  3. Arduino Uno with Ethernet Shield W5100 not working
15 Posts 6 Posters 4.7k Views 5 Watching
  • kduinoK
    kduinoK
    kduino
    Hi, I've cut present, setup and loop not to waist to much space. I edit and add them too...
    Unfortunately as you can see, the gateway is not receiving anything and therefore not answering the node.
    I will test with different hardware now, if there is something weird.
    • kduinoK kduino
      @kduino thanks for clearing that up.
      st=OK:
      means that the node is getting a hardware acknowledgement on the sent message. So something (probably the gateway unless you have other MySensors nodes nearby) receives the message and acknowledges it, but then nothing happens.
      Could you add #define MY_DEBUG_VERBOSE_RF24 to both sketches to see if that can give a clue?
      • kduinoK
        kduinoK
        kduino
        Wow cool, so the hardware is basically running, but for some reason, the gateway doesn't accept the message.
        I'll double-check the signing algorithm (perhaps I comment it to see, if there are arriving unsigned messages) and I will post the result.
        Strange thing. Thank you very much!
        I'll do this tonight.
        AnticimexA 1 Reply Last reply
        • kduinoK kduino
          AnticimexA
          AnticimexA
          Anticimex
          @kduino looks like communication fails already during parent lookup. Signing should not kick in until after that so I don't think that is the issue. But you could always try to disable signing to see if it affects things (the added code from signing could lead to stack problems which might manifest itself in many obscure ways, in case you are limited in RAM).
          • kduinoK
            kduinoK
            kduino
            This is what is coming out of the gateway debug:
             MCO:BGN:INIT GW,CP=RNNGAS--,VER=2.3.0
            53 TSM:INIT
            54 TSF:WUR:MS=0
            55 RF24:INIT
            56 RF24:INIT:PIN,CE=5,CS=6
            59 RF24:WBR:REG=0,VAL=14
            66 RF24:WBR:REG=3,VAL=3
            68 RF24:WBR:REG=4,VAL=95
            70 RF24:WBR:REG=5,VAL=76
            72 RF24:WBR:REG=6,VAL=37
            74 RF24:WBR:REG=16,VAL=115
            77 RF24:WBR:REG=29,VAL=4
            79 RF24:RBR:REG=6,VAL=37
            81 RF24:RBR:REG=5,VAL=76
            83 RF24:WBR:REG=2,VAL=2
            87 RF24:WBR:REG=1,VAL=0
            89 RF24:WBR:REG=28,VAL=3
            91 RF24:FRX
            92 RF24:FTX
            93 RF24:WBR:REG=7,VAL=112
            96 TSM:INIT:TSP OK
            97 TSM:INIT:GW MODE
            99 RF24:WBR:REG=2,VAL=3
            101 RF24:WBR:REG=1,VAL=1
            103 RF24:STL
            105 RF24:WBR:REG=0,VAL=15
            107 RF24:WBR:REG=10,VAL=0
            109 TSM:READY:ID=0,PAR=0,DIS=0
            112 MCO:REG:NOT NEEDED
            114 RF24:RBR:REG=23,VAL=17
            16766 GWT:TIN:IP=192.168.178.XYZ
            17769 MCO:BGN:STP
            17771 RF24:RBR:REG=6,VAL=37
            17774 RF24:RBR:REG=5,VAL=76
            17776 MCO:BGN:INIT OK,TSP=1
            17779 RF24:RBR:REG=23,VAL=17
            17782 RF24:RBR:REG=23,VAL=17
            17784 RF24:RBR:REG=23,VAL=17
            17787 RF24:RBR:REG=23,VAL=17
            Last line is repeating for ever
            Just to be sure I insert the gateway code again:
            #define MY_RADIO_RF24
            //#define MY_RADIO_NRF5_ESB
            //#define MY_RADIO_RFM95
            #define MY_GATEWAY_W5100
            //#define MY_W5100_SPI_EN 4
            // radio on the same spi bus.
            #define MY_SOFTSPI
            #define MY_RF24_CE_PIN 5
            #define MY_RF24_CS_PIN 6
            // Enable UDP communication
            #define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
            #define MY_PORT 5003
            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 46
            // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
            // Enable inclusion mode
            // Set blinking period
            // Flash leds on rx/tx/err
            #if defined(MY_USE_UDP)
            #include <EthernetUdp.h>
            #include <Ethernet.h>
            // Singing issues:
            #define MY_SIGNING_SOFT
            #define MY_SIGNING_SOFT_RANDOMSEED_PIN A5
            • kduinoK
              kduinoK
              kduino
              What I have to mention: The setting was running great as a Serial Gateway config. But when I changed to ethernet gateway I was not able to restore this condition together with the W5100 shield. Moreover I don't know if the pin4 is making some trouble. As far as I know its used for writing to the sd card (which I don't use...).
              • kduinoK kduino
                @kduino Could you give this a try? Add the following to your sketch:
                #define SD_SS_PIN                     (4)  // chip-select for SD card (unused, pull high!)
                void before() {
                    pinMode(SD_SS_PIN, OUTPUT);
                    digitalWrite(SD_SS_PIN, HIGH);
                • kduinoK
                  kduinoK
                  kduino
                  I'll try this as soon as possible. Although the ip network connection doesn't seem to be the issue since ip dedication is without problem.
                  alexsh1A 1 Reply Last reply
                  • kduinoK kduino
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @kduino Did you manage so solve it please?
                    • SpannersS
                      SpannersS
                      Spanners
                      wrote on last edited by Spanners
                      I'm experiencing the same issue with 2x Uno+NRF24+W5100 Shields that I tried to upgrade from 2.2.0 to 2.3.1 yesterday with Arduino IDE 1.8.8
                      I didn't modify the sketch. It does nothing funky like run other sensors, use signing or encryption.
                      I have the code to disable the the SD reader in setup() already. Haven't tried in before() yet.
                      The devices had been working fine previously.
                      I have upgraded 2 other W5100 Ethernet gateways based on FreeTronics EtherTen and EtherMega to 2.3.1 with no issues.
                      I have upgraded a Nano based Repeater with 2.3.1 with no issues.
                      I have upgraded an Energy Monitoring Sensor with 2.3.1 and it works fine with the FreeTronics gateways but not with the Uno gateways.
                      On the Uno Gateways:
                      I have tried downgrading to MyS 2.2.0
                      I have tried downgrading Ethernet library from 2.0 to 1.x (can't remember exact version)
                      Tried downgrading the AVR boards definition in the IDE
                      Thus far have not been able to get them working on any combination of older code. Any suggestions on how to troubleshoot further would be most welcome.
                      • SpannersS Spanners
                        @spanners said in Arduino Uno with Ethernet Shield W5100 not working:
                        Please do so. It makes a big difference!
                        SpannersS 1 Reply Last reply
                        • YveauxY Yveaux
                          SpannersS
                          SpannersS
                          Spanners
                          @yveaux - unfortunately not that much of a difference that the two Uno's started working..
                          0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
                          16:26:38.766 -> 10006 TSM:INIT
                          16:26:38.766 -> 10008 TSF:WUR:MS=0
                          16:26:38.766 -> 10015 TSM:INIT:TSP OK
                          16:26:38.766 -> 10017 TSM:INIT:GW MODE
                          16:26:38.766 -> 10019 TSM:READY:ID=0,PAR=0,DIS=0
                          16:26:38.766 -> 10022 MCO:REG:NOT NEEDED
                          16:26:39.349 -> 10586 GWT:TIN:IP=10.0.0.244
                          16:26:40.337 -> 11589 MCO:BGN:STP
                          16:26:42.372 -> 13596 MCO:BGN:INIT OK,TSP=1
                          16:26:42.372 -> 13603 TSM:READY:NWD REQ
                          16:26:42.399 -> 13641 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                          Then they just sit there.
                          With verbose NRF debug on:
                          20777 RF24:RBR:REG=23,VAL=17
                          20780 RF24:RBR:REG=23,VAL=17
                          20783 RF24:RBR:REG=23,VAL=17
                          20786 RF24:RBR:REG=23,VAL=17
                          20788 RF24:RBR:REG=23,VAL=17
                          20791 RF24:RBR:REG=23,VAL=17
                          20794 RF24:RBR:REG=23,VAL=17
                          20796 RF24:RBR:REG=23,VAL=17
                          20799 RF24:RBR:REG=23,VAL=17
                          Goes on forever
                          Edit:
                          /epic_facepalm Tried everything including downgrading the IDE to 1.8.5, all the libraries etc..
                          Out of desperation I thought I'd try the Uno Gateways on the same MY_RF24_CHANNEL/MY_RF24_BASE_RADIO_ID as my production MyS network and they started picking up transmits.
                          Focus now changed to the test sensor. I started replacing hardware and discovered a flaky Dupont pin for the GND connection on my NRF radio... on the sensor I was using to test with.. of course... So between validating that my test sensor worked on the other gateways and then testing the upgraded gateways, the sensor ceased transmitting reliably.
                          That my friends, is Murphy's law as applied to MySensors builds.
                            Goes on forever
                            Edit:
                            @spanners I told you it would make a big difference :-)
                            Thanks for reporting back!
                            12.5k
