  3. Ethernet Gateway with Nano - Invalid message length, 0 (actual) != 7 (expected)
8 Posts 2 Posters 2.2k Views 2 Watching
  • pihomeP
    pihomeP
    pihome
    wrote on last edited by pihome
    Hi Guys,
    back again with another problem; i m trying to build Ethernet gateway, it starts ok, gets ip but then it goes into some loop with this message on serial port:
    0;255;3;0;9;TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    0;255;3;0;9;!TSF:MSG:LEN,0!=7
    Gateway Startup
    ⸮⸮⸮⸮=⸮0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.99.7
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;!TSF:MSG:LEN,0!=7```
    No Major change in code,
     * Version 1.0 - Henrik EKblad
     * LED purposes:
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define RF24_CHANNEL     125
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    //#define MY_IP_ADDRESS 192,168,99,166
    //#define MY_IP_GATEWAY_ADDRESS 192,168,99,1
    //#define MY_IP_RENEWAL_INTERVAL 600
    #define MY_PORT 5003
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    PiHome - Smart Heating Control
    • pihomeP pihome
      Hi Guys,
      Gateway Startup
      IP: 192.168.99.7
       * LED purposes:
      #define MY_SOFTSPI
      @pihome said in Ethernet Gateway with Nano - Invalid message length, 0 (actual) != 7 (expected):
      As you can see the gateway is only receiving zeroes, probably due to a radio communication problem.
      See this thread for some suggestions on how to solve it.
      • pihomeP
        pihomeP
        pihome
        @Yveaux
        yes it looks like power issue, haven't fixed it yet but for future if some one stumbled upon this posts: gateway starts ok, but as soon as some message arrives gateway reset and controller lost connection with gateway (serial output below), i dont have inductor available to test suggested solution.
        PS: i have tried supplying power from separate source to W5100, changed cap on nrf from 10uf to 100uf but no luck.
        IP: 192.168.99.7
        0;255;3;0;9;TSF:MSG:READ,26-18-0,s=1,c=1,t=38,pt=7,l=5,sg=0:3.36
        IP: 192.168.99.7
        0;255;3;0;9;TSF:MSG:READ,27-27-0,s=1,c=1,t=38,pt=7,l=5,sg=0:1.61
        IP: 192.168.99.7
        0;255;3;0;9;MCO:BGN:INIT OK,TSP=1```
        • pihomeP pihome
          @Yveaux
          IP: 192.168.99.7
          IP: 192.168.99.7
          IP: 192.168.99.7
          @pihome well, it sounds like this issue : https://www.google.nl/url?sa=t&source=web&rct=j&url=https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time&ved=2ahUKEwiWhI_V07ncAhWPKVAKHRTzDh4QFjABegQIBhAB&usg=AOvVaw3McbF-Z_smHD4YYBNx5udV
          • pihomeP
            pihomeP
            pihome
            @Yveaux
            thank you for help, downgrading to the 1.16.11 version fixed the disconnection issue. now back to power problem, i have order inductors to test this but it need another 4 weeks :(
            How to Change to version 1.116.11
            172pilot: "Tools, Board, and at the top of the list, choose board manager, click in the window for "Arduino AVR Boards" and it will give you a pull-down for 'version' in the bottom left. Choose your 1.16.11 version, and click install.."
            IP: 192.168.99.5
            0;255;3;0;9;TSF:MSG:READ,25-25-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSF:MSG:BC
            0;255;3;0;9;TSF:MSG:FPAR REQ,ID=25
            0;255;3;0;9;TSF:CKU:OK,FCTRL
            0;255;3;0;9;TSF:MSG:GWL OK
            0;255;3;0;9;TSF:MSG:SEND,0-0-25-25,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            0;255;3;0;9;!TSF:MSG:SEND,0-0-25-25,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Sensor
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=12,pt=0,l=4,sg=0:1.35
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=0,c=0,t=6,pt=0,l=0,sg=0:
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
            0;255;3;0;9;TSF:MSG:SEND,0-0-25-25,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=1,c=1,t=38,pt=7,l=5,sg=0:1.47
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=0,pt=1,l=1,sg=0:34
            0;255;3;0;9;TSF:MSG:READ,25-27-0,s=0,c=1,t=0,pt=7,l=5,sg=0:29.5
            0;255;3;0;9;TSF:MSG:READ,26-26-0,s=1,c=5,t=46,pt=7,l=5,sg=0:6.53
            0;255;3;0;9;TSF:MSG:READ,26-26-0,s=255,c=3,t=0,pt=1,l=1,sg=0:77
            0;255;3;0;9;TSF:MSG:READ,26-26-0,s=0,c=1,t=0,pt=7,l=5,sg=0:28.7
            0;255;3;0;9;TSF:MSG:READ,21-21-0,s=0,c=1,t=0,pt=7,l=5,sg=0:24.1
            0;255;3;0;9;TSF:MSG:READ,20-20-0,s=0,c=1,t=0,pt=7,l=5,sg=0:22.8
            0;255;3;0;9;TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=1,c=1,t=38,pt=7,l=5,sg=0:0.38
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=255,c=3,t=0,pt=3,l=1,sg=0:37899
            0;255;3;0;9;!TSF:MSG:LEN,9!=8
            0;255;3;0;9;TSF:MSG:READ,25-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0:29.2```
            • pihomeP
              pihomeP
              pihome
              Hi Guys,
              while troubleshooting Ethernet gateway, i discover my arduino nano voltage on different pin as i wasn't sure from where to feed power to W51000 module just decided to check voltage on these three different pins and to my surprise all three gives different values . i can not find any decent schematic to check reason for these different voltage. can some shed some light please... i always thought 5v is straight from usb connector without any regulator etc...
              voltage at USB connector 5.11v
              VIN Pin 4.33v
              5v Pin 4.76v
              • pihomeP pihome
                Hi Guys,
                VIN Pin 4.33v
                5v Pin 4.76v
                @pihome according to the arduino nano schematic 5v is connected through a diode to vusb; you'll see the voltage drop.
                Vin is meant as input for the nano's voltage regulator. You should only feed power to it, not sink from it.
                • pihomeP
                  pihomeP
                  pihome
                  @Yveaux
                  thank you for reply, found something similar for 5v, just in case some one stumble upon this.
                  +5V	Output or Input
                  +5V Output (From On-board Regulator) or
                  +5V (Input from External Power Supply
                  ref: http://www.circuitstoday.com/arduino-nano-tutorial-pinout-schematics
                  12.5k
