  3. OpenHAB
  4. Rule for dimmer and LED strip
2 Posts 2 Posters 2.0k Views 2 Watching
  • vladimirV
    vladimirV
    vladimir
    Hello!
    I have two nodes:
    1. Dimmer (encoder with switch)
    2. RGB LED strip
    Please tell me how to make a rule for controlling two parameters (on / off, brightness) of an RGB LED strip using a dimmer unit.
    Perhaps someone already uses this rule in OpenHAB?
    Dimmer
    Dimmer
    RGB LED strip
    RGB LED strip
    H 1 Reply Last reply
    • vladimirV vladimir
      Hello!
      I have two nodes:
      2. RGB LED strip
      Dimmer
      Dimmer
      RGB LED strip
      RGB LED strip
      H
      H
      hard-shovel
      @vladimir
      Are you looking for something similar to the following:
      rule  "Rule Dimmer to Color Item Brightness"
      // TestDimmer121 is the item name of the dimmer value
      // Mock_RGB_Color_x is the Item name of the color strip
      // Openhab sends color data as Hue, Saturation, Brightness Data
      when
      	Item TestDimmer121 changed
      then
      	logInfo("rules","Dimmer to Color conversion Received " +TestDimmer121.state )
      	var PercentType BrightnessfromDimmer= TestDimmer121.state
      	var HSBType currentState = Mock_RGB_Color_x.state as HSBType
      	var DecimalType CurrentHue = currentState.hue
      	var PercentType CurrentSaturation = currentState.saturation
      	var PercentType CurrentBrightness = currentState.brightness
      	logInfo("rules","HSBtype " + currentState)
      	Mock_RGB_Color_x.sendCommand(new HSBType(CurrentHue,CurrentSaturation,BrightnessfromDimmer))
      	logInfo("rules","HSBtype NEW " +Mock_RGB_Color_x.state.toString)
      end
      You did not post your item names, so you need to change to suit.
      I do not have a HSB lamp node to physicaly test on, so i have only been checking the openhab logs.
