  3. VEML6070 and VEML6075 UV sensors
52 Posts 6 Posters 20.8k Views 5 Watching
  • korttomaK
    korttomaK
    korttoma
    Yeah, my 6075 device is also still working fine on the 2xAA batteries I put in it a year ago.
    • Tomas
    alexsh1A 1 Reply Last reply
    • alexsh1A
      alexsh1A
      alexsh1
      OK, I think found what the issue is. VEML 6070 is not providing accurate UV Index. Adafruit is stating the following:
      Note that this is not UV index, its just UV light intensity!
      This is how it can be converted into sort of UV Index according to the datasheet:
      RISK_LEVEL convert_to_risk_level(WORD uvs_step)
      WORD risk_level_mapping_table[4] = {2241, 4482, 5976, 8217};
      WORD read_uvs_step(void)
      BYTE lsb, msb;
      WORD data;
      VEML6070_read_byte(VEML6070_ADDR_DATA_MSB, &msb);
      VEML6070_read_byte(VEML6070_ADDR_DATA_LSB, &lsb);
      data = ((WORD)msb << 8) | (WORD)lsb;
      return data;
      LEVEL* UV Index
      LOW 0-2
      MODERATE 3-5
      HIGH 6-7
      VERY HIGH 8-10
      EXTREME >=11
      • korttomaK korttoma
        alexsh1A
        alexsh1A
        alexsh1
        #34
        @korttoma @scalz FYG I got a new DMM from Dave Jones 121GW and decided to measure a sleep current for VEML6075 and to my surprise:
        Quickly reading the datasheet I discovered my mistake:
        • current supply - 480uA
        • shutdown current - 800nA
        Therefore, the sensor has to be put to sleep properly.
        One can modify the existing lib:
        uint8_t VEML6075::Shutdown() {  //Places device in shutdown low power mode
        	Config = ReadByte(CONF_CMD, 0); //Update global config value
        	return WriteConfig(Config | 0x01); //Set shutdown bit
        uint8_t VEML6075::PowerOn() {  //Turns device on from shutdown mode
        	return WriteConfig(Config & 0xFE); //Clear shutdown bit
        Make sure you define #define CONF_CMD 0x00
        PS Now I understand why I did not change batteries - they are rechargeable. Charing and putting them back made me think that batteries lasted for a long time. :relaxed:
        • alexsh1A
          alexsh1A
          alexsh1
          I have now three sensor from Vishay - VEML6040, VEML6070 and VEML6075
          I can confirm all three sensors must be property put down to sleep with battery nodes or you would have the following sleeping currents on nodes with typical mysensors setup and standalone sleeping current of 4uA:
          VEML6040 - 240uA
          VEML6070 - 94uA
          VEML6075 - 622uA
          Unfortunately, most libraries do not care for properly sleeping/waking up sensors and therefore, one has to do a little tinkering with software to make it work. I am actually thinking about re-writing some libs completely.
          • A
            Avamander
            Battery issues is one thing, SparkFun's VEML6075 library can't handle direct daylight even (compensated UV readings go negative).
            • A Avamander
              alexsh1A
              alexsh1A
              alexsh1
              @avamander That's impossible - it is designed to handle the direct sunlight. Mine is showing UV Index = 9. Negative UV reading is a software issue - looks like Sparkfun did not write a good lib for it. Did you try a different lib?
              • alexsh1A alexsh1
                Avamander
                wrote on last edited by Avamander
                #38
                @alexsh1
                Haven't bothered, I'm just logging the raw values and then compensating with software.
                • A Avamander
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @avamander It definitely works.
                  My problem for now was just the battery consumption. I have one of these:
                  https://www.aliexpress.com/item/I2C-Interface-3-3V-Board-Based-on-VEML6075-UVA-UVB-Light-Sensor-Module/32832979057.html?spm=2114.search0104.3.1.5f765e65b6nG8K&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10343_10340_10548_10341_10696_10192_10190_10084_10083_10618_10307_10820_10301_10821_10303_10059_100031_10103_524_10624_10623_10622_10621_10620,searchweb201603_25,ppcSwitch_7&algo_expid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3-0&algo_pvid=c6a42de3-1e19-435c-af06-c3a9b24d4ca3&priceBeautifyAB=0
                  The problem is that it is dodgy - the sleep consumption never goes below 50uA at 3.2V. According to the datasheet it should be 800nA while sleeping at 1.8V and 25C. Can anyone measure a shutdown current for VEML6085 please?
                  • alexsh1A alexsh1
                    Avamander
                    @alexsh1 I have the same board, there seems to be a regulator and a few other components on the board, if you remove those, how's the power consumption then?
                    • A Avamander
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @avamander I have removed every component bit by bit. Originally the consumption was 56uA and now it is 50uA with the only sensor left on the board
                      • alexsh1A alexsh1
                        Avamander
                        #42
                        @alexsh1 There's an I^2C address selection jumper on the board, maybe that draws current?
                        • A Avamander
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @avamander desoldered
                          • alexsh1A alexsh1
                            Avamander
                            #44
                            @alexsh1 Just desolder the sensor itself from the board if you're that far already? I wouldn't be surprised if aliexpress sellers sell counterfeit chips that are s****ier, I'm already seeing that with nRF24L01+'s
                            • A Avamander
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @avamander I tried to resolder it to the board - no luck.
                              It is very small. Very hard to solder any wires to it
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                Ok, I did manage to solder the bare sonsor.
                                Consumption is still 50uA.
                                Can anyone please let me know your VELM6075 break board consumption?????
                                • alexsh1A alexsh1
                                  Avamander
                                  @alexsh1 I'd do it but I'm waiting for my replacement multimeter to arrive, sorry.
                                  • A Avamander
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @avamander That's ok. Just post values here - other may benefit on this as well.
                                    I still have no idea why the sensor is taking so much current
                                    • T
                                      tonbor
                                      An old thread, tried the github ino for the VEML6075, is not working ok. UVA and UVB sometimes wrong negative figures. I am going to try the sparkfun library, is from 2018. Let you now if I get beter results.
                                      • T tonbor
                                        tonbor
                                        • T
                                          tonbor
                                          Original by scalz@mysensors: https://forum.mysensors.org/topic/6952/veml6070-and-veml6075-uv-sensors/25#
                                          Needs a modified VEML6075-lib: https://github.com/rejoe2/VEML6075
                                          rewritten by Tonbor using sparkfun libary
                                          //#define MY_NODE_ID 10
                                          #include <SparkFun_VEML6075_Arduino_Library.h>
                                          VEML6075 uv;
                                          //VEML6075 veml6075 = VEML6075();
                                          bool sensorFound = false;
                                          #define CHILD_ID_UVI 1
                                          #define CHILD_ID_UVA 2
                                          #define CHILD_ID_UVB 3
                                          uint32_t SLEEP_TIME = 30
                                          1000; // Sleep time between reads (in milliseconds)
                                          MyMessage uviMsg(CHILD_ID_UVI, V_UV);
                                          MyMessage uvaMsg(CHILD_ID_UVA, V_UV);
                                          MyMessage uvbMsg(CHILD_ID_UVB, V_UV);
                                          sendSketchInfo("UV Sensor", "1.4T");
                                          present(CHILD_ID_UVI, S_UV);
                                          present(CHILD_ID_UVA, S_UV);
                                          present(CHILD_ID_UVB, S_UV);
                                          if (!uv.begin()) {
                                          Serial.println(F("VEML6075 not found!"));
                                          } else
                                          sensorFound = true;
                                          //#ifdef MY_DEBUG
                                          // uint16_t devid = veml6075.getDevID();
                                          // Serial.print(F("Device ID = "));
                                          // Serial.println(devid, HEX);
                                          // Serial.println(F("----------------"));
                                          //#endif
                                          if (sensorFound) {
                                          unsigned long lastSend =0;
                                          float uvi;
                                          float uva;
                                          float uvb;
                                          static float uviOld = -1;
                                          static float uvaOld = -1;
                                          static float uvbOld = -1;
                                          //veml6075.sleep(false); // power up veml6075 == begin()
                                          //sleep(500);
                                          // Poll sensor
                                          //veml6075.poll();
                                          uv.powerOn();
                                          delay(250);
                                          uva = uv.a();
                                          uvb = uv.b();
                                          uvi = uv.index();
                                          #ifdef MY_DEBUG
                                          Serial.print(F("UVA = "));
                                          Serial.println(uva, 2);
                                          Serial.print(F("UVB = "));
                                          Serial.println(uvb, 2);
                                          Serial.print(F("UV Index = "));
                                          Serial.println(uvi, 1);
                                          if (uvi != uviOld) {
                                          send(uviMsg.set(uvi,2));
                                          uviOld = uvi;
                                          if (uva != uvaOld) {
                                          send(uvaMsg.set(uva,2));
                                          uvaOld = uva;
                                          if (uvb != uvbOld) {
                                          send(uvbMsg.set(uvb,2));
                                          uvbOld = uvb;
                                          uv.shutdown(); ; // power down veml6075
                                          sleep(SLEEP_TIME);
