  3. 💬 EFEKTA BME280 Sensor
cr2450bme280cr2477nrf52832nrf52
14 Posts 6 Posters 4.0k Views 5 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/638/EFEKTA-BME280-Sensor
    • MiKaM
      MiKaM
      MiKa
      You design it for some nice enclosure???
      Regards,
      MiKa
      berkseoB 1 Reply Last reply
      • MiKaM MiKa
        Regards,
        MiKa
        berkseoB
        berkseoB
        berkseo
        @mika said in 💬 EFEKTA Atmospheric Pressure & Temperature & Humidity Sensor:
        Regards,
        MiKa
        PCB is prepared for installation in the case, there are mounting holes, feed-through saws. As long as this device is without the case, you can make the case yourself, all conditions are created for this. Later it will be offered in the case, but that's another story...
          shajek
          Is sketch available? Thanks :)
          • S shajek
            berkseoB
            berkseoB
            berkseo
            @shajek In the coming days will add a sketch. It's a mix of the standard mysensors sketch and the adafruit sketch.
            • T
              thecricketer
              Thanks for designing this! But I'm having a hard time getting it made. Primarily because of the 0.2mm hole size and there are 2 masks for each of the top and bottom (and I think the PCB manufacturers are having a hard time reading Russian). Has anyone else experienced this or have any of the files been modified since this was posted? I have tried several houses and they come up with the same problems and those that have been able to make it work change the price to about $10 per board because of the hole size.
              magpernM berkseoB 2 Replies Last reply
              • T thecricketer
                magpernM
                magpernM
                magpern
                wrote on last edited by magpern
                @thecricketer I had the same problem. It looks like @berkseo is uskng 0.2mm holes for vias. I simply changed the drill file. The T01C0.2 I changed to T01C0.3. Then I checked all the gerbers in a gerber viewer and the slightly larger holes does work.
                Pcbway can read the russian file names. 5 usd for 10 pcs.
                But, do you have the schematics? If you have the board it would be a guessing game to know that component goes where.
                • T thecricketer
                  berkseoB
                  berkseoB
                  berkseo
                  @thecricketer
                  https://jlcpcb.com/
                  Just adding my archives. I did not encounter problems with file names in Cyrillic.
                  • magpernM magpern
                    berkseoB
                    berkseoB
                    berkseo
                    @magpern said in 💬 EFEKTA BME280 Sensor:
                    What kind of problems?
                    • magpernM
                      magpernM
                      magpern
                      @berkseo said in 💬 EFEKTA BME280 Sensor:
                      That the vias where 0.2mm drill and the fab houses I tried charged 10 times extra for 0.2 drill than 0.3.
                      But I don't think it is a problem changing them to 0.3 (I changed it in the drill file). The copper pads on the vias are 0.5mm in diameter, and a drill with 0.3 will still work.
                      Green 0.2mm drill, yellow 0.3mm drill, red is copper.
                      • magpernM magpern
                        berkseoB
                        berkseoB
                        berkseo
                        If you change yourself, I think this is not a problem with the inner 0.3 and the outer layer of 0.5 problems will not be
                        • magpernM
                          magpernM
                          magpern
                          @berkseo Do you have a what goes where description? like this but with a number instead of x
                          • Rx , Rx----- Resistors 10K 1% 0805 2 pieces
                          • Rx ----- Resistors 1M 1% 0805 1 piece
                          • Rx ----- Resistors 470K 1% 0805 1 pcs
                          • Rx, Rx, Rx, Rx ----- Resistors 4.7K 1% 0805 4 piece
                          • Rx ----- Resistors 27K 1% 0805 1 piece
                          • Rx ----- Resistors 20K 1% 0805 1 piece
                          • Rx ----- Resistors 5.6K 1% 0805 1 piece
                          • Cx, Cx ---- Condenser 100nf 2 pieces
                          And the code, could you upload the code for this and for the SHT20 version?
                          • berkseoB
                            berkseoB
                            berkseo
                            update! new pcb ver2+case model+experemental sketch :)
                            • magpernM
                              magpernM
                              magpern
                              Could you please update the description with what component goes where on the pcb?
                              12.5k
