  3. Battery life for Motion Sensor
24 Posts 8 Posters 10.0k Views 8 Watching
    wrote on last edited by gohan
    Use a multimeter that can measure uA or build your own (there is a project on openhardware).
    If your nrf24 are clones it is normal, also the material of your house affects range.
    • P popsyann
      @dbemowsk Thank you for the info. I have made some progress and I have one sensor working on Pro Mini, with 2 x AA batteries. I am facing an issue with radio range. Apparently everything works well within close range but if I put the sensor some 8-10 meters from the gateway, I do not have accurate update of the sensor state (on-off). I though the NRF24 was able to cover such range.....
      alexsh1A
      alexsh1A
      alexsh1
      @popsyann Poor RF issues can be a sign power issues (GW) or an indication of a low quality nrf24l01+
      I have 3 PIRs. One of them have been working for 1.5 years on 2xAA batteries (Arduino Pro Mini modified + nrf24l01+). Some nodes are very remote from the gateway.
      P 1 Reply Last reply
      • alexsh1A alexsh1
        P
        P
        popsyann
        @alexsh1 Hi, maybe you can help me with the following:
        I have built motion sensors with Arduino mini 3.3V and they have been working well, integrated in Home Assistant. However, the battery life is far from being satisfactory (I am looking for at least a year, and currently I reach a month, at most).
        While replacing batteries, I have discovered (because the sensor was not working well after battery replacement) that the sensor component works well (3V when motion detected, 0V when no motion) when not connected to the Arduino Mini. As soon as I connect the output to pin 3 (as defined in the sketch), I get 3V when there is motion, and 1.1V when no motion (which results in no status update). Do you have any clue on what could be the reason of this 1.1V once connected (instead of 0V with no motion)?
        Help appreciated.
        alexsh1A bgunnarbB 2 Replies Last reply
        • P popsyann
          Help appreciated.
          alexsh1A
          alexsh1A
          alexsh1
          @popsyann you have to provide more info :
          • did you modify arduino pro mini for batteries life?
          • what PIRs do you have?
          • post your sketch please
          • P popsyann
            Help appreciated.
            bgunnarbB
            bgunnarbB
            bgunnarb
            @popsyann
            In your sketch, please check that you have defined the input pin for the PIR pin as pinMode (PIR_PIN, INPUT) and not pinMode (PIR_PIN, INPUT_PULLUP). If you have activated the internal pullup in the arduino this will prevent the PIR from pulling the input low when there is no motion.
            I have never been so busy since I retired!
            • alexsh1A alexsh1
              P
              P
              popsyann
              @alexsh1
              Hi
              1. I did not modify the Arduino Pro Mini for Batteries life. What is there that I should do? Did not read anything about it.
              2. I use either the standard PIR Motion sensor (with two potentiometers on board the module to adjust sensitivity and timer) (Seems to be HC-SR501), or the mini version of this sensor .
              3. The code I use is the one given in the MySensors
               * Version 1.0 - Henrik Ekblad
              // Enable debug prints
              // #define MY_DEBUG
              //#define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
              // Initialize motion message
              	present(CHILD_ID, S_MOTION);
              	// Read digital motion value
              	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
              	Serial.println(tripped);
              • alexsh1A
                alexsh1A
                alexsh1
                @popsyann
                1. https://www.mysensors.org/build/battery
                2. OK
                3. This is a standard sketch. Cannot see anything wrong.
                • alexsh1A alexsh1
                  @popsyann
                  2. OK
                  P
                  P
                  popsyann
                  @alexsh1 Indeed, I saw the batteries life page but I did not want to cut into my Pro Minis (and I believe that the LED provides a good info as to the sensor is well powered).
                  Even if I make this modification, that does not explain the 3V to 1V instead of 3V to 0V phenomenon. Does it?
                  alexsh1A 1 Reply Last reply
                  • P popsyann
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @popsyann I de-soldered power LEDs and power regulators. You do not need them for battery powered nodes and this is reversible. Otherwise you wont get low uA.
                    This is about power.
                    Talking about voltage - did you measure it? How do you know if goes to 1V?
                    Did you double-triple check all wires and everything is correct?
                    FYG - HR-SR501 has to be modified as well for 3.3V (remove regulator)
                    http://www.instructables.com/id/Convert-a-5v-PIR-Motion-Sensor-to-33v-for-ESP8266/
                    • alexsh1A alexsh1
                      P
                      P
                      popsyann
                      @alexsh1 Noted for the de-soldering info. I get it.
                      For voltage measurements, yes I did measure the voltage between the ground and the output pin of the motion sensor: when the pin is not connected to Arduino, I get 3V when motion is detected and 0V when no motion.
                      Then I connect the output pin of the PIR to the Arduino (pin 3) and I measure on Arduino pin 3: I get 3V when motion is detected and 1.2V when no motion.
                      As for the modification of the PIR: noted. But I mainly use the mini PIR, where such modification cannot be applied (as the circuitry is very different and very simple).
                      For the cabling: when I load on the Arduino the Serial Gateway sketch, everything works well, the Gateway starts properly, meaning the radio is well connected.
                      When I load the motion sensor sketch, it start properly, finding the right "parent" and immediately after this, there is a flow of info going out of the Arduino+sensor, sending 0s or 1s, constantly (like if there was an issue with the interrupt process).
                      And what I do not understand is that this (these) sensor(s) has(have) been working well for a while.
                      • P popsyann
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #24
                        @popsyann said in Battery life for Motion Sensor:
                        Please search for sleep() function - it has changed the way it works at some stage in MySensors 2.*
                        https://forum.mysensors.org/topic/1088/battery-powered-pir
                        https://forum.mysensors.org/topic/5807/interrupt-and-sleep/26
                        https://forum.mysensors.org/topic/5552/pin-change-interrupt-not-firing-with-mysensors/28
                        Another reason could you that your PIR is not settling properly - this is why it sends out 1s and 0s to the GW. Try to insert sleep(20000); into void setup() at the end to settle the PIR
