  3. OpenHAB
  4. Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable)
60 Posts 19 Posters 24.2k Views 23 Watching
  • jogantJ jogant
    @timo unfortunately this solution doesn't work for me.
    After update oh to version 2.3 I don't get mqtt to work. Prior I used mqtt for mysensors and for eventbus. I configured two broker connections and set up a mysensors-mqtt-bridge via things-file. In the broker all events from openhab arrived and all mysensors-messages arrived in openhab.
    After update mysensors doesn't work at all, allthough I followed your instructions. If I setup mqtt1 binding I can see eventbus messages in mqtt broker but my mysensors-mqtt-gateway remains initializing.
    What I'm doing wrong?
    TimO
    @jogant Yeah. :-( There are still some problems with 2.3 to fix. The binding works fine within the development IDE, but only there. I'm still looking into it.
    • MasMatM
      MasMatM
      MasMat
      Did that, MQTT bridge stuck at "initializing". Not the full answer yet, but thanks @timo for your effort!
      Openhab.log when I checked the Services - MQTT in Paper UI
      2018-06-08 00:59:19.162 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
      2018-06-08 00:59:19.221 [WARN ] [me.config.core.internal.ConfigMapper] - Could not set field value for field 'port': For input string: "1883.0"
      java.lang.NumberFormatException: For input string: "1883.0"
      	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
      	at java.lang.Integer.parseInt(Integer.java:580) [?:?]
      	at java.lang.Integer.valueOf(Integer.java:766) [?:?]
      	at org.eclipse.smarthome.config.core.internal.ConfigMapper.objectConvert(ConfigMapper.java:159) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
      	at org.eclipse.smarthome.config.core.internal.ConfigMapper.as(ConfigMapper.java:98) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
      	at org.eclipse.smarthome.config.core.Configuration.as(Configuration.java:54) [98:org.eclipse.smarthome.config.core:0.10.0.oh230]
      	at org.eclipse.smarthome.io.transport.mqtt.internal.MqttBrokerConnectionServiceInstance.modified(MqttBrokerConnectionServiceInstance.java:77) [207:org.eclipse.smarthome.io.transport.mqtt:0.10.0.oh230]
      	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
      	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
      	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
      	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
      	at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeModifiedMethod(SingleComponentManager.java:772) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.manager.SingleComponentManager.modify(SingleComponentManager.java:727) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:645) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:609) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:426) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:284) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$1.configurationEvent(RegionConfigurationSupport.java:89) [41:org.apache.felix.scr:2.0.12]
      	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:2090) [8:org.apache.felix.configadmin:1.8.16]
      	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:2058) [8:org.apache.felix.configadmin:1.8.16]
      	at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [8:org.apache.felix.configadmin:1.8.16]
      	at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [8:org.apache.felix.configadmin:1.8.16]
      	at java.lang.Thread.run(Thread.java:748) [?:?]
      2018-06-08 00:59:19.340 [WARN ] [.MqttBrokerConnectionServiceInstance] - Ignore existing broker connection configuration for: mosquitto```
      • MasMatM MasMat
        TimO
        wrote on last edited by TimO
        @masmat please check your MQTT configuration. You're receiving an exception because it's trying to set "1883.0" for the value port.
        MasMatM 1 Reply Last reply
        • T TimO
          MasMatM
          MasMatM
          MasMat
          @timo I did. I can't figure out where it's finding that .0 it adds to the 1883 port I have in the cfg-file
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            How close is this for 2.3? Worth a try? or should I hold? Thanks for the work so far on it!
            Home Automation Tinkerer
            www.CrankyCoder.net
            Gateway: MQTTClientGateway
            MySensors: 2.3
            jogantJ 1 Reply Last reply
            • CrankyCoderC CrankyCoder
              jogantJ
              jogantJ
              jogant
              @crankycoder Unfortunately there are still issues with the mqtt implementation. I reverted back to 2.2 yesterday as all my fiddling didn't help.
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                my setup is still just using the direct mqtt subscription so i will hold off.
                is there any discovery working (in 2.2 that is) how about once you configure the things. do you get all the properties of that item from when it presents?
                www.CrankyCoder.net
                MySensors: 2.3
                  jogantJ
                  jogantJ
                  jogant
                  @crankycoder in 2.2 with appropriate binding mysensors is working pretty well. All variables are presented with mysensors lib 2.2.
                  I only updated openhab to 2.3 as this release was presented on my debian system. But I didn't get 2.3 working with mysensors mqtt.
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    I did an upgrade the other week from 1.8 to 2.2. Then right about the time I had some stuff working 2.3 came out. So I figured since I have to do all the learning curve anyways I might as well stick with 2.3. The variables being presented in mysensors would be HUGE for me. But hopefully it's not too far out.
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • jogantJ
                      jogantJ
                      jogant
                      @TimO : are there any news concerning compatibility to version 2.3?
                      Thanks for your work!
                      • jogantJ jogant
                        TimO
                        @jogant There already is a working version (2.4 SNAPSHOT) available on the marketplace and on my server. Please let me know if you expierence any problems.
                        • T TimO
                          jogantJ
                          jogantJ
                          jogant
                          @timo unfortunately this also does not work for me. I followed your manual very well but I always get errors. It starts after installing feature:install esh-io-transport-mqtt and mysensors binding:
                          16:59:57.772 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
                          16:59:57.806 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.96.8' with clientid paho1135997459230242 and file store '/var/lib/openhab2/mqtt/192.168.96.8'
                          16:59:57.867 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                          org.eclipse.paho.client.mqttv3.MqttException: MqttException
                                  at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38) [229:org.eclipse.paho.client.mqttv3:1.0.2]
                                  at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:604) [229:org.eclipse.paho.client.mqttv3:1.0.2]
                          Caused by: java.net.SocketException: Connection reset
                                  at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
                                  at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
                                  at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
                                  at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
                                  at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
                                  at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
                                  at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
                                  at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
                                  at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:89) ~[?:?]
                                  at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:590) ~[?:?]
                                  ... 1 more
                          and reconection starts every 10 seconds.
                          It must be interference with mqtt1 bindung that I use for eventbus.
                          The mqtt-bridge remains Offline.
                          What is wrong?
                          • jogantJ jogant
                                    ... 1 more
                            What is wrong?
                            TimO
                            @jogant Indeed this looks like an error in your configuration. I suspect the MQTT configuration. Did you change the MQTT configuration according my posting above? I've also added a text to the Wiki. The name and content of the MQTT configuration differs between OpenHAB 2.2 and 2.3.
                            jogantJ 2 Replies Last reply
                            • T TimO
                              jogantJ
                              jogantJ
                              jogant
                              @timo with 2.2 I had two configurations which were very similar.
                              I have one mosquitto mqtt broker on localhost, version 1.5.
                              The mqtt1 binding is for my mqtt-eventbus connection is called mosquitto and the config file (mqtt.cfg) is as follows:
                              mosquitto.url=tcp://192.168.96.8:1883
                              mosquitto.retain=false
                              mosquitto.clientId=openhab
                              mosquitto.user=user
                              mosquitto.pwd=pwd
                              With OH2.2 this configuration works. It also works with 2.3 as I can see all openhab events on my mosquitto.
                              My mysonsors binding is configured by org.eclipse.smarthome.mqttbroker.cfg config file which looks as follows:
                              name=mosquittomys
                              host=192.168.96.8
                              port=1883
                              retain=false
                              username=username
                              password=password
                              clientId=openhabMys
                              I also tried without authentication and also without clientId, all to no succuess.
                              I cleaned /var/lib/openhab2/cache/ folder and /var/lib/openhab2/tmp/ folder.
                              I looked at /var/lib/openhab2/config folder for resulting runtime configuration, but all looks fine. Do you have any further idea?
                              • T TimO
                                jogantJ
                                jogantJ
                                jogant
                                @timo I found the fault in my configuration: it was the missing secure=false config flag in the org.eclipse.smarthome.mqttbroker.cfg config file. I have no idea what happens when the flag is missing but without it one doesn't achieve a valid connection.
                                name=mosquittomys
                                host=192.168.96.8
                                port=1883
                                secure=false  <-- important !
                                So now I have a working 2.3 installation! Thanks alot for your support.
                                • jogantJ jogant
                                  name=mosquittomys
                                  host=192.168.96.8
                                  port=1883
                                  TimO
                                  @jogant Good catch! I'm glad it's working now! :-)
                                  • MasMatM
                                    MasMatM
                                    MasMat
                                    I'm still unsuccesful.
                                    Do I need to reinstall all the files as well? I didn't find a new set of instructions.
                                    In my /etc/openhab2/services-folder I have:
                                    mqtt-eventbus.cfg containing just
                                    broker=mosquitto
                                    and org.eclipse.smarthome.mqttbroker.cfg:
                                    name=mosquitto
                                    host=127.0.0.1
                                    secure=false
                                    port=1883
                                    secure=false
                                    username=XXXX
                                    password=YYYYY
                                    retain=false
                                    clientId=openhabMys
                                    openhab.log everything mysensors related:
                                    2018-07-09 06:40:36.782 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid paho175068223000 and file store '/var/lib/openhab2/mqtt/127.0.0.1'
                                    2018-07-09 06:40:37.050 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
                                    2018-07-09 06:40:37.075 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
                                    2018-07-09 06:40:37.206 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=119, service.bundleid=13, service.scope=bundle, component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=17} - org.openhab.binding.mysensors
                                    2018-07-09 06:42:36.466 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): error=2, Tiedostoa tai hakemistoa ei ole)
                                    2018-07-09 06:42:36.685 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
                                    2018-07-09 06:42:37.484 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                                    2018-07-09 06:42:38.136 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                                    2018-07-09 06:42:38.178 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [0, 1, 99, 4, 5]
                                    2018-07-09 06:42:38.608 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
                                    2018-07-09 06:42:38.830 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=281, service.bundleid=13, service.scope=singleton} - org.openhab.binding.mysensors
                                    2018-07-09 06:42:38.897 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                                    2018-07-09 06:42:38.926 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                                    Anyone spot what's still wrong?
                                    P.S. I remember seeing someone got MyS gateway to log to a different file. Does anyone know how to implement that in the ./configure -command? Or how can I do that?
                                    • MasMatM MasMat
                                      broker=mosquitto
                                      name=mosquitto
                                      host=127.0.0.1
                                      secure=false
                                      port=1883
                                      secure=false
                                      username=XXXX
                                      password=YYYYY
                                      retain=false
                                      clientId=openhabMys
                                      jogantJ
                                      jogantJ
                                      jogant
                                      @masmat two things come to my mind: I have two different broker-names for eventbus connection and mysensors connection. For eventbus binding you need classic mqtt1 binding with its own configuration like this:
                                      mosquitto.url=tcp://127.0.0.1:1883
                                      mosquitto.user=user
                                      mosquitto.pwd=pwd
                                      And second: can you show your mysensors bridge configuration? Not shure but debug log looks like an ethernet bridge and not a mqtt bridge.
                                      • MasMatM
                                        MasMatM
                                        MasMat
                                        Not sure how to answer some of your questions...but here goes.
                                        configuration:
                                        sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-signing-password=XXXXXXXX --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=YYYY --my-mqtt-password=ZZZZZ --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                                        I'm not sure what "eventbus"-binding is. Something I need to install in Paper UI?
                                        Is the configuration file mqtt-eventbus.cfg or something else? Should I try to install it? I have not installed the MQTT binding in OpenHab because at least originally the instructions said not to.
                                        • MasMatM MasMat
                                          configuration:
                                          jogantJ
                                          jogantJ
                                          jogant
                                          @masmat I just wanted to understand your configuration. So I read through whole thread and saw your problems began with upgrade to OH2.3.
                                          I mentioned eventbus as you wrote something about eventbus.cfg.
                                          You need eventbus only if you want to send all oh events to mqtt broker.
                                          I wanted to see your mqtt bridge configuration. You can either configure dynamicly via paper ui or you set it up via things file. The later is what I did. So here is my things file with bridge configuration.
                                          Bridge mysensors:bridge-mqtt:gateway [  brokerName="mosquittomys",
        topicPublish="mysensors1/in",
        topicSubscribe="mysensors1/out",
        startupCheckEnabled=true ] {
                                          Here the brokername has to be the same as in mqttbroker.cfg. Fix topic names to match your mysensors gateway.
                                          Hope this is of any help.
