogant
                              @TimO : are there any news concerning compatibility to version 2.3?
                              Thanks for your work!
                              • jogantJ jogant
                                TimO
                                @jogant There already is a working version (2.4 SNAPSHOT) available on the marketplace and on my server. Please let me know if you expierence any problems.
                                • T TimO
                                  jogantJ
                                  jogantJ
                                  jogant
                                  @timo unfortunately this also does not work for me. I followed your manual very well but I always get errors. It starts after installing feature:install esh-io-transport-mqtt and mysensors binding:
                                  16:59:57.772 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
                                  16:59:57.806 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.96.8' with clientid paho1135997459230242 and file store '/var/lib/openhab2/mqtt/192.168.96.8'
                                  16:59:57.867 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                                  org.eclipse.paho.client.mqttv3.MqttException: MqttException
                                          at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38) [229:org.eclipse.paho.client.mqttv3:1.0.2]
                                          at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:604) [229:org.eclipse.paho.client.mqttv3:1.0.2]
                                  Caused by: java.net.SocketException: Connection reset
                                          at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
                                          at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
                                          at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
                                          at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
                                          at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
                                          at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
                                          at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
                                          at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
                                          at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:89) ~[?:?]
                                          at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:590) ~[?:?]
                                          ... 1 more
                                  and reconection starts every 10 seconds.
                                  It must be interference with mqtt1 bindung that I use for eventbus.
                                  The mqtt-bridge remains Offline.
                                  What is wrong?
                                  • jogantJ jogant
                                            ... 1 more
                                    What is wrong?
                                    TimO
                                    @jogant Indeed this looks like an error in your configuration. I suspect the MQTT configuration. Did you change the MQTT configuration according my posting above? I've also added a text to the Wiki. The name and content of the MQTT configuration differs between OpenHAB 2.2 and 2.3.
                                    jogantJ 2 Replies Last reply
                                    • T TimO
                                      jogantJ
                                      jogantJ
                                      jogant
                                      @timo with 2.2 I had two configurations which were very similar.
                                      I have one mosquitto mqtt broker on localhost, version 1.5.
                                      The mqtt1 binding is for my mqtt-eventbus connection is called mosquitto and the config file (mqtt.cfg) is as follows:
                                      mosquitto.url=tcp://192.168.96.8:1883
                                      mosquitto.retain=false
                                      mosquitto.clientId=openhab
                                      mosquitto.user=user
                                      mosquitto.pwd=pwd
                                      With OH2.2 this configuration works. It also works with 2.3 as I can see all openhab events on my mosquitto.
                                      My mysonsors binding is configured by org.eclipse.smarthome.mqttbroker.cfg config file which looks as follows:
                                      name=mosquittomys
                                      host=192.168.96.8
                                      port=1883
                                      retain=false
                                      username=username
                                      password=password
                                      clientId=openhabMys
                                      I also tried without authentication and also without clientId, all to no succuess.
                                      I cleaned /var/lib/openhab2/cache/ folder and /var/lib/openhab2/tmp/ folder.
                                      I looked at /var/lib/openhab2/config folder for resulting runtime configuration, but all looks fine. Do you have any further idea?
                                      • T TimO
                                        jogantJ
                                        jogantJ
                                        jogant
                                        @timo I found the fault in my configuration: it was the missing secure=false config flag in the org.eclipse.smarthome.mqttbroker.cfg config file. I have no idea what happens when the flag is missing but without it one doesn't achieve a valid connection.
                                        name=mosquittomys
                                        host=192.168.96.8
                                        port=1883
                                        secure=false  <-- important !
                                        So now I have a working 2.3 installation! Thanks alot for your support.
                                        • jogantJ jogant
                                          name=mosquittomys
                                          host=192.168.96.8
                                          port=1883
                                          TimO
                                          @jogant Good catch! I'm glad it's working now! :-)
