  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.8k Views 5 Watching
  • A Avamander
    @alexsh1
    Did you try a different lib?
    Haven't bothered, I'm just logging the raw values and then compensating with software.
    alexsh1A
    alexsh1A
    alexsh1
    @avamander It definitely works.
    My problem for now was just the battery consumption. I have one of these:
    https://www.aliexpress.com/item/I2C-Interface-3-3V-Board-Based-on-VEML6075-UVA-UVB-Light-Sensor-Module/32832979057.html?spm=2114.search0104.3.1.5f765e65b6nG8K&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10343_10340_10548_10341_10696_10192_10190_10084_10083_10618_10307_10820_10301_10821_10303_10059_100031_10103_524_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_7&algo_expid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3-0&algo_pvid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3&priceBeautifyAB=0
    The problem is that it is dodgy - the sleep consumption never goes below 50uA at 3.2V. According to the datasheet it should be 800nA while sleeping at 1.8V and 25C. Can anyone measure a shutdown current for VEML6085 please?
    A 1 Reply Last reply
    • alexsh1A alexsh1
      Avamander
      @alexsh1 I have the same board, there seems to be a regulator and a few other components on the board, if you remove those, how's the power consumption then?
      alexsh1A 1 Reply Last reply
      • A Avamander
        alexsh1A
        alexsh1A
        alexsh1
        @avamander I have removed every component bit by bit. Originally the consumption was 56uA and now it is 50uA with the only sensor left on the board
        • alexsh1A alexsh1
          Avamander
          wrote on last edited by Avamander
          #42
          @alexsh1 There's an I^2C address selection jumper on the board, maybe that draws current?
          • A Avamander
            alexsh1A
            alexsh1A
            alexsh1
            @avamander desoldered
            • alexsh1A alexsh1
              Avamander
              #44
              @alexsh1 Just desolder the sensor itself from the board if you're that far already? I wouldn't be surprised if aliexpress sellers sell counterfeit chips that are s****ier, I'm already seeing that with nRF24L01+'s
              • A Avamander
                alexsh1A
                alexsh1A
                alexsh1
                @avamander I tried to resolder it to the board - no luck.
                It is very small. Very hard to solder any wires to it
                • alexsh1A
                  alexsh1A
                  alexsh1
                  Ok, I did manage to solder the bare sonsor.
                  Consumption is still 50uA.
                  Can anyone please let me know your VELM6075 break board consumption?????
                  • alexsh1A alexsh1
                    Avamander
                    @alexsh1 I'd do it but I'm waiting for my replacement multimeter to arrive, sorry.
                    • A Avamander
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @avamander That's ok. Just post values here - other may benefit on this as well.
                      I still have no idea why the sensor is taking so much current
                      • T
                        tonbor
                        An old thread, tried the github ino for the VEML6075, is not working ok. UVA and UVB sometimes wrong negative figures. I am going to try the sparkfun library, is from 2018. Let you now if I get beter results.
                        • T tonbor
                          tonbor
                          • T
                            tonbor
                            Original by scalz@mysensors: https://forum.mysensors.org/topic/6952/veml6070-and-veml6075-uv-sensors/25#
                            Needs a modified VEML6075-lib: https://github.com/rejoe2/VEML6075
                            rewritten by Tonbor using sparkfun libary
                            //#define MY_NODE_ID 10
                            #include <SparkFun_VEML6075_Arduino_Library.h>
                            VEML6075 uv;
                            //VEML6075 veml6075 = VEML6075();
                            bool sensorFound = false;
                            #define CHILD_ID_UVI 1
                            #define CHILD_ID_UVA 2
                            #define CHILD_ID_UVB 3
                            uint32_t SLEEP_TIME = 30
                            1000; // Sleep time between reads (in milliseconds)
                            MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                            MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                            MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                            sendSketchInfo("UV Sensor", "1.4T");
                            present(CHILD_ID_UVI, S_UV);
                            present(CHILD_ID_UVA, S_UV);
                            present(CHILD_ID_UVB, S_UV);
                            if (!uv.begin()) {
                            Serial.println(F("VEML6075 not found!"));
                            } else
                            sensorFound = true;
                            //#ifdef MY_DEBUG
                            // uint16_t devid = veml6075.getDevID();
                            // Serial.print(F("Device ID = "));
                            // Serial.println(devid, HEX);
                            // Serial.println(F("----------------"));
                            //#endif
                            if (sensorFound) {
                            unsigned long lastSend =0;
                            float uvi;
                            float uva;
                            float uvb;
                            static float uviOld = -1;
                            static float uvaOld = -1;
                            static float uvbOld = -1;
                            //veml6075.sleep(false); // power up veml6075 == begin()
                            //sleep(500);
                            // Poll sensor
                            //veml6075.poll();
                            uv.powerOn();
                            delay(250);
                            uva = uv.a();
                            uvb = uv.b();
                            uvi = uv.index();
                            #ifdef MY_DEBUG
                            Serial.print(F("UVA = "));
                            Serial.println(uva, 2);
                            Serial.print(F("UVB = "));
                            Serial.println(uvb, 2);
                            Serial.print(F("UV Index = "));
                            Serial.println(uvi, 1);
                            if (uvi != uviOld) {
                            send(uviMsg.set(uvi,2));
                            uviOld = uvi;
                            if (uva != uvaOld) {
                            send(uvaMsg.set(uva,2));
                            uvaOld = uva;
                            if (uvb != uvbOld) {
                            send(uvbMsg.set(uvb,2));
                            uvbOld = uvb;
                            uv.shutdown(); ; // power down veml6075
                            sleep(SLEEP_TIME);
                            • T
                              tonbor
                              wrote on last edited by tonbor
                              #52
                              This ino is working for me, it has the sleep function to save batteries. The Adafruit en the github/mysensors-> https://github.com/schizobovine/VEML6075 lib gives far to high index with my sensor. Only uv a and uv b declaration is not correct. Uv expect a index 0 till 11, domoticz controller passes a lower figure when it receives a number above 11.
