  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.8k Views 5 Watching
  • A Avamander
    Battery issues is one thing, SparkFun's VEML6075 library can't handle direct daylight even (compensated UV readings go negative).
    alexsh1A
    alexsh1A
    alexsh1
    @avamander That's impossible - it is designed to handle the direct sunlight. Mine is showing UV Index = 9. Negative UV reading is a software issue - looks like Sparkfun did not write a good lib for it. Did you try a different lib?
    A 1 Reply Last reply
    • alexsh1A alexsh1
      Avamander
      wrote on last edited by Avamander
      #38
      @alexsh1
      Haven't bothered, I'm just logging the raw values and then compensating with software.
      alexsh1A 1 Reply Last reply
      • A Avamander
        @alexsh1
        alexsh1A
        alexsh1A
        alexsh1
        @avamander It definitely works.
        My problem for now was just the battery consumption. I have one of these:
        https://www.aliexpress.com/item/I2C-Interface-3-3V-Board-Based-on-VEML6075-UVA-UVB-Light-Sensor-Module/32832979057.html?spm=2114.search0104.3.1.5f765e65b6nG8K&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10343_10340_10548_10341_10696_10192_10190_10084_10083_10618_10307_10820_10301_10821_10303_10059_100031_10103_524_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_7&algo_expid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3-0&algo_pvid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3&priceBeautifyAB=0
        The problem is that it is dodgy - the sleep consumption never goes below 50uA at 3.2V. According to the datasheet it should be 800nA while sleeping at 1.8V and 25C. Can anyone measure a shutdown current for VEML6085 please?
        • alexsh1A alexsh1
          Avamander
          @alexsh1 I have the same board, there seems to be a regulator and a few other components on the board, if you remove those, how's the power consumption then?
          • A Avamander
            alexsh1A
            alexsh1A
            alexsh1
            @avamander I have removed every component bit by bit. Originally the consumption was 56uA and now it is 50uA with the only sensor left on the board
            • alexsh1A alexsh1
              Avamander
              #42
              @alexsh1 There's an I^2C address selection jumper on the board, maybe that draws current?
              • A Avamander
                alexsh1A
                alexsh1A
                alexsh1
                @avamander desoldered
                • alexsh1A alexsh1
                  Avamander
                  #44
                  @alexsh1 Just desolder the sensor itself from the board if you're that far already? I wouldn't be surprised if aliexpress sellers sell counterfeit chips that are s****ier, I'm already seeing that with nRF24L01+'s
                  • A Avamander
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @avamander I tried to resolder it to the board - no luck.
                    It is very small. Very hard to solder any wires to it
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Ok, I did manage to solder the bare sonsor.
                      Consumption is still 50uA.
                      Can anyone please let me know your VELM6075 break board consumption?????
                      • alexsh1A alexsh1
                        Avamander
                        @alexsh1 I'd do it but I'm waiting for my replacement multimeter to arrive, sorry.
                        • A Avamander
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @avamander That's ok. Just post values here - other may benefit on this as well.
                          I still have no idea why the sensor is taking so much current
                          • T
                            tonbor
                            An old thread, tried the github ino for the VEML6075, is not working ok. UVA and UVB sometimes wrong negative figures. I am going to try the sparkfun library, is from 2018. Let you now if I get beter results.
                            • T tonbor
                              tonbor
                              • T
                                tonbor
                                Original by scalz@mysensors: https://forum.mysensors.org/topic/6952/veml6070-and-veml6075-uv-sensors/25#
                                Needs a modified VEML6075-lib: https://github.com/rejoe2/VEML6075
                                rewritten by Tonbor using sparkfun libary
                                //#define MY_NODE_ID 10
                                #include <SparkFun_VEML6075_Arduino_Library.h>
                                VEML6075 uv;
                                //VEML6075 veml6075 = VEML6075();
                                bool sensorFound = false;
                                #define CHILD_ID_UVI 1
                                #define CHILD_ID_UVA 2
                                #define CHILD_ID_UVB 3
                                uint32_t SLEEP_TIME = 30
                                1000; // Sleep time between reads (in milliseconds)
                                MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                                MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                                MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                                sendSketchInfo("UV Sensor", "1.4T");
                                present(CHILD_ID_UVI, S_UV);
                                present(CHILD_ID_UVA, S_UV);
                                present(CHILD_ID_UVB, S_UV);
                                if (!uv.begin()) {
                                Serial.println(F("VEML6075 not found!"));
                                } else
                                sensorFound = true;
                                //#ifdef MY_DEBUG
                                // uint16_t devid = veml6075.getDevID();
                                // Serial.print(F("Device ID = "));
                                // Serial.println(devid, HEX);
                                // Serial.println(F("----------------"));
                                //#endif
                                if (sensorFound) {
                                unsigned long lastSend =0;
                                float uvi;
                                float uva;
                                float uvb;
                                static float uviOld = -1;
                                static float uvaOld = -1;
                                static float uvbOld = -1;
                                //veml6075.sleep(false); // power up veml6075 == begin()
                                //sleep(500);
                                // Poll sensor
                                //veml6075.poll();
                                uv.powerOn();
                                delay(250);
                                uva = uv.a();
                                uvb = uv.b();
                                uvi = uv.index();
                                #ifdef MY_DEBUG
                                Serial.print(F("UVA = "));
                                Serial.println(uva, 2);
                                Serial.print(F("UVB = "));
                                Serial.println(uvb, 2);
                                Serial.print(F("UV Index = "));
                                Serial.println(uvi, 1);
                                if (uvi != uviOld) {
                                send(uviMsg.set(uvi,2));
                                uviOld = uvi;
                                if (uva != uvaOld) {
                                send(uvaMsg.set(uva,2));
                                uvaOld = uva;
                                if (uvb != uvbOld) {
                                send(uvbMsg.set(uvb,2));
                                uvbOld = uvb;
                                uv.shutdown(); ; // power down veml6075
                                sleep(SLEEP_TIME);
                                • T
                                  tonbor
                                  wrote on last edited by tonbor
                                  #52
                                  This ino is working for me, it has the sleep function to save batteries. The Adafruit en the github/mysensors-> https://github.com/schizobovine/VEML6075 lib gives far to high index with my sensor. Only uv a and uv b declaration is not correct. Uv expect a index 0 till 11, domoticz controller passes a lower figure when it receives a number above 11.
